hull reinforcement. - SailNet Community
post #1 of 10 Old 07-18-2013 Thread Starter
rigga1995's Avatar
hull reinforcement.
Hi
I'm thinking of buying a bristol 30 anc was wondering any way i could reinforce the hull.
rigga1995 is offline
post #2 of 10 Old 07-18-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: hull reinforcement.
There is a section in "This Old Boat" by Don Casey on how to reinforce the hull of an older boat by adding stringers and tabbing the bulkheads, along with a vast amount of other information. You might want to consult first with a naval architect/marine surveyor/fiberglass repair specialist on the need/desirability of reinforcing your particular boat. Bristols have a good reputation as well-built and well-designed boats.
jameswilson29 is offline
post #3 of 10 Old 07-19-2013
KNOT KNOWN
Capt.aaron's Avatar
I re-enforced my old hull by glassing in ribs and adding 5 coats of west system outside and coated the bilge with thick bi axial cloth and west system.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #4 of 10 Old 07-19-2013
watsongs's Avatar
Unless you put glass on the outside, those extra coats of epoxy did nothing but add weight. Epoxy by itself isn't a strong medium, it's a glue. It's no different than coating the exterior with five coats of Titebond. The glass/epoxy in the bilge was right, though it's necessary to have a proper bonding surface, otherwise you've just created a male plug....
watsongs is offline
post #5 of 10 Old 07-19-2013
KNOT KNOWN
Capt.aaron's Avatar
Well, I took all the gel coat off the outside and did a big blister job, then came back in with the 5 coats of west with alum. powder for my barrier coat making it very strong as in hard and water tight. That was in 1994 and I haven't had a blister since, it's still very hard. I did a very good job prepping the bilge and added the Bi ax because my center board knocked a crack in the well. That was when I was 200 miles off shore and it caused a nice steady leak. Which I patched with a chop stick and a sock. So I re-enforced that. And the ribs that I glassed in have def. added some strength. All in all boat hull is stronger, and more impervious to knocks and bumps, swell beatings because of the work I've done.
post #6 of 10 Old 07-19-2013
watsongs's Avatar
Good. The aluminum powder added to the epoxy made a composite. Now you've got something useful. Your original post said nothing about the gelcoat removal nor the aluminum, hence the confusion.
watsongs is offline
post #7 of 10 Old 07-21-2013
Originally Posted by rigga1995 View Post
Hi
Just wondering why you feel the need to do that?
seabreeze_97 is offline
post #8 of 10 Old 07-23-2013
CapnChuck's Avatar
The older Bristols had a pretty solid hull, so you might reconsider the additional work and expense to accomplish little. Chuck
Our Blogs
CapnChuck is offline
post #9 of 10 Old 07-23-2013
denverd0n's Avatar
That was my first thought, too. Why? Bristols are well-built boats.
denverd0n is offline
post #10 of 10 Old 07-23-2013
A solid fiberglass hull on an old Bristol that need reinforcment? That's kinda scary.
Buttttt, as posted, Don Casey wrote the book. Lotsa pix and illustrations too!
Good luck!!!
TJC45 is offline
Chainplate reinforcement Tafa Gear & Maintenance 12 01-16-2013 07:38 AM
Rot in hull/deck joint - thoughts on necessity of reinforcement? JeffBurright Gear & Maintenance 8 09-21-2012 03:33 AM
aft end structural reinforcement annascaptain P30 2 06-30-2011 04:08 PM
hull reinforcement with liner xact Gear & Maintenance 19 02-04-2010 06:40 PM
hull reinforcement. Heruka General Discussion (sailing related) 0 10-18-2002 04:40 AM
