There's More Than One Way To Clear A Low Bridge - SailNet Community
 3Likes
post #1 of 11 Old 07-22-2013 Thread Starter
JulieMor's Avatar
I'd say he's done this before...
kellysails likes this.
JulieMor is offline
post #2 of 11 Old 07-22-2013
Kayaker/Dreamer
Resolute_ZS's Avatar
Re: There's More Than One Way To Clear A Low Bridge
Repost, but still a good one.
Resolute_ZS is offline
post #3 of 11 Old 07-22-2013
Asleep at the wheel
jimgo's Avatar
This has been posted here before. It's pretty impressive! Imagine the stress on the rigging.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 11 Old 07-22-2013
The most female moderator
Donna_F's Avatar
Dock
I was told that these are pros. You can pay them to get your boat under the bridge.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is online now
post #5 of 11 Old 07-22-2013
Nah, the boat's built to take it, since the load should be roughly equivalent to those required to induce the same angle of heel under sail... Only difference would be in that it is solely concentrated in this case on the mainmast, rather than possibly being distributed between main and mizzen under sail...
Given the weight of the bags, I would guess there could be a higher degree of compression at the base of the mast, but in theory to load on the shrouds should be no greater...
JonEisberg is offline
post #6 of 11 Old 07-22-2013
You may be thinking of the guys at Indiantown who help boats clear the Port Mayaca RR bridge... This is definitely not them...
I believe Dave on AUSPICIOUS knew the owner, who has sadly since passed away... He was a member of the SSCA, and I believe the first time he employed this trick, was in an effort to run up the ICW from Ft Pierce to attend an SSCA Gam in Melbourne... This vid, however, appears to have been taken at the bridge in Coinjock, NC...
I'm the guy who watched this and took the pictures. I have to say it was a very professionally executed operation. Just the captain and his wife aboard. As they approach the bridge, they release the bags from the base of the mast and execute a slight turn (to port in this example) to start the bags moving off the starboard beam.
As they get closer they ease the sheets that hold the bags to the boat. When the bags touch the water the mast height is 60'.
David is a pretty cool guy. He rigged this as Noel was approaching the eastern US. It worked so well that he figured he could go inside and visit the places he had been missing.
Must See To Believe... - Cruiser Log World Cruising & Sailing Forums
More on David Parrott, the owner of ARATINGA, here:
Remembering David Parrot 1945-2010
post #7 of 11 Old 07-22-2013
grumpy old man
The load is just Rm=heeling mom.
The load at the masthead would be similar to reaching hard with a spin up but far less dynamic. I don't see a problem. Not that I would have the balls to try it.
Very handsome yacht. What is it?
miatapaul and jimgo like this.
Bob's Blog ....
bobperry is offline
post #8 of 11 Old 07-22-2013
what a pain in the ass. this is alot easier. Little more stress on the rig though.
abrahamx is offline
post #9 of 11 Old 07-22-2013 Thread Starter
JulieMor's Avatar
I hadn't seen it here.
I thought the expression on the guy at the helm said it all - been there, done that. And the way he cranked in the weights after passing under told me this whole process has had some solid engineering or a lot of trail and error or some of both.
As for the stress on the rig, his rails were just touching the surface, a position I'm sure not unusual to that boat. So I would imagine the stresses created wouldn't be that out of line with what the rig was designed to handle, just that all the pull is at the top of the mast.
JulieMor is offline
post #10 of 11 Old 07-22-2013
blutoyz's Avatar
hardcore right there
blutoyz is offline
Bay Bridge Clearances SailinJay General Discussion (sailing related) 22 10-12-2013 11:03 PM
Bridge openings irk 520 bridge commuters - Northwest Cable News NewsReader News Feeds 0 05-24-2012 09:20 PM
Wednesday night Sailboat Races to take place on Clear Lake - Ultimate Clear Lake NewsReader News Feeds 0 02-01-2012 01:00 AM
Sailboat races on Clear Lake offer landlubbers a waterfront view - Ultimate Clear Lak NewsReader News Feeds 0 08-16-2011 06:00 PM
What to do about a low bridge? hudi11 General Discussion (sailing related) 26 04-27-2010 04:17 PM
