Can I use a differently shaped mast? - SailNet Community
 3Likes
post #1 of 24 Old 07-10-2013 Thread Starter
Question Can I use a differently shaped mast?
I'm trying to find a new aluminum mast for my small sailboat (13' trimaran of unknown manufacturer believed to be part of a limited number made in Florida in the 1960s).
The old mast is broken. It was 18'8" and 2 3/4" x 1 5/8".
In particular I'm looking at a mast I found on CraigsList that is 19'2" and 2 3/8" x 2 5/8".
I'm hoping I can cut 6" off it and use it. It has spreaders, shrouds, cleats that I will either use or replace (either from my old mast or new).
I had planned on replacing the step anyway (I want to use a hinged step).
Is there any reason I should not use the CraigsList mast? Anything I should find out before I buy it? (It is 250 miles away.)
MikeTri is offline
post #2 of 24 Old 07-10-2013
Bristol 45.5 - AiniA
Re: Can I use a differently shaped mast?
Don't see a problem with your plan.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
The Following User Says Thank You to killarney_sailor For This Useful Post:
MikeTri (07-11-2013)
post #3 of 24 Old 07-10-2013
grumpy old man
Mike:
That should work fine. The new mast is a bit bigger athwartships but that just means it will be heavier and a bit stiffer. Can't imagine you could tell the difference. I thoink the small difference in the fore and aft dims will be offset by the extra material that comes with the bigger athwarstships dim.
Bob's Blog ....
bobperry is offline
The Following User Says Thank You to bobperry For This Useful Post:
post #4 of 24 Old 07-10-2013
Mike,
The strength of a section lies in the location of material, not (necessarily) the weight. Case in point, my company supplies, among other things, two sizes of aluminum rafters. A 6" capable of spanning 18 feet and a 9" with a 24' span rating. Both with the same amount of aluminum per foot. That said, I'd bet these section are virtually identical, weight wise. Long story to say, "You're fine. You wouldn't notice the difference even if there was one."
DonScribner is offline
The Following User Says Thank You to DonScribner For This Useful Post:
post #5 of 24 Old 07-10-2013
krisscross's Avatar
I would not cut the mast at all. It will give you more flexibility with the sails - now and in the future (you can carry more sail, or carry the current sails higher for better visibility. It does change the balance of your rig a little but not enough to make a difference IMO.
capta and jimgo like this.
Plato
krisscross is offline
The Following User Says Thank You to krisscross For This Useful Post:
post #6 of 24 Old 07-10-2013
HANUMAN
RobGallagher's Avatar
Ummmm... A legend just gave you advice, If it were me, I just might print that out and frame it
(I also like krisscross' suggestion, unless you are using the original rigging.)
miatapaul likes this.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #7 of 24 Old 07-10-2013
grumpy old man
No, you can't use that other mast.
Your boat will explode!
Bob's Blog ....
bobperry is offline
post #8 of 24 Old 07-10-2013
HANUMAN
I might just frame that one myself.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
post #9 of 24 Old 07-11-2013
overbored's Avatar
why do you need a mast with spreaders on a 18' tri mast. hobie 16 mast is 26 ' and no spreaders. find a hobie 14 mast or the whole rig and sails
"GOLD RUSH" PRINDLE 16
overbored is offline
post #10 of 24 Old 07-11-2013 Thread Starter
Question Re: Can I use a differently shaped mast?
OK, so I can use this new mast. Now how do I connect it to the boat?
The old mast was open at the bottom and fit onto a step (like Dwyer DH2111) mounted to the boat.
The new mast seems to have step fastened in the bottom with 3 tenons (kind of like Dwyer DH213 except the tenon split into 3 squares).
Also the old mast had a slight bevel/taper on the bottom. So it stood maybe 5 degrees off vertical. Is that standard for all masts or do I need to recreate it or should I not worry about it?
I was thinking I would cut off the bottom few inches of the new mast (including the step that's mounted in it) and buy a new step that comes closer to the new shape. The closest I find seems to be the right shape but designed for an eighth inch smaller mast in both dimensions. Would that work OK?
Alternatively (and especially if I don't want to cut the mast at all -- as krisscross suggests), what do I mount to my boat to receive the tenon?
Finally, any problem with using a hinged step? I'm hoping this will make it safer to put the mast up (I dropped it once -- luckily my kids weren't around) and easier to bring it down (meaning I won't be as tempted to trailer it for short distances with the mast up -- what got the mast broken in the first place).
MikeTri is offline
What should I have done differently? Brickyard Cove SPC General Discussion (sailing related) 11 02-28-2013 09:02 PM
What would you have done differently cbtucker Cruising & Liveaboard Forum 9 07-02-2011 08:32 PM
Autopilot: S shaped course ichorniy General Discussion (sailing related) 9 07-10-2010 04:04 PM
Why do we refer to wind and water movement differently? nolatom General Discussion (sailing related) 10 04-29-2010 12:09 AM
Sailing: Sean seas it differently (icWales) NewsReader News Feeds 0 07-16-2006 06:19 AM
