Motor mount jammed. - SailNet Community
post #1 of 1 Old 07-02-2013 Thread Starter
Motor mount jammed.
Hello, I just purchased an O'Day 20. The motor mount I (Garelick?) use for my 4 HP Mercury is stuck in the down position. I am sure it it because of lack of use and wonder if I should attempt to unscrew the two bolts that hold the bracket and springs in place. Is there a lot of spring in those two springs and will I be able to re-assemble the bracket once I get it apart? Thanks, Mark.
marksniat is offline
Sealing a motor mount Robbiebobbie Gear & Maintenance 1 05-19-2010 01:12 PM
i need to add a motor mount...how hard is it? mountforever Gear & Maintenance 6 07-09-2009 12:10 PM
motor mount help hubbardsw Gear & Maintenance 1 11-12-2007 09:07 AM
Motor mount replacement? bread316 Gear & Maintenance 4 11-07-2006 01:17 AM
outboard Motor Mount reid5009 Gear & Maintenance 3 04-12-2003 08:29 PM
