Talk to me about whisker poles! - Page 6 - SailNet Community
 9Likes
post #51 of 61 Old 07-29-2013
O'Day 272 - "Pana-Sea-A"
You can do without a whisker pole. I use a setup I read about in Sail which uses the boom as a whisker pole. All you need is a snatch block clipped to the end of your boom. Run the job sheet through the block, down to the deck jib block and then to a winch. The boom should be out as far as possible(watch for chafe) and the main furled. Rig a preventer, then pull out your Jenny. This works great, and is simple,taking about 5 minutes to set up. True, you only have one sail, but I still make decent speed.
Mjfossler is offline
post #52 of 61 Old 07-29-2013
TakeFive's Avatar
Re: Talk to me about whisker poles!
Maybe simple for those with a furling main.
Even then, 5 minutes to set up doesn't sound so simple.
From this thread, I am getting a real appreciation for how different our rigs may be, and therefore there's no one single best way to do a whisker pole because of these differences.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #53 of 61 Old 07-29-2013
grumpy old man
fos:
Yeah but,,,,,,,
Now you have both sails on the same side of the boat.
And that's why we use a whisker pole.
Ta dahhhhhhhhhhhhhhhh
Bob's Blog ....
bobperry is offline
post #54 of 61 Old 07-30-2013
outbound's Avatar
If I don't want to use a pole( by myself or just plain lazy). May put reef in main and go to far reach even with genny and light/ moderate air. Not pretty but easy as have preventers for main on both sides always rigged. Easy to gybe back and forth.If long run its clearly worth the effort to use the pole and go wing and wing God bless carbon fiber.
s/v Hippocampus
Outbound 46
outbound is offline
post #55 of 61 Old 07-30-2013 Thread Starter
weinie's Avatar
It literally takes me 2 minutes to get my new pole up. Another minute if I use the topping lift. And that's single handed.
I use the forspar stanchion mounts to keep it near the mast.
weinie is offline
post #56 of 61 Old 07-30-2013
TakeFive's Avatar
Originally Posted by weinie View Post
It literally takes me 2 minutes to get my new pole up...
LOL. Classic quote coming from a guy named weinie.
Could you explain the single handed part?
TakeFive is offline
post #57 of 61 Old 07-30-2013 Thread Starter
weinie's Avatar
Well, I just use the same hand to unzip and then ....
oh, you meant the boat!
Easy. Autopilot keeps the boat on a deep reach with the main blanketing the genoa. Sheets are free. I connect the pole to the sheet (and topping lift if needed). I jibe the sail over if going wing/wing. Extend the pole, pushing the sail out and then hook it to the ring on the mast. If the wind is up, I'll extend the after it's attached to the mast.
Go back to the cockpit, head DDW, trim the sheet and I'm good to go.
ETA: The only pain in the ass is the pole needs to be extended just a couple of inches first before you can work the latches for some reason.
weinie is offline
post #58 of 61 Old 07-30-2013
flyingwelshman's Avatar
Here’s what I can tell you about whisker poles:
In Warsaw, 1967, an underground, subversive group sprang up in opposition to the Communist regime of Władysław Gomułka.
The group met secretly at a location beneath a storefront on Ulica Kubusia Puchatka.
They named the clandestine meeting room the ‘Kit Kat Klub’ – a reference to the setting of the play (and subsequent film) Cabaret.
The philosophy of the group was based on the writings of Robert ‘Bob’ Kane auteur of the popular television series ‘Batman’.
Male members of the group donned costumes based on that worn by Julie Newmar in her character as Catwoman. They would then entertain themselves by chasing bits of string and balls of wool.
The members referred to themselves as ‘Polacy wąsy’ or: ‘Whisker Poles’.
Now you know the rest of the story!
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #59 of 61 Old 07-30-2013
Dave makes a good point. The topping lift can make it easier to handle the pole. But on boats under 40' LOA I'm not convinced it's a problem. But then I am a huge strong brute of a man not to be cowed by a mere whisker pole.
"Cowed"?
" mere "?
English is a challenge for me.
And to clarify... I don't have WHISKER POLE. I'm using my spin pole and it's not light.
I do have an extendable whisker pole that a friend gave me and have also found the forespar whisker pole that came w/ the boat although it seems a bit short. May have to try it out tomorrow night in the Wed night race!
Still, I'm thinking the TL makes it easier to handle a long awkward object. Maybe 30' and under it's overkill though.
CS 36M DIANTHUS
sailordave is offline
post #60 of 61 Old 07-30-2013
No, you only have the jib- the main is flaked on the boom.
Whisker Poles - How Often Do You Use Them? montenido General Discussion (sailing related) 39 12-20-2008 01:36 AM
Whisker Poles RichardElliott Gear & Maintenance 1 02-11-2003 10:27 AM
used whisker poles chris1f Gear & Maintenance 1 06-15-2002 01:18 PM
