Easy only if you know the answer - SailNet Community
post #1 of 9 Old 07-07-2013 Thread Starter
Have a go and DIY .....
I have over the years worked on Hundreds of boats and most have a wooden plaque .
I still do not know what it all means.
Even though I have worked for some large boat builders I have never seen the sign fitted.
I guess there one of the last items fitted before they are sold...
I am sure the bottom line refures to the length .
But what does the top line relate to ??
And what does
O.N. Mean ?
PAGE 11
macwester26 is offline
post #2 of 9 Old 07-07-2013
Re: Easy only if you know the answer
And what does
O.N. Mean ?
PAGE 11
The top line looks like a call signal ON 309561
The second line is the tonnage (not the displacement)
RT (register ton) also abbreviated GRT
One register ton = 100 cubic feet
You cant fit this until the boat have been measured and registered.
In Norway this number (and tonnage if measured) have to be permanently marked on the boat/ship
knuterikt is offline
post #3 of 9 Old 07-07-2013
MarioG's Avatar
Top number looks like a documentation number. My U.S. documentation number is also 6 digits.
Endeavour E-32 "Samara"
I am the Capt of my ship but sometimes I think I had more fun just being the cabin boy.
MarioG is offline
post #4 of 9 Old 07-07-2013
marcusc130's Avatar
Coast Guard documented boats are required to display their document number like that. I've never seen the tonnage on it though.
marcusc130 is offline
post #5 of 9 Old 07-07-2013
ebs001's Avatar
O.N. Official number This is the boats registration number. In the US it's the documentation number.
R.T. (In Canada this should be N.R.T.) Registered tonnage
In Canada, both the official number and register tonnage shown on the Certificate of Registry must be clearly marked and permanently fixed to the hull. In the US this is probably the requirement for documented vessels.
ebs001 is offline
post #6 of 9 Old 07-07-2013
travlin-easy's Avatar
Top number is manufacturers registration number the bottom number is the tonnage.
Gary
travlin-easy is offline
post #7 of 9 Old 07-07-2013
ebs001's Avatar
Gary
No Gary it definitely is not the manufacture's number. It's the official registration number of that boat specific to that particular boat or registered name.
ebs001 is offline
post #8 of 9 Old 07-07-2013
Master Mariner
capta's Avatar
I agree with those above; the top number is the "official" number of registration, which is why you wouldn't see it installed at the factory. It is probably installed by the seller (broker or agent) after the paper work for registration is done. and the vessel then has an official number.
The second must be tonnage, as suggested above, as registered tonnage, be it net or gross, depending on the country of initial registration.
US boats have only the official number on the plate and by law that plate must be permanently attached (fiber glassed on or welded in the case of steel), not screwed on.
This number remains with the boat and does not change with ownership.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #9 of 9 Old 07-07-2013 Thread Starter
Many thanks for all the replies
Here is the vessel the plate is on.
Macwester 26 archive details - Yachtsnet Ltd. online UK yacht brokers - yacht brokerage and boat sales
I am working on a westerley Griffon at the moment I will try and rember and take a picture of that plate as well..
I did think the bottom number could be the length of the vessel...
Last year i was working on a oldish crusier that was 45 foot long it also has a plate. set out in the same format....
Here again is the same vessel with another tpe of plate see image 4 or 5
http://macwester.wordpress.com/macwester-26/
A Conundrum, without an Answer Jasper Windvane General Discussion (sailing related) 50 11-17-2009 09:15 PM
