Trailering Catalina 22 - SailNet Community
post #1 of 6 Old 07-18-2004 Thread Starter
Hey,
Thinking of a Catalina 22 w/swing keel. But have to keep it on land, storage near the water....so I would just need to move it down the ramp and back to the dry storage.
I drive a 1994 Toyota Pickup...not the Tundra or such, and not a V6.....the basic little Toyota P/U that they no longer make.
The manual says it can tow up to 3500#, but I wonder about its ability to pull 2600# of boat and trailer uphill from a standing start.
Anyone have expierience?
THX
garrettav8or is offline
post #2 of 6 Old 07-18-2004
Sasha_V's Avatar
Older Toyota commercial vehicles (Utes and vans) are famous/infamous for having a first gear seamingly designed for towing fully laden semi-trailers out of bogs.
Provided your engine is in reasonable condition and you have adequate traction, first gear WILL get you there in a Toyota. Just take your time and don''t be afraid to keep the revs up at 4k if you need to.
Sasha
Sasha_V is offline
post #3 of 6 Old 07-18-2004
I had a Catalina 22 Swing Keel a while back. The trailer had an extendable tongue, because you floated the boat on and the trailer was really under water. The tongue extension was a good 10'' in length. I mention this because some of the launch ramps fell off quickly and had a deep ridge to pull the trailer over. The extension kept you up in the dry part of most ramps. I had a small Dodge Car with a 318 V-8 automatic, there were times it would really strain, sometimes just spin tires a little, but eventually would get the boat up and out of the water. If you can control wheel spin, I don''t think you''ll have a problem.
boatbum is offline
post #4 of 6 Old 07-18-2004
Let me add that the extention is <u>very</u> desirable for launching the C22. Even my full sized truck was buried very deep in water w/out it.
JeffC_ is offline
post #5 of 6 Old 07-18-2004
Sand bag the bed over the rear axle for max traction?
JeffC_ is offline
post #6 of 6 Old 07-21-2004
I''m towng a C-22 with a ''94 Pathfinder, rear wheel drive, standard, 150 hp V-6, tow-rated for 3500# and no problems. I use the gears to handle hills both up and down, and as an earlier posting says, keep your rpm up. Lower the rolling resistance by inflating your trailer tires to 50 or 55 psi so they don''t flex and overheat and cook a bearing. Balance your boat fore and aft and side to side to prevent whipping: 200# on the tongue, and move the o/b belowdecks in the middle. My personal experience has been quite positive, I presume your machine has a transmission cooler, you''d need that.
maxcontax is offline
catalina 30 Jemac Boat Review and Purchase Forum 2 07-15-2002 01:24 PM
Catalina 310 greatwhiteway Boat Review and Purchase Forum 10 07-02-2002 07:42 AM
Catalina 27 or 30 xavier6162 General Discussion (sailing related) 0 02-13-2002 11:30 AM
PHRF club racing a Catalina 27? Nawlinsguy Racing 2 12-09-2001 11:40 AM
A new catalina 36? paul-e Boat Review and Purchase Forum 32 09-21-2001 06:26 PM
