Need Opinion: Chart plotter, north up or course up? - Page 2 - SailNet Community
 16Likes
post #11 of 87 Old 07-09-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Re: Need Opinion: Chart plotter, north up or course up?
Originally Posted by killarney_sailor View Post
Interesting that people say they go north up because of paper charts. From Scouts to university in geography I always oriented the map/chart to the course I wanted to follow rather than to north. Heck the m/c has true north at the top,not even magnetic.
On the boats generally have course up except in tight corners where I want the land features to stay in one place even I'd the course is changing frequently.
Exactly! After a few years in the military and doing a fair amount of land nav the "map" was always oriented to course up. Then the transition to boating the RYA beat into my head that "charts" need to be oriented North up. Now I have a new chart plotter that gives me the option and with a mixed experienced crew.
kellysails is offline
post #12 of 87 Old 07-09-2013
first sailed january 2008
northoceanbeach's Avatar
North up. I find it easier to follow.
northoceanbeach is offline
post #13 of 87 Old 07-09-2013
Originally Posted by kellysails View Post
I think heading is the direction the boat is pointing and course is the actual path the boat is taking. This takes into account set/run effects of the current/wind.
Different vendors might have different definitions..
This is from the manual of my Furuno NN3D MFD8
Description of orientation modes
Head-up: Displays the chart with the current compass heading of your vessel at the top of the screen. The heading data from a compass is required. When the heading changes, the boat icon remains fixed, and the chart picture rotates according to heading.
North-up: North is at the top of the screen. When your heading changes, the boat icon moves according to heading. This mode is for long-range navigation.
Course-up: The chart picture is stabilized, and shown with your current course (overground) at the top of the screen. The boat icon moves with the heading. If you select a new course, the picture resets to display the new course at the top of the screen.
I might be wrong - but the "If you select a new course" statement above indicate that they are talking about "selecting course as selecting new way point"
I switch between North up and heading up depending on what I'm doing.
For inshore navigation I prefer HU, for orienting and planning I switch to NU.
I know the difference between COG and heading.
My plotter also have a heading line and a COG/SOG predictor (that is independent of the orientation mode.
knuterikt is offline
post #14 of 87 Old 07-09-2013
bljones's Avatar
North up. it is a chart plotter, not a TomTom, so it should be chart oriented as an honest- to-neptune paper chart is oriented. Orienting to course risks spatial disorientation as your compass (you still use a compass, right?) and chart differentiate wildly, especially after dark.
It's 5 o'clock somewhere:
bljones is offline
post #15 of 87 Old 07-09-2013
The most female moderator
Donna_F's Avatar
Dock
I'm not sure that I understand your example. I don't turn my paper chart so that it's always oriented north even when my boat is not. I must be missing something.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #16 of 87 Old 07-09-2013
bljones's Avatar
Charts are north oriented., ie north is top of page.
Nav stations are designed to fit charts with north up orientation.
ergo, all plotting is done with north up.
looking down on the chart laid out on the nav with the course marked (you do use a paper chart back up, right?), then looking at the plotter, whihc is course oriented will cause a momentary unnecessary spatial disorientation.
Which is compounded by boat manufacturers insisting on installing nav stations whihc face the stern, not the bow.
bljones is offline
post #17 of 87 Old 07-09-2013
Donna_F's Avatar
Dock
North up in relation to me. Got it.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #18 of 87 Old 07-09-2013
chef2sail's Avatar
True the paper chart is printed with orientation to the north. That makes sense though because that is the only thing that is a standardization to. It would not be possible to print charts in a head up orientation. That alone is not reason to create everything north on the boat. In addition charts can be rotated and moved.
Our nav station faces forward, the chart table is large enough to rotate the chart 360 degrees. If my bow is facing E and I intend on traveling that way I orient my paper chart that way at the nav station as well as in the cockpit.
If my bow is facing E and there are rocks in front of me visually, I don't want my paper chart facing north so they are 90 degrees to the right of me when I look at it, I want to rotate the chart so they are ahead of me. When I glance down at the chart and there is a river to the left, and I look up the river is to the left. No room for error or need for computation. That's why I have the CP in a head up orientation.
While I can make that shift if I can keep things in a north orientation many newer people or inexperienced cannot easily I have found. They need to confirm visually what they have looked down at on a chart and then look up again to get their bearings..
However all this said, there is no ultimate CORRECT way to do this. You should do whatever makes you comfortable as well as so the rest of your crew can understand also if necessary.
Makes no difference what orientation you keep, as long as you can read your position safely
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #19 of 87 Old 07-09-2013
poopdeckpappy's Avatar
Yes, agreed
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
The Following User Says Thank You to poopdeckpappy For This Useful Post:
DJR351 (07-10-2013)
post #20 of 87 Old 07-09-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
All sorts of interesting opinions here, thanks! It's a sailnet trademark above all else.
I may give course up another try on my plotter that sits in front of the wheel in the cockpit. I can see that in rough weather it could be quite disconcerting though.
Laptop as a Chart Plotter daddyhobbit Electronics 38 03-10-2012 03:15 PM
chart plotter badsanta Gear & Maintenance 3 05-07-2009 12:00 PM
Chart plotter badsanta Gear & Maintenance 5 11-19-2008 10:52 PM
Electronic Chart Plotter SledDog Gear & Maintenance 5 08-23-2006 08:56 PM
Chart Plotter Installation rpowell Gear & Maintenance 3 12-31-2001 07:29 AM
