Do you have an outboard for back up propulsion? - Page 2 - SailNet Community
 13Likes
post #11 of 25 Old 07-11-2013 Thread Starter
One of None
deniseO30's Avatar
Re: Do you have an outboard for back up propulsion?
Originally Posted by night0wl View Post
This reminds me of a member in our sailing club. They have a *BIG* full keeled Morgan. Doesn't back worth a damn. However, they do have a whole mechanical platform on the aft deck to lower their dinghy. Come time to reverse, the Admiral would get on the dinghy, and skipper would lower it just to the point where the shaft of the outboard was under water....then he'd back her up.
The dinghy acted like a stern thruster to straighten out the prop-walk and wander in reverse
Was a great spectacle in the marina, HA!
Eh? Am I sensing a little "holier then thou" attitude?
Maybe the spectacle is the people spectating!
I don't see how this discussion is about reversing motoring a boat. "doesn't back worth a damn" in your opinion maybe?
"If your calling me or others a fool, then say it! Don't hint, it's petty"
My last project!
deniseO30 is offline
post #12 of 25 Old 07-11-2013
night0wl's Avatar
Its pretty well acknowledged that any full keeled boat does not track in reverse. Personally, I think this is brilliant...sailing ingenuity at its best without throwing money at another piece of technology that is unreliable (thrusters).
S/V Jendai
Beneteau 343
night0wl is offline
post #13 of 25 Old 07-11-2013 Thread Starter
One of None
deniseO30's Avatar
I don't know, If I ever get a chance on a full keel boat I'll find out. Still, this wasn't about motoring in reverse which could be a good discussion on another thread. From all that I know and have seen, and using prop walk to help spin my boat 180 in tight quarters, is actually easy now, it wasn't 5 years ago.
jimgo and Seaduction like this.
My last project!
post #14 of 25 Old 07-11-2013
TakeFive's Avatar
Yeah, it's back up propulsion, not backup propulsion!
deniseO30 and jimgo like this.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
The Following User Says Thank You to TakeFive For This Useful Post:
deniseO30 (07-11-2013)
post #15 of 25 Old 07-11-2013
Tundra Down
downeast450's Avatar
Denise,
At first I wasn't paying attention to your post. I have an Islander-28 with a great little A-4. It is most reliable. An obm doesn't make much sense for my purposes? After mulling over your "proposal" it occurred to me that having an obm that could push the boat if stranded in some remote location might be worth considering. Perhaps if we were leaving for a summer cruise to Newfoundland and wanted a back up motor, would building a removable mount that would hang low enough make sense? Finding the space to store an obm and that mount would be a problem. Probably too big a problem but, being stuck in some fiejord with no engine would be a PITA. If you could lower something down onto the transom and motor away that would be nice. We do have a long shaft, 4 stroke, 7.5 Honda that would probably push the boat at hull speed. Does it make sense to carry something that big as back up? Probably not. It is an interesting idea, thanks.
Carry enough spares for the A-4 instead.
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #16 of 25 Old 07-11-2013 Thread Starter
One of None
deniseO30's Avatar
Sorry for the confusion.. LOL No I did not mean "do you have power to back up"
I'm just thinking if I had transmission problems (more matter of when, not if) rather then cut a trip short and leave my boat for salv... err repairs
My last project!
post #17 of 25 Old 07-11-2013
Hi Denise, Did the PO have an engine on that mount that worked for propulsion? When you say it's too high, do you mean too high for the 9.9 to fit on it and lower? I'm not sure why you'd need cable controls..wouldn't you just lock it and steer with your ships rudder?
I agree I don't know if I'd lug around the heavy 9.9 ..just in case. But a smaller outboard that could serve a dual purpose of engine back-up and dinghy outboard might be worth considering.
In either case, I'm guessing you're worried about the trans. going in the worst possible place like the C&D canal or some other narrow channel. The transom mount would get you going faster: lower, start and go. Hip towing with a dinghy takes a little time to set up. You might want to think about how to get an anchor out quickly, if you can't sail to safety.
I transit a rock lined inlet and two bridges to get in and out of my marina where there's often swift currents running. Only once in many years did my engine stall in the channel ( before I cleaned the fuel tank). But ever since then I've kept a danforth anchor mounted to my stern rail. I managed to sail back to my slip with the genoa, but it was a rare beam wind and two open bridges that allowed me to do that.
tempest is offline
post #18 of 25 Old 07-11-2013
T37Chef's Avatar
Originally Posted by TQA View Post
Do you have a dink with an outboard? If so a 'hip tow' with the dink lashed alongside works.
Even a 2hp egg beater will move a 30 footer along providing there is not much wind.
Although I have actually never done it, I have watched the Tow Boat US bring a few boats in using this technique...maybe I should try it for myself before I need to
Shawn
T37Chef is offline
post #19 of 25 Old 07-11-2013 Thread Starter
One of None
deniseO30's Avatar
The mount is too high for any outboard. and it's not even reinforced inside the transom for it. It does make a good lpg tank mount LOL I've hip towed a boat with my club dinghy and it was slow but did work. The 9.9 I have doesn't even have a tiller handle, guess it could be rigged to run one speed. But lugging that thing is not something I'd want to do. sold my honda 2 hp very short shaft it was though.
My last project!
post #20 of 25 Old 07-11-2013
Asleep at the wheel
jimgo's Avatar
With your boat, you really don't NEED to steer using the tiller handle. The only thing you'd need is the throttle cable. I wonder if you couldn't make a temporary mount that you could put on the stern pulpit for the controls. As others have said, perhaps a structure (stainless steel?) kind of like a ladder that fits over the gunwals (sp?) at the back with a mount for the outboard. No, I wouldn't want to use it on a regular basis, or in really nasty seas, but for where you sail, something like that might work to get you to the nearest marina.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Electric Propulsion. GufShoz Introduce Yourself 5 04-08-2012 06:15 PM
Back ona board with the outboard 71Irwin32 Gear & Maintenance 4 05-18-2010 09:51 PM
Electric propulsion scrumhalf Gear & Maintenance 3 05-01-2008 05:55 PM
Electric Propulsion vardaman77 Gear & Maintenance 5 08-05-2007 07:09 PM
