oil in bilge - SailNet Community
post #1 of 5 Old 07-18-2013 Thread Starter
Could not find the delete options
Last edited by abrahamx; 07-18-2013 at 10:24 AM. Reason: Found another thread on the matter
abrahamx is offline
post #2 of 5 Old 07-18-2013
Re: oil in bilge
I'd start with a shop vac to get as much oil out as possible and then a combination of soap, water, scrubbing, and vacuuming until clean.
I'd insert some snide comment about boarding and the coast guard, but I'll resist
peoples1234 is offline
post #3 of 5 Old 07-18-2013
Retired Naval Architect
Re: oil in bilge
The powder that consists of dried, dormant bacteria that come to life in water and eat the oil work better and faster than you can believe. West Marine usually doesn't carry them in jars but you can buy oil absorbent pads with the bugs inside and either use as is or cut them open and sprinkle the power around which I have found works well.
Roger Long is offline
post #4 of 5 Old 07-18-2013
poopdeckpappy's Avatar
Re: oil in bilge
Auto parts supply houses have a product called Oil Eater, this stuff works great, it's similar to what Mr. Long just posted but in liquid form, little micro-bacs eat the oil then eat themselves.
I helped a friend who blew a line and filled his bilge with oil, I hand pumped (6) 5 gal buckets of nasty a$$ bilge water out of his boat, pour Oil Eater on top, covered them and two days later was able to skim the surface oil off with paper towels, what was left was clean enough to dump back in the bay but, NOT, it went down the toilet in stead
This stuff is safe for our watery environment
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #5 of 5 Old 07-18-2013
Once known as Hartley18
Classic30's Avatar
Dock
Re: oil in bilge
I usually use the 3M pads, but I was persuaded one day by a sales guy who had run out of stock of them to try the "oil eating bacteria" version. It came in a similar pillow format and, I guess the bottom part of it that was actually submerged kind of worked but the rest turned into a slimy-looking mess so I chucked the thing away in the end..
If only I'd seen your post 6 months ago I could have ripped open the bag, scattered the contents and it might have worked fine!! The stuff you learn on Sailnet...
Classic30 is offline
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
Bilge??? Stevyboy MacGregor 2 02-11-2011 10:07 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Oil in bilge Neicy Gear & Maintenance 5 12-07-2005 08:40 AM
