Advice on this Catalina 22 - SailNet Community
post #1 of 8 Old 08-21-2013 Thread Starter
High Desert Guy
Ziaduck's Avatar
I've been in the market (again) for a trailer sailor in the 19'-22' range, and today looked at a local 1975 Catalina 22'. Overall the boat isn't terrible and needs normal maintenance and updating.
I would like your input on a few things as I don't pretend to be an expert. There is some damage to the fiberglass of the keel trunk near the front. I found it while inspecting the boat, and the owner (older gentlemen who's been sailing for at least 40 years) was unaware of it. Can anyone tell me if this is a serious red flag, or just something cosmetic?
Access under dinette seat for location purposes:
Different shots of the issue:
Also, Are these compartments usually filled with foam? One is under the v-berth and the other under the quarter berth:
Also, it appears the sides of the bottom of the cockpit was re-glassed at some point. Not sure what to think about it:
I appreciate all input!
We learn not from the mistakes we make, but the price we pay.
Ziaduck is offline
post #2 of 8 Old 08-21-2013
Captain Obvious
Sal Paradise's Avatar
Re: Advice on this Catalina 22
Holy Cow!! That is weird. Are you seeing the keel from inside?I would be very scared. Those compartments are not filled on my boat. I would walk away.
Sal Paradise
Senior Researcher - Dunning Kruger
Sal Paradise is online now
post #3 of 8 Old 08-21-2013
The most female moderator
Donna_F's Avatar
Dock
I don't have a C22, but I'm not aware of Catalina filling any compartments with foam. However, you can't see what the foam may be hiding.
I wouldn't worry about the sides of the cockpit being re-glassed as long as when you look at it from inside the storage locker you don't see any signs of serious damage. It could simply be issues from flexing, especially if it was on a trailer.
That first hole concerns me. But, if it was me and the boat was reasonably priced and everything else (rigging, sails, etc) was in decent shape, as long as it was above the water line, I'd simply fix it and move on. My first boat was a project 22 and I did some fiberglass repairs on it. I wasn't much concerned about doing my own repairs as long as it wasn't below the waterline.
Not knowing what's behind that foam would be a deal breaker for me.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #4 of 8 Old 08-21-2013 Thread Starter
High Desert Guy
Ziaduck's Avatar
Not the keel, it appears to be a wood brace in front of the keel.
Ziaduck is offline
post #5 of 8 Old 08-21-2013
Captain Obvious
Yeah I see it now. I don't know...I suppose you could just glass it up;.but its a bad place to have rot... and the cockpit too, must have leaked and might have rot..... The foam may be a home made floatation system..... I dont remember anything critical in those areas... the keel is pretty damn critical...
Work the keel and see if it flexes....look at it from above and below.... then if you think its solid..... bid cheaply. I got mine, dirty but rock frigging solid...... very cheap.
Sal Paradise
post #6 of 8 Old 08-21-2013
JimMcGee's Avatar
I don't remember there being anything but empty space where the foam is, but it's been a while since I sold my 22. I'm guessing the guy was after positive floatation.
As for the glass over the wood stringer, take a scratch awl and probe the wood. If it's solid you're probably OK just glassing it up.
Try going here Catalina 22 - SailboatOwners.com and ask the question. Somebody over there has seen and fixed this same problem.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #7 of 8 Old 08-21-2013
Huck
smallboatlover's Avatar
Walk away the foam was most likely to cover up problems. On one of my first boats the previous owner did it. Just walk away keep looking always better deals out there. To remove foam like that you r looking at about 30 hours of work with shovels, saws, and every thing else you have. My personal advise from first hand experience
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #8 of 8 Old 08-21-2013 Thread Starter
High Desert Guy
Ziaduck's Avatar
Thank you all for the advice! I'm in no major rush (though I'd like to buy one soon) so I don't mind passing on this one.
Ziaduck is offline
a little advice please catalina 25 newbie139 Boat Review and Purchase Forum 9 06-24-2013 06:24 PM
repair advice on a Catalina 22 Mitch817 Gear & Maintenance 16 05-18-2012 06:56 PM
Advice 27''Catalina Before I sign lgmuth Boat Review and Purchase Forum 10 02-20-2007 12:58 PM
Advice on Catalina 27 ricardoasilva Catalina 0 08-18-2006 05:34 AM
