Backing up (or not) - Page 3 - SailNet Community
 15Likes
post #21 of 44 Old 07-16-2013
Barquito
Barquito's Avatar
Re: Backing up (or not)
Make sure your A4 reversing gear is adjusted to give you enough thrust.
Valiant 32
Barquito is offline
post #22 of 44 Old 07-16-2013
Originally Posted by chucklesR View Post
I have a Maxprop so in theory I have no prop wash - in practice I have minimal prop wash.
I have a Maxprop on our Hunter 40. But I'm new to the boat and the prop and don't really understand exactly what a Maxprop does.
What I DO know is that the boat does incredibly well in reverse - with very, very little prop walk. I had to move it to our new slip a few weeks ago (my first time really handling the boat in close quarters). I was extremely nervous - as the boat felt like an aircraft carrier compared to my previous C27.
To make things more difficult, I had to back it in for my shorepower cords to reach the cockpit. And to make things even more difficult, I had wind blowing directly into the slip.
I asked the broker who sold me the boat - a seriously good guy and veteran sailor in the area named Pat - to help me as I didn't want to try it with just the boys aboard. I did just fine backing it out of the slip at the boat yard that re-did my rigging. Piece of cake.
When we got to the new slip, he walked me through what I needed to do - which was come into the fairway pretty tight to our dock (leeward), then right at our slip, turn hard to port to get the bow through the wind and swing the stern to align with the slip - then back down quickly.
I tried this 5-6 times (Pat's a very patient guy) and finally got the stern going into the slip, but I was always too timid with the initial turn which allowed the bow to blow off to starboard. So even though I got good initial alignment with the stern, I always got a little too sideways to reverse in cleanly. Pat made me keep trying. I was able to control the boat in the fairway and keep us away from the hard bits as we kept at it.
Long story short...at my request, Pat finally showed me how. But he warned me that he was already a couple of Manhattans into the evening. Regardless, he did a great job - still getting us a bit sideways as the bow blew off, and crunching my life ring a bit - but we got her in.
It made me feel good to see that it's NEVER that easy - even with tons of experience. And it made me feel REALLY good when he complimented me on my boat handling. I'm feeling a bit more confident for the next try.
davidpm likes this.
smackdaddy is offline
post #23 of 44 Old 07-16-2013
To the OP, You cant surf when there are no waves and you cant sail when there is no wind so why would your try and make your boat do something it physically cant. Learn the characteristics of your boat and always be one step ahead. Tip, forget about your rudder in reverse, the prop has more effect that the rudder, use the prop walk to your advantage.
barefootnavigator is offline
post #24 of 44 Old 07-16-2013
CaptainForce's Avatar
.............................. I have a Maxprop so in theory I have no prop wash - in practice I have minimal prop wash.
I appreciate your wisdom with this statement. It's a benefit of the Maxprop to use the same leading edge of the blade in forward and reverse. So, in theory you would have the same prop walk in reverse as forward. I think that is only the license of salesmanship that promotes the statement of "No prop walk". Of course the prop walk in reverse is accentuated by not having the prop wash over the rudder and that still stands true with the Maxprop in reverse. The Maxprop only has no prop walk in reverse to the degree that there is no prop walk in forward, but, of course, there is prop walk in forward. Final answer, the Maxprop has far less prop walk, but not with "no" prop walk.
I haven't addressed the fact that you used the terrm prop wash. I just figured that was intended to be prop walk for you would never move without prop wash!
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #25 of 44 Old 07-16-2013
Thanks for the explanation Force. After my last post, I looked it up and saw the explanation you just gave for how it works. Pretty cool.
When I'm at the boat this weekend, I'll do the prop-walk test in the slip to see how much push we're getting in reverse.
post #26 of 44 Old 07-16-2013
On my Edel 22' I turn the outboard when in reverse and keep the tiller str8.
I think something disconnects the tiller whenever the Honda is in "R"....I cannot see that connection but I will find it one day.
or perhaps my brain's RAM is overloaded unless it is in "F"
i_amcdn is offline
post #27 of 44 Old 07-16-2013
Bristol 45.5 - AiniA
Smack, I had a Maxprop on my last boat, a Niagara 35 with longish fin keel and big spade rudder. In general there was very little prop walk but I learned that if you wanted some, eg to pull the stern into a dock you could goose it in reverse for just a second or two and you would get a quick jump in the desired direction - you did choose the dock to allow this of course?
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #28 of 44 Old 07-16-2013
Of course not. I have no idea what I'm doing!
I chose my slip purely based on it being among the ones that survived Ike - and was only $260/mo for a 40 footer. BAM!
post #29 of 44 Old 07-16-2013 Thread Starter
davidpm's Avatar
I'm trying to figure out what the boat will do because it is so different from other boats.
In all other boats I have operated I could count on the the prop walk at low speed before the the speed was sufficient to make the rudder work.
This boat has surprised me on some occasions. Instead of prop-walking to port in reverse as would be expected it has moved starboard.
Sometime port sometimes starboard.
It obviously has a cause it it not magic. I'm thinking that the reason is that the prop-walk effect is overwhelmed by the currents effect on the keel and in one case topside windage.
davidpm is offline
post #30 of 44 Old 07-16-2013 Thread Starter
davidpm's Avatar
What adjustment are you referring to?
davidpm is offline
Backing plates micheck General Discussion (sailing related) 7 11-14-2010 01:27 AM
Oak for backing plates? Mandofish Gear & Maintenance 34 04-04-2009 09:06 PM
Backing pvanv1 Gear & Maintenance 5 02-28-2009 03:22 PM
Backing Plates painkiller Gear & Maintenance 29 02-19-2009 02:17 PM
GPO-3 as backing material dgr Gear & Maintenance 4 11-07-2008 03:47 PM
