CO2 replacement - SailNet Community
post #1 of 8 Old 08-12-2013 Thread Starter
Slayer's Avatar
CO2 replacement
How often do you replace the CO2 canister on your inflatable PFD? I have two and both were filled in 07. I triggered one to see if it still works, and it worked fine. Should I replace the other one?
Slayer is online now
post #2 of 8 Old 08-13-2013
poopdeckpappy's Avatar
Re: CO2 replacement
If the cylinder hasn't been holed or dented it's good, they have no shelf live
Hopefully we're talking the same one time use CO2
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #3 of 8 Old 08-13-2013
s/v Tiger Lily
dvuyxx's Avatar
Re: CO2 replacement
You are supposed to inspect the seal on the cylinder. But for automatic vests you are supposed to replace the dissolving bobbin (that activates in water) every year (or at least every other year) since it is affected by humidity.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #4 of 8 Old 08-13-2013
Remember you're a womble
PaulinVictoria's Avatar
Re: CO2 replacement
Depends on the manufacturer and the type of vest. Read the manual.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 8 Old 08-13-2013
Splashed
JomsViking's Avatar
Re: CO2 replacement
The CO2 Canister has a weight stamped on it, put it on an accurate scale and make sure that it is close to that. They do NOT last forever.
While testing vests we've had several that did not inflate the vest fully.
Take care
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
post #6 of 8 Old 08-13-2013
Re: CO2 replacement
I've personally witnessed a inflatable pfd, fail to inflate. It puffed, but barely even broke out of the velcro enclosure. The manufacturers define the re-arming period and this one was exactly at that date. Most don't follow it, myself included. We all really should.
Jeanneau 54DS
Minnewaska is offline
post #7 of 8 Old 08-13-2013
Re: CO2 replacement
no need to replace it at all as it would fine and superbly without a worry, even it could run on a single cylinder too...l.
MarkBarrett is offline
post #8 of 8 Old 08-13-2013
Splashed
JomsViking's Avatar
Re: CO2 replacement
Care to explain?
If you're saying that they don't need replacement - You're putting people in danger.
If you're saying that vests have two cylinders, while most don't - You're putting people in danger.
CO2 Replacement on PFD Slayer General Discussion (sailing related) 3 04-02-2011 07:42 PM
Acrylics replacement Erwan Gear & Maintenance 4 01-22-2010 08:40 PM
Headliner Replacement harbin2 Islander 6 12-13-2009 01:44 PM
Replacement Key? Sailpilot Gear & Maintenance 8 06-12-2009 10:21 PM
Replacement key dmurcott General Discussion (sailing related) 3 06-01-2006 12:43 PM
