-   -   Scary night sail (http://www.sailnet.com/forums/general-discussion-sailing-related/102838-scary-night-sail.html)
davidpm 08-22-2013 07:46 PM
Scary night sail
4 Attachment(s)
As I proof read this is it long and boring.
But I wrote it so might as well post it. You have been warned.
I thought you ladies and gentleman will enjoy my little story from last night.
For the last few years Iíve been volunteering as a skipper for a local organization that takes out handicap people in their three boats (sailctaccess.org). Charles one of the volunteers and members has been a regular for several years. Charles has a pretty good job but is in a wheel chair. He cannot use his legs at all as far as I can tell but his arms are pretty strong and he can maneuver himself it just takes some time.
Last year he got it into his head that he wanted his own boat. He went shopping and settled on this Allmand 31. It had been neglected on the hard and was yard owned. It needed a lot of work and I told him point blank to not buy the boat. But he did and as expected there were unexpected expenses the most notable being that the fuel tank sprung a leak on the hard and had to be replaced. There were the normal issues with the yard with the engine, and electrical and getting rid of the fuel oil smell.
There were issues with insurance not letting him leave the dock until everything was fixed. Charles will be the first to tell you he knows very little about boating but he really wanted his own boat.
So miracle of miracles he got is boat in the water just a couple weeks ago and some friends from the Power Squadron took him out a couple times and even ran him into a rock. But considering a yearsí worth of frustration and more money than he had to spend he was a little bummed.
He asked me if I would take him and his wife out last night.
Last night at 4PM I get there and my crew is Charles, his wife and daughter. His wife has several medical issues and while she can walk it takes her a very long time. In fact one either of the sits down even moving a foot or two one way or the other on the seat can take a little doing. At first I thought I could use the daughter as crew but since she is brand new to boating and had some mobility issues I could not count on her to react quickly either.
We were waiting for another crew member, a cousin I believe so I figured I had some time to kill so we took a look at the motor.
It took quite a long time to start it. It seemed like the sometimes the starter would get juice and sometimes not. Other times it would spin but not start. He said it was like that. Finally we got it started. Then I experimented with the throttle and shift. The throttle did not have a defined idle. Too far back and the motor stops, very touchy. The shifter did not have a clear neutral, very touchy too.
I figured I would be fending off and walking the boat out and Charles would be on the helm. I couldn't be at both ends of the boat at once. Charles had never touched the controls before. So we spend about 40 minutes at the dock practicing putting it in gear and giving it throttle then idle then neutral. At first every time he put it in gear and the dock lines snapped his wife excitedly urged caution. I had to reassure her that I was watching things so she would keep quiet so Charles could work calmly.
Finally the cousin arrives. I find out that he has very bad knees. He can walk but he canít put all his weight on one leg quickly. In other words he canít get on or off the boat unless it is tied up.
All this time Iím thinking of how Iím going to get the boat out. As you can see if the boat backs out it has to turn to port which of course the prop work is not going to like. I was thinking of just backing down the fairway but the wind was directly behind the boat at right angles to the fair way and this boat has a full keel and I didn't know how it would back.
All this time Iím trying to figure out if can I handle this boat with a crew that has very limited abilities, and no experience, on a boat where I don't trust the motor and I don't know how it handles. I am truly hoping the engine will stop so I don'tí have to decide.
Finally I decide to go for it. The conditions were perfect. Very light wind about 5 knots and no current. If I wasn't going to go in those conditions I might as well give up boating. I would have liked one able bodied even minimal experienced person but I had what I had.
My idea was to push the boat out by hand and see which way it wanted to go then hop on and make sure the bow cleared the pole and then pick either forward or reverse depending on what the wind did that moment.
It worked perfectly. I pushed it out and after clearing the pole we were positioned to just put it in forward and go. Charles put it in gear and nothing much happened so he gave it a little throttle and we were on our way.
Thatís when Charles found out he needs a little modification to the helm seat. He can't see over the bow so I was lookout until we got past the channel.
Before we put up the sails I took the helm in open water and tried to get a feel for how fast the boat responded to steering controls.
During this time we get a little close to buoy 6. This buoy marks a string of rocks coming from Duck Island (we are in the Westbrook CT harbor). I know we have good water there I have been there a hundred times and have my hand held chart plotter for verification.
But I tell Charles to go ahead and head east to make sure we are in obviously clear water. He is more than a little nervous about this area because another .3 miles east there is a peninsula that has some rocks off its shore that he hit on one of his two prior excursions with the power squadron guys. So don't know what damage there is to the keel.
I put up the sails and after a few minutes we caught some air and were sailing at four knots on a perfectly calm sea.
We didn't leave until five so it was about seven when Iím thinking we should start heading back as I didn't like the idea of trying to dock in the dark.
Then I find out that the whole purpose of going out last night was to see the blue moon. So Iím thinking of how Iím going to dock that boat by myself and now I find out I'm supposed to do it in the dark too.
Everyone seemed to be so excited about the moon and it is only a few minutes later than what I planned. The darkness idea I did not plan however.
So we tack and are heading back, Charles is on the helm and I go below to get flashlights, figure out navigation lights and dock lines etc. By the time I get on deck I see we are in line with Buoy 6 again. I ask what we are doing here. He said he was worried about the rock on the east side.
I tell him Iím more worried about the rocks 100 yards to our west that the current and east wind was taking us towards than the rocks a half mile away. So we try to start the engine. Not even a click. Then after a few minutes it seems to click then all of a sudden it starts. I had maybe another couple minutes before I had to go for the anchor which I saw existed but didnít know its status.
So we hang out for about half an hour see the moon then start to head in. Only now there are 20+ boats ahead of us. Apparently the weds night race folks figured they might as well see the moon too. Of course Charlie doesn't know where the channel is and canít see the traffic so I take the helm.
I've done this channel dozens of times in the dark so the only issue is the heavy traffic. The slip however is new to me and we canít see the fairway letters on the poles. I need to buy that battery torch. Fortunately Charlieís wife has really good eyes and makes out row ďNĒ. We make our turn and it is clear that I pretty much have to do this by myself.
While we were waiting for the moon I was trying to figure out how to dock. I figured that the expensive powerboat on our starboard was the enemy. I had no one that could fend for me so I figured I would favor the port side pole. A scratch of two on Charlieís boat would match the ones he already has. I figured I would put the port side of the boat at about 45 degrees to the dock connected to the pole, stop the boat, step off with the bow spring and swing the boat in manually around the pole. I would have someone on deck throw me the stern line and all would be good.
Only problem was that their stern line was only 6 feet long. There were no extra dock lines on the boat but I found a long line connected to a couple blocks, probably a boom vang that I cut the knot off of to use for a stern line.
That was the plan and it worked perfectly. No one was more surprised than me.
had a great time and I pushed my boundaries just a little
Frankly Charlie is an inspiration. He is not letting a significant handicap or limited funds prevent him from doing what he wants to do.
He was thrilled that he was able to get the boat out with him at the helm and that he was able to steer under sail. He needs a little help but he had a great sail.
I would never have bought the boat he did but he pulled it off.
To my mind his most significant lapse in judgment is his apparent complete confidence in me.
If something went wrong there would have been all kinds of legitimate comments about have going out was a bad idea. Iím glad I got lucky. Iím not sure Charlie knows how lucky he was.
aeventyr60 08-22-2013 07:54 PM
Re: Scary night sail
Sometimes you just have to go for it. Maybe Charlie is the real teacher here. He is a lucky guy to have you helping him live his dream. Good on ya David!
mad_machine 08-22-2013 07:57 PM
Wonderful story.. scary yes, but wonderful too. I bet you really made their night, possibly their year.
Being Handicapped should not stop anybody from sailing. If he can spare the funds to run all the lines to the cockpit and set up an autohelm, he should be good to go
davidpm 08-22-2013 07:58 PM
Originally Posted by aeventyr60 (Post 1078057)
Maybe Charlie is the real teacher here. !
I was thinking the same thing.
Sal Paradise 08-22-2013 07:59 PM
That is an awesome story. I am so glad you decided to share that. Thanks, you made my day. And you made Charlies day, maybe his year!
davidpm 08-22-2013 08:11 PM
That was has original plan. From a practical point of view I doubt if it matters.
Until I had last nights experience I really didn't understand the delays certain disabilities cause.
Neither Charlie or his wife can just slide over in their seat a couple feet to make room for someone else to reach gear they are in the way of.
That slide alone can take a while while he positions his feet with his hands then moves his body with his hands. It takes time especially when each step may only move him six inches. There is no way I can think of to modify the boat to run all lines to behind the wheel. Even if this was done I don't seem him being fast enough to switch from one side to the other.
Even with a bow thruster and an easy to maneuver boat what would hold the boat in place until the lines were run?
I'm sure with unlimited funds and engineering something could be rigged up. But then if something went wrong what would he do?
I think he is going to make a lot of friends. Hopefully they will have more skills than I.
But what do I know. I never expected him to even get the boat in the water. He was sanding the bottom from his wheelchair in the winter.
smurphny 08-22-2013 08:16 PM
A big high five to you!
justified 08-22-2013 08:30 PM
David
Great story. Glad you went for it and got them out there, it was a beautiful night. I was racing there, so was probably in the parade with you.
My brother and I sailed with you a couple yrs ago on Bene's boat (new yr day).
I'm around if you would like some experienced crew with you next5 time you take them out. PM me or I think you may have my number.
Good Job
Peter R Carey
cthoops 08-22-2013 08:53 PM
Great story. As I read it I became increasingly worried that it wasn't going to work out so well, so kudos to you. I'm sure Charlie and his wife will be talking about that sail - and the blue moon - for a long time.
zeehag 08-22-2013 09:01 PM
28 Attachment(s)
the picture with him smiling ear to ear says it all--yoo dun gud.
