Pics of Dawn (Ponce Inlet outward) - SailNet Community
 2Likes
  • 2 Post By Harborless
post #1 of 2 Old 08-11-2013 Thread Starter
Blue Horizons
Harborless's Avatar
This was my fourth ocean sail. I decided to leave the marina 30 minutes from dead low. What a great idea. I left dock at 4:50 a.m. with no trouble other than dinging my head on an anchor mounted over the stern rail while undoing a dock line, that woke me up right quick.
Made the 4 mile trip including draw bridge (Coronado) in about an hour. I had just spent two hours scraping and brushing the bottom clean the day before- was moving at a steady 6 knots. Hoisted main after crossing under bridge.
Big swells coming into the inlet. Bucking bronco for a few minutes until out past the jetty. Made it out about 5 till 6:00 a.m. Did not heave the jib halyard taught enough so when it was time to raise the jib I was a bit tangled around the forestay. Big swells and mostly darkness took me a few minutes to unwind it but then the jib was hoisted no problem and the engine killed.
Sailed around in 4' swells up to 6' perhaps. Stayed out until around 12:00 p.m. and rode the flood back in in about an hour fifteen. Sailed under the bridge with engine in neutral the last two miles- wind from the south southwest. Made the cut into the alley where the marina is and dropped sails. Cruised into my slip- no bumps. Was a nice day. I like sailing at sunrise. Sorry I am not more inclined to take pics. Here are the ones I took however.
-Harborless
Raw Water hose leading to the pump came a bit loose because the hose diameter is around an 8th of an inch too large diameter. So had a bit of water in the bilge. Other than that all green. Will add another hose clamp tmmrw for water pump fix.
jimgo and Fau like this.
Harborless is offline
post #2 of 2 Old 08-11-2013 Thread Starter
Blue Horizons
Harborless's Avatar
Re: Pics of Dawn (Ponce Inlet outward)
FYI- The first pic is of the Ponce Inlet light house. It was the first time I had ever seen a lighthouse in active operation. A pity my picture taker is a cellphone- I wanted to get the light as it rolled around off the bow but the delay caused it to be missed.
-Harborless
Ponce Inlet Florida Snboard976 Destinations 4 12-23-2009 10:00 AM
ponce de leon inlet Cbarg Cruising & Liveaboard Forum 1 03-27-2009 08:26 PM
Local knowledge for Ponce De Leon inlet seamyst Cruising & Liveaboard Forum 2 06-01-2008 06:42 PM
Coast Guard assists vessel off Ponce Inlet (CBS 47 Jacksonville) NewsReader News Feeds 0 11-07-2006 10:15 AM
Coast Guard assists vessel off Ponce Inlet (FOX 10 Mobile) NewsReader News Feeds 0 11-07-2006 07:15 AM
