Trying to be prepared for the inevitable hurricane - Page 2 - SailNet Community
 5Likes
post #11 of 16 Old 06-28-2013 Thread Starter
Re: Trying to be prepared for the inevitable hurricane
Thanks for the suggestions so far, everyone.
If there's something bearing down a la Sandy, we would definitely haul out. However, here in Connecticut hurricanes are often downgraded quite a bit before it gets here (assuming it doesn't miss us completely). Hauling out every time there's a threat isn't going to work for us financially. We're going to have to look at all of the forecasts, take our best guess, and often just cross our fingers (after removing the boom, sails, etc.).
So it looks like we could shackle the extra lines to the shackle on the mooring ball, and then tie them to the mast. Makes sense I guess. Are there any other options?
Thanks.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #12 of 16 Old 06-28-2013
snake charmer, cat herder
zeehag's Avatar
my marina neighbor in la cruz lost a line to chafe FROM his garden hose anti-chafe gear--we recommend fire hose--the outside part made of cotton or whateveritis--works best...seen that...use it---besides, garden hose isnt an inch in diameter. firehose will accommodate real lines, not just string.
my slip i chose for furycame season has 4 pilings....is double wide slipand strongly installed cleats i checked for stability. i tie a flat tarp onto my coachhouse securely with 1/2 inch line over the top and i wait for the rain to go away. so far we have been fortunate...only had the overlap of one huge wet ts/huricane...cosme was enormous, at over 600 miles in diameter, which delivered 40 kts of wind and torrential rains to us here along coast of colima and jalisco estados in mexico....mazatlan even had rain from this system...
we are aware this wasnt a true hit--it was a slide by only-- what we will do for roller furling foresail this season is wrap with line opposing the direction of furling wrap....to keep wind out and be ready in case of need to flee.
downeast450 likes this.
formosa 41, cruising tropics
zeehag is offline
post #13 of 16 Old 06-28-2013
+ 1 on firehose. A boat neighbor gave me a coil to cut up in Irene and it seems to protect from chafe without building up heat from friction.
I also have these Shock Absorber style snubbers that I bought a number of years ago, that I can no longer find. But they are fantastic. They almost look like an auto absorber.
My Marina and others nearby took a pretty hard hit by Sandy. I stayed in the water and survived, but that was as much luck as anything. ( though, I did tie up very well and took everything down ( boom included) and removed everything of value from the boat,
Most of the damaged boats were those that were lifted off their jackstands by the surge and landed in piles as the tide receded. Most of the docks in my section were destroyed, including part of mine. ( I had to crawl out on the remaining planks to get to the boat) .
The Docks and poles are all new now and the poles are 3X higher than they were. As a result of that new height, just about everything on land would be under at least 10' of water before docks floated off the poles. Given that, I feel safer in the water now, and would stay in again.
tempest is online now
post #14 of 16 Old 06-28-2013
My hurricane plan is to park it in a field 40 miles inland.
One of my criteria for my boat was trailer launchable. I ended up with a Cape Dory 25. The Bristol 24 has 5" more draft and an extra ton of weight that pushed it beyond the limits of my tow vehicle. You can probably pull it off with the right trailer at the right ramp with the right truck. It will probably take you a while to find the right launching trailer for that boat, but it would pay for itself in a few years of launching, hauling, and storage fees.
Have any friends/family with a big pickup? If not, do you have a United Rental or Hertz equipment rental nearby? :-)
KarlP is offline
post #15 of 16 Old 06-29-2013
I like the fact that the swivel on your mooring is on top. Attach your main pennant and extra pennants to that swivel.
I rode one out on a mooring that had the pennant attached below the ball. To be "safe" I added to additional pennants, same attach point. I was in a tidal river. With the currents, wind, and waves the boat made many trips around the mooring during the storm. One of the extra pennants chaffed through after getting wrapped around the chain, and working with the sea state.
My first choice is to haul. Some of the boat yard's in my area will only haul if they have time to step the mast (which is unlikely unless you haul many days in advance). The are worried about jack stand domino's.
We've weathered a few, including a direct hit with Hurricane Bob on moorings. Strip everything, extra chaffing, get to the most secure place with the least fetch you can find and cross your fingers. Think minimum windage, no sails, no dodgers, put life rings below, etc. Connect your halyards to strong points on deck to help support the mast if the standing rigging gets compromised. Remove the anchor if it can interfere in
any way with the mooring lines and chafe them.
I watched hurricane Bob from the shore on a small harbor with minimum fetch. Horizontal spray from the sea (not rain) was like a car wash from the surface up to about 20 feet in a very protected harbor. Sailboats would lay over until the spreaders touched. Very convincing, don't stay on the boat if you have a choice, secure and get to a safe place.
capecodda is online now
post #16 of 16 Old 06-29-2013
manatee's Avatar
In the immortal words of Arthur, king of the Britons:
'RUN AWAY!'
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
Rescued at Sea - Are You Prepared? smackdaddy General Discussion (sailing related) 401 02-23-2014 11:46 PM
the inevitable slow death of sailing journalism - does it matter dylanwinter1 General Discussion (sailing related) 70 03-08-2012 11:40 AM
The importance of being prepared billyruffn General Discussion (sailing related) 3 07-25-2009 12:54 PM
What is SeaTow prepared to do? davidpm General Discussion (sailing related) 12 10-23-2008 07:55 AM
