Replace cotter pins with welding rod - Page 2 - SailNet Community
 7Likes
post #11 of 35 Old 07-11-2013
Over Hill Sailing Club
smurphny's Avatar
Re: Replace cotter pins with welding rod
Originally Posted by deniseO30 View Post
So it's using wire basically. I read it too, I'll stay with spiral rings.
Yep. You could accomplish the same thing with some #10 copper:-) I think rings are probably a better idea than cotter pins which require pliers every time you need to adjust a shroud/stay.
smurphny is offline
post #12 of 35 Old 07-11-2013
Senior Moment Member
SloopJonB's Avatar
I like rings too, basically because of no sharp points, but they CAN unwind on their own. They can also get bent which makes them a bitch to remove.
This welding rod idea is interesting - eliminates the need for rigging tape with its downsides. A small roll on board means you're never out of the right size pin as well. It's essentially a variation on safety wiring bolts.
P.S. If you follow Rod Stephens advice you don't need to replace cotters every time you remove them. Clip them short - just enough length to get a decent end on them, then spread them about ten degrees or so. They don't need to be wrapped back on themselves to stay in place. The small spread on a short end will keep them just as secure and squeezing them with pliers to remove them flattens the end enough to be reusable.
SloopJonB is offline
post #13 of 35 Old 07-11-2013
Señor Member
PorFin's Avatar
The only thing I'm scratching my head over is what about fine tuning adjustments?
So, you've got the rod bent at exactly the right spots but realize you need to tighten up the shroud a couple of turns -- now you've got to re-bend the rod (or replace the whole section)
Maybe I'm over-thinking it...
________
'85 BYB Vagabond 39
PorFin is offline
post #14 of 35 Old 07-11-2013
Retired Naval Architect
I've done this for the last 25,000 odd miles and it has worked great. There is some further discussion of it here with a photo of Rod Stephens and details of his cotter pin recommendations.
Turnbuckle protection - SailboatOwners.com
I've had cotter rings snag on jib sheets and get opened up into finger snags. Never a problem with the welding rod. I also like the looks of the rod better than the rings.
There is no tape on my boat except the upper headstay fitting which a boat yard worker put on and I didn't notice.
Roger Long is offline
post #15 of 35 Old 07-11-2013
Omatako's Avatar
Originally Posted by aa3jy View Post
One interesting point that was made in the article is that the removal of welding wire is easier and faster in case of a de masting..which our vessel experienced..
When a rig comes down I wouldn't want to have to unscrew the bottle screw - you need more tools for that and it takes too long. It would make more sense to take the pin out of the bottom of the bottle screw where it connects to the chain plate. I don't believe welding wire down there is a better idea.
The intention of these pins is to stop the bottle screw from unscrewing itself. The good thing about the wire is that it passes from one cavity to the next so there is no way that the bottle screw can do more than a quarter of a turn because the wire goes tight. If the split pins (sorry I can't call them cotter pins) are a little small they don't achieve the primary objective - the bottle screw can turn past them.
Arthur C. Clarke
Omatako is offline
post #16 of 35 Old 07-11-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
I like the sound of the Silicon Bronze option. I guess I'm showing my age but a bit of ye olde worlde patina sounds like no bad thing.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #17 of 35 Old 07-11-2013
You are. I've taken up a couple of turns on mine with no need to re-bend. I've also re-bent to accommodate a new length very quickly with a pair of needle nose pliers.
post #18 of 35 Old 07-11-2013 Thread Starter
TakeFive's Avatar
Originally Posted by Omatako View Post
...The intention of these pins is to stop the bottle screw from unscrewing itself. The good thing about the wire is that it passes from one cavity to the next so there is no way that the bottle screw can do more than a quarter of a turn because the wire goes tight. If the split pins (sorry I can't call them cotter pins) are a little small they don't achieve the primary objective - the bottle screw can turn past them.
Very good point, and it's a concern with my particular turnbuckles. The typical open turnbuckle has that crossbar at the midpoint, which allows the wire to prevent rotation of the turnbuckle:
But I have the Catalina OEM turnbuckles, which are an unplated bronze inner turnbuckle with no crossbar. I like them because I don't need rigging tape - the SS cover accomplishes that nicely. But without the crossbar, I'd be afraid that a tightly bent wire would allow the turnbuckle to rotate:
So unless I replace my turnbuckles someday, I think I need to stick with the split pins that are used currently.
Rick S., Swarthmore, PA
TakeFive is offline
post #19 of 35 Old 07-11-2013
HANUMAN
RobGallagher's Avatar
My previous boat had the TIG (?) wire in place of cotter pins. It worked great for several years of day sailing and short cruises in inland waters.
For the record, it was purchased in welding sticks or rods, not from a spool. I've never done more than spot welding so I can't comment on the variations of wire.
I have cotter pins at the moment, but will change over to welding wire as I have to change out the pins.
So much easier to make small adjustments and much less work when the rig comes down for the winter.
YMMV
Edit: Got me to thinking.... RIP Tom Rapp of TR Rigging.. you were a nice guy and missed. http://www.legacy.com/obituaries/tim...21#fbLoggedOut
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #20 of 35 Old 07-12-2013
poopdeckpappy's Avatar
Me too
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
No tape turnbuckles and cotter pins Roger Long General Discussion (sailing related) 1 06-10-2013 07:51 AM
Idea for turnbuckle cotter pins davidpm Gear & Maintenance 51 12-11-2009 06:54 PM
Cotter Pins ccriders Gear & Maintenance 9 06-04-2009 12:56 PM
Martec Prop Cotter Pins rperret Gear & Maintenance 13 04-06-2009 09:57 PM
Cotter Pin lsusailing Gear & Maintenance 22 09-06-2008 01:51 AM
