Boat delivery list - SailNet Community
 7Likes
post #1 of 38 Old 08-16-2013 Thread Starter
davidpm's Avatar
Boat delivery list
Every so often I get a call from someone wanting help moving a boat. It is usually 50 to 150 miles, east coast, typically Long Island Sound, RI, CT, NY, NJ.
The boat would be from 25 to 35 feet. Typically these people are buying their first big boat so they don’t know much. They will come with me on the trip so the two of us will do the delivery. I’ve done it several times and find myself having the same conversation. I’m putting together a list of things I need to discuss so I can email it and not forget anything.
I know several of you have done this for years so what should I add to the list?
Did I include anything that is unnecessary?
The bold items are not negotiable. The lights are negotiable if I’ve got a really high chance of not sailing at night. The standard font items I ask about but if they don’t work depending on the details of the trip I may do the trip without them
1. Hull is sound, not making water.
2. Thru hulls don’t look like they are ready to fall off.
3. Engine runs ok, starts well, does not overheat, transmission works forward and reverse.
4. Boat can make reasonable speed under power.
5. Fuel is new or if old has been polished
6. Spare impeller and tools
7. Oil
8. Battery is holding charge.
9. Alternator putting out correct voltage
10. Navigation lights, steaming light and deck light work.
11. Standing rigging at least looks ok and seems to be reasonably tight.
12. Sails and running rigging work.
13. Reefing is working
14. Winch handles
15. Bucket, Dock lines
16. Anchor and rode
17. USCG safety equipment
18. Personal clothing (not for me for them, foul weather etc)
19. Insurance card
20. Tow boat or Boat US
21. Food (utensils), water, rags, paper towels, trash bags, toilet paper
There are several things that are needed I don’t make a fuss about as I carry them myself:
1. Charts
2. GPS
3. VHF Radio
4. Hand bearing compass
There are several things I haven’t mentioned on either list that I would like to have but I’m conflicted as to how important they are so I’ll see if someone else mentions them.
My goal is to move the boat from point A to point B. I pick good weather and motor if I have to. I'm not responsible for a full survey but the basics have to work well enough to move the boat.
davidpm is offline
post #2 of 38 Old 08-16-2013
manatee's Avatar
Re: Boat delivery list
Provision for emergency steering, tested and working.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #3 of 38 Old 08-16-2013 Thread Starter
davidpm's Avatar
Yes of course, thanks.
davidpm is offline
post #4 of 38 Old 08-17-2013
manatee's Avatar
With any kind of good luck, you'll never need any of this, so once you make up what you want of it, you're set. This is the 'plan for the worst, hope for the best' list. ....or, 'paranoia is cheap' list.
Don't know how frequently through-hull punctures happen up there, but with all the rivers & floods there's bound to be some bad junk in the water:
Set of various-diameter tapered wooden plugs to drive into a hole in the hull, with heavy mallet for driving them. Fitted plug on lanyard next to each through-hull.
Set of plywood squares, maybe up to 1/4 sheet, with nails started on the edges, with hammer.
Fothering gear: canvas, rope & goop to cover a hole from the outside.
High-volume manual bilge pump.
Selvagee & handy-billy in case a stay or shroud lets go.
davidpm likes this.
~~Dylan Winter,
manatee is offline
post #5 of 38 Old 08-17-2013
Tartan 27' owner
CalebD's Avatar
What about a med kit if someone gets seriously injured?
Yes, you will usually be within VHF of CG somewhere but people have died from getting boomed by accidental jibes. That segues nicely with a preventer for the boom for downwind courses.
You can still get low dose Codeine over the counter in civilized countries like Canada, eh?
Not in the good ol' USA. Nope. No dope.
Everybody has one:
CalebD is offline
The Following User Says Thank You to CalebD For This Useful Post:
davidpm (08-17-2013)
post #6 of 38 Old 08-17-2013
Mermaid Hunter
SVAuspicious's Avatar
Pretty short hops. Ground transportation is likely to be a bigger issue in many cases than moving the boat.
My thoughts as a delivery skipper follow. Most of my work is long haul offshore but I do my share of local moves also, mostly single-handed.
Nav lights are not negotiable. You never know what might happen except that the sun will go down.
You can never have too many fuel filters.
Ground tackle is important. Appropriate anchor, rode, snubber for chain.
Tools.
Are there enough fenders and dock lines for arrival?
Educate yourself on towing insurance. If you are being paid to move the boat your own Towboat/US policy does NOT apply, and the owner's doesn't either if he isn't aboard. I don't know the details of SeaTow policy. Towboat/US offers a separate delivery skipper policy I highly recommend.
Meals and snacks need real attention. You have to keep energy levels up. You have to be alert. On short trips you can get away with cold pizza and PBJ but there has to be enough and you have to make sure everyone, including you, eats. Good food helps make good trips. Hydration is similarly important. For short trips as you describe, a couple of gallon jugs of water is plenty in case there is a problem with the water system. If the boat water smells or tastes funny you'll want more jugs.
Other things from my own list:
Baby wipes
Spare batteries for all portable electronics
Adapters to charge phones et al from 12V
I think damage control prep is often overblown. If you have duct tape and wood screws you can manage nicely in extremis with locker doors and floatation cushions. The latter you're going to want anyway to sit on.
Remember that real problems are rarely single events. It's a cascade of two or three failures that lead to a crisis. Deal with every single thing that fails as quickly and permanently as possible, even if that means breaking off a passage.
As you're sailing think about things that might go wrong and what you would do in response. It's good practice, and when something does go wrong you'll respond more quickly.
I do a lot of owner-aboard deliveries. You have to have a discussion about who is in charge before there is a problem. Are you skipper or crew? Do they just need support or are they looking for training? Are you in a position to meet the owner's expectations? Communication is key.
nolatom, jameswilson29 and TJC45 like this.
SVAuspicious is offline
The Following User Says Thank You to SVAuspicious For This Useful Post:
post #7 of 38 Old 08-17-2013
One other point regarding towing insurance, is that no one company covers all areas. And, in some areas, one company dominates to a point that the competition offers only minimal coverage. That is, a call to the lesser coverage company could lead to a very long wait. That's if they respond at all. I would check coverage areas before departure. Or, carry insurance for all tow companies within your 150 mile radius of operation.
TJC45 is offline
post #8 of 38 Old 08-17-2013
The most female moderator
Donna_F's Avatar
Dock
All of this is a good checklist for the average boat owner, not just delivery captains.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #9 of 38 Old 08-17-2013 Thread Starter
davidpm's Avatar
I actually had this happen once. I was able to use my insurance and no questions were asked. We only need a tow about 2 miles though.
davidpm is offline
post #10 of 38 Old 08-17-2013 Thread Starter
davidpm's Avatar
I found this list also:
BoatUS Professional Captains
davidpm is offline
Boat Delivery TimofBlindSquirrel Boat Review and Purchase Forum 8 08-11-2010 08:40 AM
Boat delivery options rjg23 General Discussion (sailing related) 4 08-05-2010 03:22 PM
boat delivery Fl to Md, my thread scottyt General Discussion (sailing related) 7 04-28-2010 02:43 PM
Boat Delivery Costs TSteele65 General Discussion (sailing related) 16 11-27-2007 09:10 PM
Overland Boat Delivery?? prussell General Discussion (sailing related) 5 07-18-2004 03:23 PM
