Do you use dinghy lights? - Page 3 - SailNet Community
 53Likes
post #21 of 135 Old 07-08-2013
chef2sail's Avatar
Re: Do you use dinghy lights?
Originally Posted by fryewe View Post
Don't use them on the dink because I haven't been dinking after dark in a while but I got these for the Dovekie. From Attwood.
Attachment 14830
Attachment 14831
Exactly what we have.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #22 of 135 Old 07-08-2013
snake charmer, cat herder
zeehag's Avatar
i used to use em, then i left usa and sd bay, looked for them last year, but they were rotted out and no longer usable..lol they donot last long for the money ....
is much more pleasant here without the water nazis...
and do keep a good flashlight on ye at all times if gonna be out in a dink at night--
pangas come out of no where and is good if they know where ye are, so they wont hit you.
as for finding ones own boat in darkness--is why gods made unique lighting for you to use as cockpit or anchor lighting so you appear as a different thing to hit than the neighbors....in a crowded anchorage it can make a lot of difference.
formosa 41, cruising tropics
zeehag is offline
post #23 of 135 Old 07-08-2013
chef2sail's Avatar
Originally Posted by Minnewaska View Post
Chef, should have known the likely source of the first flame I predicted at the beginning of my OP.
Seems you missed the description of precisely how lit the harbor is and how the offending boater was limiting, not improving their sight.
I will rest comfortably knowing that 90% of the dinghies around me have no running lights, but yours will be on.
No one flamed you poor sir just disagreed with you that's all.
I have anchored and also been to Edgartown. Not sure what your point is. I agreed with your comment and Captain Tony that you can see at night well without light
Again the purpose is to be seen by others. That's the safe thing to do. And yes mine will be on
I guess I need to ride with a 2,000,000 candlepower flashlight now in that area. Who knows what is speeding around in the dark Least I will spot it before it slices us in half
Parkville, Maryland
Our blog-
post #24 of 135 Old 07-08-2013
Coquina's Avatar
I once forget my light and was doing 15 knots in the dark with my excellent night vision and clearly moonlit water avoiding all obstacles with ease unitl I almost got T-Boned by ANOTHER dinghy going 20 knots + in the dark that did not see me
BTW - airplanes ARE required to have running lights no matter what size. They used to just be the same as a boat, but it wa quickly discovered that fixed lights blend right in to ground lights and starlight, so a flashing light was added and then later on strobes.
chef2sail likes this.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #25 of 135 Old 07-08-2013
TakeFive's Avatar
Could we get some clarification on what the REQUIREMENTS are? Then let's separate that from the best practices that may go over and above the requirements - or choose to not meet them due to night vision or lax enforcement in certain areas.
My understanding is that in US waters, an unmotorized (rowing) dinghy only requires a flashlight, not a 360 degree white light nor a red/green bow light.
A motorized boat dinghy would require red/green bow light plus a 360 degree white light on the stern. Technically, a tricolor red/green/white light like sailboats use would not be sufficient because the white is neither 360 degrees nor at the stern.
Is that correct?
It could be argued that a rowing dinghy needs to be lighted more than a motorized boat, because it's not going to be able to get out of another boat's way. But that's not how I read the regs.
Rick S., Swarthmore, PA
TakeFive is offline
post #26 of 135 Old 07-08-2013
T37Chef's Avatar
I meant that I don't use running lights, which seemed to cause some yahoo to light me up, like a felon from a police helicopter with their spot light.
Ok, I think I got it now...you dont use running lights, not even a 360 white light on your motorized dingy at night but you are pissed that someone lite you up with their spot light?
Shawn
T37Chef is offline
The Following User Says Thank You to T37Chef For This Useful Post:
DJR351 (07-08-2013)
post #27 of 135 Old 07-08-2013
fryewe's Avatar
Rulz is rulz so you have to show a light (or lights). Sometimes it may make sense not to show a light - a well lit anchorage or perhaps in a remote anchorage where you are enjoying the moon - but legal it is not.
If you choose not to show lights in the wrong place you may find yourself starting a new thread about legalizing drugs after you're hassled by (fill in the agency) that uses their FLIR or night vision to spot you and wonder if your lights are out because you are hauling contraband.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
The Following User Says Thank You to fryewe For This Useful Post:
DJR351 (07-08-2013)
post #28 of 135 Old 07-08-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
I confess we do not use lights when rowing although yes we do carry a torch but always carry (lights that is) when motoring. I'm afraid that under power too much happens too quickly not to have lights.
(calrification ... if rowing across a channel or in open water I'd have lights even when rowing but for shore to mooring not so.)
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #29 of 135 Old 07-08-2013
travlin-easy's Avatar
Last time I checked, running lights were required for all vessels, powered, sail or rowed. You may want to take a look at
If you want specifics for each state, especially Florida, try rowing through Boot Key Harbor in January at night with no lights at all. Someone in a uniform will politely explain the law to you, chapter and verse, while he or she writes you a citation that will really piss you off. Same holds true with anchor lights. There were a lot of unhappy campers that thought because they were on a mooring ball they didn't need anchor lights - WRONG! Yep, they were cited as well.
Good luck on staying alive very long while running that dink at night with no lights.
Gary
travlin-easy is offline
post #30 of 135 Old 07-08-2013 Thread Starter
I just glanced around the dinghy dock. There are exactly 37 dinghies. I see running lights of any kind on 4.
Jeanneau 54DS
Minnewaska is offline
LED lights chucklesR Electrical Systems 15 06-15-2013 09:45 PM
Dinghy lights - NH Marine Patrol Summons ereuter General Discussion (sailing related) 27 08-31-2011 10:13 AM
Identification Lights & Nav Lights on Sailing Vessels Boasun General Discussion (sailing related) 10 02-13-2009 09:42 AM
Nav Lights for inflatable dinghy's...WTH!!!! T37Chef General Discussion (sailing related) 31 07-15-2008 02:54 PM
