Sailing Efficiency Ratings???? - SailNet Community
post #1 of 9 Old 08-08-2013 Thread Starter
NewportNewbie's Avatar
I was just curious...is there any reference that tells you in X amount of wind with X amount of sail area you should be able to attain X speed? I know it will vary depending on boat and current, but something in general?
The reason I ask is I was sailing with my 155 and it was about 8-9 knots of wind and I was at 4.5 knots of boat speed...I was happy, then I wondered...is that actually good??? What if I should be able to do 5.5 knots with that sail area? Just wanted to see how efficiently I sail my boat! Also would be cool to see what other boats sail in the same wind/water conditions.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 9 Old 08-08-2013
Rhys05's Avatar
Re: Sailing Efficiency Ratings????
There are generally polar charts for boats that show for a given wind speed and point of sail what the boat is "capable" of, which can also be influenced by sea state (surfing, bashing into waves, etc.).
For example, here are polars for my boat (S2 7.9):
http://hottamaleracing.com/misc_files/New_79_Polar.xls
Rhys05 is offline
post #3 of 9 Old 08-08-2013
Barquito
Barquito's Avatar
You could find boats of similar speed potential (look at PHRF ratings that are close). Arrange to go out when they are and compare speed. If you just want to experiment on yourself, then make adjustments and see if you go faster.
Valiant 32
Barquito is offline
post #4 of 9 Old 08-08-2013
Rhys05's Avatar
This was going to be my second suggestion, or better yet, go do some beer can races around the buoys! That'll show you quickly whether you are doing well or not. (I need to take this advice myself...)
Rhys05 is offline
post #5 of 9 Old 08-08-2013 Thread Starter
Thats kinda useless...lol...because...I dont know how well THEY are sailing! If they have old tired sails, etc...
Looking for a good baseline. Not looking to sail faster than the next guy, just sail the most efficiently with what I have.
post #6 of 9 Old 08-08-2013
Rhys05's Avatar
That's where being in an actual "race" would make it a bit more likely that you can get a good baseline. Really, if you are racing handicap races, then you can see how you perform against even significantly different boats on corrected time. Other than that, polars seem to be the only truly empirical way to measure your boat's performance against the "expected" performance of the boat model.
Rhys05 is offline
post #7 of 9 Old 08-08-2013
4KSB driver.
Newport, you should be able to find a polar chart for your boat (ideally equipped)... it will give you the answers you are looking for.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is online now
post #8 of 9 Old 08-08-2013 Thread Starter
Thanks. Never new these things existed. That's what I wanted to know. Thanks!
post #9 of 9 Old 08-08-2013
SchockT's Avatar
I ha ent could polar plots for the Santana 30 using Google, but if you send an email to WD Schock they might be able to dig something up for you. The best polar plots are the ones that are developed by boat owners who race, but you would be hard pressed finding one of those for boats as old as ours.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
Displacement to (efficiency per ton) ratio at a given speed steel General Discussion (sailing related) 13 01-02-2013 11:58 AM
Maximizing efficiency under sail ambitiousbutrubbish Cruising & Liveaboard Forum 6 09-23-2012 10:51 PM
AC questions about ratings (BTU) saillife Gear & Maintenance 7 07-05-2012 11:19 AM
COST-EFFICIENCY IS PLANE SAILING (Bangkok Post) NewsReader News Feeds 0 09-27-2006 05:15 PM
Ratings for Caribbean Sailing Charters ? DuaneIsing Chartering 17 01-05-2002 06:57 PM
