Talk to me about whisker poles! - SailNet Community
 9Likes
post #1 of 61 Old 06-25-2013 Thread Starter
weinie's Avatar
I have a Catalina 27 and I'd like to use a whisker pole with my 150% furling genoa. (Foot is 18').
I was looking at the forspar twist lock 7-15 ft pole.
Assuming I store it on the stanchions with the forspar stanchion brackets, can I simply use a pad eye on the mast or should I go with a t-track and car?
Do I need any other hardware?
weinie is offline
post #2 of 61 Old 06-25-2013
Lookin' for an excuse ...
CaptTony's Avatar
Many years ago I had a Hunter 27. It had a 150 Genoa sail like you're Catalina. The boat was outfitted with a twist lock whisker pole, and I used a pad eye on the mast. It worked fine. One year returning from the Bahamas I was doing a wing on wing for 10 hours with that setup.
Having said that it would probably be better set up with a track on the mast; although if I ever did it again with a similar size boat I probably would just use the padeye again.
Capt Tony
CaptTony is offline
post #3 of 61 Old 06-25-2013 Thread Starter
weinie's Avatar
Re: Talk to me about whisker poles!
I am also assuming one can use the mainsail's topping lift for the pole, correct?
weinie is offline
post #4 of 61 Old 06-25-2013
My .02 (check current exchange rates...) is that a pad eye is fine for a whisker pole if you use it with a genoa of a fixed size. And frankly you can use it for other sails just know that it won't be optimal (but close enough).
I also feel like a topping life is overkill for your boat. Unless your whisker pole is getting particularly heavy or long you'll be fine without it. What will happen is you will close down the leech a bit but frankly downwind sailing is not real dependent on perfect sail shape.
FWIW, here it is a picture of my 23' boat rolling along with a homemade whisker pole made out of a sturdier than normal twist extension, a snap clip and a chopped up paint roller set to a point. You could argue that the pad eye coule be another foot up the mast but I can't see it affecting sail shape much if at all.
CatMan22 and blutoyz like this.
tschmidty is offline
post #5 of 61 Old 06-27-2013
blutoyz's Avatar
SOrry for the hijack but I would sure like some pics of your rig on this if you have them....I like it!!!
blutoyz is offline
post #6 of 61 Old 06-27-2013
TQA
Bombay Explorer 44
TQA's Avatar
Cut down windsurfer masts work as well if you want to go the DIY route.
TQA is offline
post #7 of 61 Old 06-27-2013
grumpy old man
You can use a pad eye on the mast in line with your genny clew. You do not need a topping lift. The leech of the jib will do that job. If it is just a whisker pole it will never see the compressive loads a spin pole sees so you can go light on the whisker pole.
jameswilson29 likes this.
Bob's Blog ....
bobperry is offline
post #8 of 61 Old 06-27-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
I used my painter's pole boat hook a few weeks ago. I put the screw-on boat hook thru the gorilla loop at the clew/jib sheet point and loosely tied the poly rope wrist strap to the main halyard cleat on the mast. Screw/twist till it's loose, extend as needed, lock 'er down and let 'er ride !
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #9 of 61 Old 06-27-2013
You don't want to use the mainsail topping lift. It emerges from the mast the wrong way.
An extra jib halyard should work well enough if you have one.
Also, I recommend buying the slightly more expensive line adjustable pole.
My experience with the twist adjustable ones has not been positive.
rb
Randy Browning
Norwalk, CT USA
sonosail is offline
The Following User Says Thank You to sonosail For This Useful Post:
DJR351 (07-06-2013)
post #10 of 61 Old 06-27-2013
outbound's Avatar
When I bought one a few weeks back Forespar was having a rebate promotion. They have all aluminum, 1/2+ 1/2 ,all carbon. Might be a good idea to check if you can still get a price break. A surprising amount of force is generated in the pole when you use it with any wind up. Like using a preventer on the main having your jib poled out takes some of the excitement out in heavy winds. Makes for better shape and I think less wear and tear on the sail. Have a carbon one due to size and being a feeble old man. Think it's a silly expense unless you have to do it like I did. Think getting a good store bought telescoping one is worth it as it makes it safer with less foredeck gymnastics and allows use on any sail. Having some form of fore guy/after guy or at least some way to keep the pole down makes it less scary as well.
sonosail likes this.
s/v Hippocampus
Outbound 46
outbound is offline
Whisker Poles - How Often Do You Use Them? montenido General Discussion (sailing related) 39 12-20-2008 02:36 AM
Whisker Poles RichardElliott Gear & Maintenance 1 02-11-2003 11:27 AM
used whisker poles chris1f Gear & Maintenance 1 06-15-2002 02:18 PM
