Questions and Advice for that first BIG sail in a new(OLD) boat - Page 2 - SailNet Community
 6Likes
post #11 of 23 Old 07-31-2013
Re: Questions and Advice for that first BIG sail in a new(OLD) boat
Hey psychedchicked (great name) I had the same rope/halyard problem on an old SS34 - I wandered around the marina until I found something that looked very close, befriended the skipper and first mate then just copied the length of everything using their set-up as the template + 10%. You could double check with jimgo's excellent advice. Worked at treat!
Brett Bris is offline
post #12 of 23 Old 07-31-2013
Yeah, and on the sheets and halyards, err on the long side when in doubt--least of all because it's so much easier to fix than the opposite....
nolatom is online now
post #13 of 23 Old 08-01-2013 Thread Starter
PsychedChicken's Avatar
Send a message via Skype™ to PsychedChicken
I actually was given a .pdf copy of the owners manual for my boat on the Ericson Forum. SOOOO glad.
I appreciate all the adivce and am going to have my husband read through it too. Luckily were not far from land the entire trip (just cruising up the gulf coast) and have buddy with a sea worthy boat sailing along with us in his boat.
Hes already strapped on the dive gear and worked on the bottom of it a bit, it was in surprisingly good shape though!
zeehag likes this.
-Kasey
"Not all who wonder are lost..."
PsychedChicken is offline
post #14 of 23 Old 08-01-2013
Tim R.'s Avatar
The manual is in the downloads section of ericsonyachts.org. I know the running rigging sizes are listed in the 35-3 manual so hopefully you can find them in the MKII manual.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #15 of 23 Old 08-01-2013
Hull Number 33
OldColumbia's Avatar
It may sound obvious, but your existing running rigging is a good general template for replacements. When I replaced mine, I used masking tape to attach a 100' spooled measuring tape to the halyards just above the sail fitting and ran it up the mast, noting the length and used the measuring tape to retrieve it. Measure the run from the mast to any clutches and winches and add what you think will be a comfortable tail.
The existing main sheet and tackle can be removed from the traveler (usually with a cotter pin on the bail or the block) and measured on the dock.
The Genoa sheets will depend on the layout of your turning blocks, cars and winches, but the old ones should give you a good idea of the length. More is generally better than less and the type and "hand" of sheets can be important if you have to move a lot quickly. Likewise the spinnaker sheets will depend on the foot of the spinnaker and the "J" measurement ( distance from mast to Genoa tack at the base of the forestay) of the boat. I ran mine to turning blocks aft of the winches which increases the length required.
In all not an inexpensive undertaking.
OldColumbia is offline
post #16 of 23 Old 08-11-2013 Thread Starter
Had our rigging inspecting, all is well to make the trip home!! SOO excited. Heres to hoping that there are no catastrophic failures.
Also, here is a picture of her:
https://fbcdn-sphotos-g-a.akamaihd.n...03307834_o.jpg
-Kasey
post #17 of 23 Old 08-11-2013
snake charmer, cat herder
zeehag's Avatar
psyched---take a manual bilge pump--the bilges are shallow--make sure it has a looong hose for water to exit boat....
food and drink for 2 days even if it is only 40 miles. cant go wrong with that --have enough for just in case---sleeping bag or blanket and spare clothing. the rest you can do when you get to where you are going.
btw--might wanna put a shaft brake so prop doesnt spin--could be a source of potential incoming water--and the packing gland is so far aft and in a convoluted place to find when in a pinch..better to not have it spin for the duration until engine works.
oh yes--and SAIL that thing-is easy and FAST!!!!
failures happen--just keep em small ones..
formosa 41, cruising tropics
zeehag is offline
post #18 of 23 Old 08-11-2013 Thread Starter
Thanks Zee! Im so excited to get her home!!
zeehag likes this.
-Kasey
post #19 of 23 Old 08-11-2013
zeehag's Avatar
you will be fine and all will work out--just bite off tiny bits at one sitting...
zeehag is offline
post #20 of 23 Old 08-11-2013 Thread Starter
Geeze Zee, you talk in fortune cookies.
zeehag likes this.
-Kasey
Tags
advice , running rigging
Advice for gusty conditions? Got a few Questions! NewportNewbie General Discussion (sailing related) 16 02-26-2013 05:34 PM
Hello(questions regarding why you sail) umpalumpa General Discussion (sailing related) 6 09-15-2011 02:51 PM
Some sail area math questions... Alstare Gear & Maintenance 17 06-17-2011 12:16 PM
First Sail on my own boat - Observations and questions donhaller Learning to Sail 22 07-07-2009 12:54 PM
Catalina 27 sail questions???? wildcard Gear & Maintenance 8 05-20-2007 05:40 PM
