Replacing propellor in the water? - SailNet Community
 2Likes
post #1 of 31 Old 07-08-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
My boat should finally be repaired this week, and will hopefully splash before the weekend. I would love to add a Campbel Sailor prop, but the repair bill is currently a huge question mark and I can't exceed my budget. If it comes in under budget (which is possible), then I could justify the expense. Of course, I won't know all of this until the boat is back in the water. So, how hard is it to swap a prop while the boat is in the water?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #2 of 31 Old 07-08-2013
I don't discuss my member
Fstbttms's Avatar
Re: Replacing propellor in the water?
Typically it is fairly easy, providing you have the right tools. A prop puller, for instance.
Fstbttms is offline
post #3 of 31 Old 07-08-2013
celenoglu's Avatar
The only difference between being on the hard and in the sea is you have to use a line to tie the prop to the boat. After extraction the prop will be too heavy to handle and most probably fall to the sea bed and get lost.
celenoglu is online now
post #4 of 31 Old 07-08-2013
Fstbttms's Avatar
Originally Posted by celenoglu View Post
After extraction the prop will be too heavy to handle...
On a 31-foot sailboat? I don't think so.
Fstbttms is offline
post #5 of 31 Old 07-08-2013
SchockT's Avatar
If you have the gear and tools to do the job under water yourself, then wait and do it later. If you will have to pay a diver to do it, you are just adding to the cost of the prop. If that is the case the most cost effective thing would be to replace it while the boat is out of the water.
kd3pc likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #6 of 31 Old 07-08-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Thanks guys, that's what I was afraid would be your response! It was worth a try, though.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #7 of 31 Old 07-08-2013
Over Hill Sailing Club
smurphny's Avatar
There is no reason you could not do this in stages with a mask if you have a prop puller. Have some extra nuts and key stock ready in case you manage to drop one. Put them in a pocket you can easily access. Tie everything up to the rails so you can't lose anything: wrenches, puller, hammer, pliers, prop. Hang new prop with enough slack to re-install so you can easily get it from in the water. Loosen/remove nuts (see if prop wants to come off easily by tapping on SIDE of prop), set prop puller, tighten it to remove prop. (I'd just leave the key in place if it looked ok.) Check shaft for corrosion or electrolysis on taper, clean up with an abrasive pad. Install new prop, tighten nuts, put in cotter pin. I'd experiment with some kind of weight to keep you down just enough so you're not fighting buoyancy. I'd also tie the tools to the shaft to keep them within easy reach. It's easy to do this kind of stuff if you just break it into 1 breath stages. Be mindful of hyperventilation. No SCUBA gear required.
Visibility is important. You really can't accomplish much if visibility isn't around 5' or so.
smurphny is offline
post #8 of 31 Old 07-08-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
The one thing you cannot do when installing the prop while the boat is in the water is properly lap the propeller and shaft so that you get a good mate between the shaft and prop. Check out Mainesail's video tutorial on this here......Lap Fitting A Propeller To A Shaft Photo Gallery by Compass Marine at pbase.com
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #9 of 31 Old 07-08-2013
Fstbttms's Avatar
Originally Posted by smurphny View Post
There is no reason you could not do this in stages with a mask if you have a prop puller. No SCUBA gear required.
Having done many dozens of prop R&Rs underwater, I can't say that doing it without air would be much fun.
And this simply isn't the case.
Fstbttms is offline
post #10 of 31 Old 07-08-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
My visibility is likely to be 2-3', if I'm lucky.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Replacing Chainplates on the Water Controlled Jibe General Discussion (sailing related) 14 05-01-2012 02:51 PM
Replacing water heater FEIERABEND Gear & Maintenance 2 09-01-2010 05:10 PM
Replacing prop while in the water theredboat Gear & Maintenance 8 06-23-2010 03:49 PM
Replacing water pump impeller tip Gear & Maintenance 8 04-06-2010 02:03 PM
Replacing water water intake screens AdamLein Gear & Maintenance 0 06-25-2009 12:09 PM
