Measuring a foresail - SailNet Community
 1Likes
  • 1 Post By bobperry
post #1 of 5 Old 07-10-2013 Thread Starter
Gregrosine's Avatar
How do you measure a genoa in terms of %?
Gregrosine is offline
post #2 of 5 Old 07-10-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Measuring a foresail
IIRC, it's the % the foot measurement passes the mast. If yer tack to mast is 11 feet and yer sail foot is 16 feet, yer % would be foot/"j" (?); or 145%
HTH,
Paul
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #3 of 5 Old 07-10-2013
FSMike's Avatar
I always thought it was the percentage by which sail area exceeded the area of the foretriangle (top of the forestay to bottom of forestay to bottom of mast to top of forestay).
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #4 of 5 Old 07-10-2013
grumpy old man
No Mike:
The percentage is a percentage of your "J" measurement measured on the "LP" (luff perpendicular). Your "J" measurement is taken from the front side of you mast to the tack fitting at the stem.
So, "J" is 100%.
A 130% genny will have a luff perpendicular (LP) of 130% of "J"
You can measure your luff perpendicular by taking a line from your clew and run it straight to the luff so it makes a 90 degree angle (perpendicular) at the luff.
jimgo likes this.
Bob's Blog ....
bobperry is offline
post #5 of 5 Old 07-10-2013
FSMike's Avatar
Aha. Thanks Bob.
Sending you a pm.
Sail Fast Live Slow
FSMike is offline
Foresail slab reefing Barquito Gear & Maintenance 25 02-20-2012 05:58 PM
Foresail downhaul binding Barquito Gear & Maintenance 6 12-07-2011 10:35 AM
Removing foresail-stowing for winter SpeedAgent Gear & Maintenance 23 12-08-2008 08:40 PM
foresail position? blueranger Learning to Sail 4 07-11-2006 10:48 AM
Multiple foresail furlers Jonathan316 Learning to Sail 4 08-09-2004 12:14 PM
