Reefing Lines in Boom - SailNet Community
 1Likes
post #1 of 15 Old 07-29-2013 Thread Starter
Hello All,
I have a friend whose reefing lines have come out of his boom. We have tried several things in order to re-feed these lines back through without any success. He is going to try and get some kind of long thin wire in order to feed them down to the end. I'm wondering if he'll have to remove the rivets on the cap (at the end) in order to feed these lines down and then reattach the cap.
Has anyone experienced this? If so, does this sound right or can you suggest another way to get the lines through?
Thanks!
NS Crew is offline
post #2 of 15 Old 07-29-2013
overbored's Avatar
Re: Reefing Lines in Boom
use a electricians fish tape. or stand the boom on end and use a weighted fishing line
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 15 Old 07-29-2013
cheoah's Avatar
fish tape
Used one to re-feed my reefing lines this year
cheoah is offline
post #4 of 15 Old 07-29-2013
Tanley's Avatar
Yep, use a tape. They look like this and can be found at most hardware stores.
Tanley is offline
post #5 of 15 Old 07-29-2013
Seņor Member
PorFin's Avatar
Got a Harbor Freight nearby? Here's one for $6.99...
Nylon Fish Tape - Save Big on this 50 Ft. Nylon Fish Tape
________
'85 BYB Vagabond 39
PorFin is offline
post #6 of 15 Old 07-29-2013 Thread Starter
First thanks so much for your suggestions!
Second, a dumb question. Would you attach the reefing line to this gizmo and then move it down the boom? Or would you feed the tape through first, attach a reefing line and THEN bring the line (and tape) back through?
Thanks!
NS Crew is offline
post #7 of 15 Old 07-29-2013
overbored's Avatar
pull it back thru with the fish tape. you have a better chance getting where you want it with just the tape first.
post #8 of 15 Old 07-29-2013
Bring the line and tape back through......
Gary3675 is offline
post #9 of 15 Old 07-29-2013
chucklesR's Avatar
Are you sure it just goes down the boom - single line reefing systems have multiple blocks and turns that make them work. It's not just a straight feed.
chucklesR is offline
post #10 of 15 Old 07-29-2013 Thread Starter
I don't think there are blocks inside but I will check this out for sure! If this is the case, I'm guessing that there may be more to open on the boom to get the lines back in place?
NS Crew is offline
reefing lines sailingtime Gear & Maintenance 26 07-11-2013 12:22 PM
Running reefing lines OUTSIDE the boom Classic30 General Discussion (sailing related) 21 05-28-2012 02:15 PM
Running reefing lines through the boom. flyingwelshman General Discussion (sailing related) 7 05-24-2012 10:08 AM
reefing lines bradfalk Gear & Maintenance 7 04-27-2009 10:59 PM
Reefing Lines? z1nonlyone Gear & Maintenance 8 04-14-2003 05:37 AM
