Do you have an outboard for back up propulsion? - Page 3 - SailNet Community
 13Likes
post #21 of 25 Old 07-11-2013
Re: Do you have an outboard for back up propulsion?
I once lashed a Honda 2hp to the swim ladder on a Catalina 270, ladder was held horizontal by lines, at WOT the boat actually got up to 3 kts. EVENTUALLY. It was very slow to start moving, March, middle of the night, pouring rain and I only had to move 1/4 mile. It was dead still and calm with no current, just cascades of rain and dark.
capttb is offline
post #22 of 25 Old 07-11-2013
You really are funny!!
chrisncate's Avatar
Our little Honda 4s 2hp pushed the boat better than I ever thought it would (A-30). I could make a couple of knots (I dunno, 2-4 maybe?) in a headwind of 15 knots or so (on the Bay, including wakes and chop).
It was more than enough for a backup (of which we had none, other than sails). Some sort of side mounted swing arm set up ala' Yves Gelinas could work? It'd be easy to design for such a light motor. I could design one for you if you were interested.
chrisncate is offline
post #23 of 25 Old 07-11-2013 Thread Starter
One of None
deniseO30's Avatar
Well it's something to think on Jim. It's a mariner long shaft too. It's heavy but not impossibly so. I, with help, certainly could move the mount lower and beef up the transom on the inside.
My last project!
deniseO30 is offline
post #24 of 25 Old 07-12-2013
chucklesR's Avatar
We hip towed our Gemini using a 2.5hp a couple times (had fuel pump issues). It worked in flat water with no wind but didn't do diddly to even hold the bow into the wind during a blow. Gemini's weigh it at 10k pounds or less and have very little wetted surface but lots of windage.
I've got a 5hp outboard for the dinghy - I don't think it would do diddly squat to push my 20k pound Irwin around.
One thing I will say, light outboards on dinghies are useless to tow - you need to do a hip tow/push to control it.
chucklesR is offline
post #25 of 25 Old 07-12-2013
snake charmer, cat herder
zeehag's Avatar
on mine, i use a unique concept---
sails.
other wise i has oars or kayak paddles which do n0t propel a formosa 41.....
nor do i worry about returning to the same place, or to a dock, as i go away when i leave....i can vary my next location for the needs of my boat.
formosa 41, cruising tropics
zeehag is offline
Electric Propulsion. GufShoz Introduce Yourself 5 04-08-2012 06:15 PM
Back ona board with the outboard 71Irwin32 Gear & Maintenance 4 05-18-2010 09:51 PM
Electric propulsion scrumhalf Gear & Maintenance 3 05-01-2008 05:55 PM
Electric Propulsion vardaman77 Gear & Maintenance 5 08-05-2007 07:09 PM
