The Perils of Rafting On - Page 4 - SailNet Community
 7Likes
post #31 of 34 Old 08-30-2013
Closet Powerboater
MedSailor's Avatar
Re: The Perils of Rafting On
No doubt many instances of dragging are due to insufficient scope, but I think the argument can also me made that many cruisers often use more scope than necessary, with no added benefit whatsoever... A lot of recent analysis and real-world experience is leaning towards the conclusion that the generally accepted safe minimum of 7:1 is largely a myth...
Peter Smith of Rocna, with help from the work of Alain Fraysee, has demonstrated there is never any point in going with more than 7 or 8:1... Unless it makes one 'feel better', of course :-)
Beth Leonard & Evans Starzinger consider 3:1 or 4:1 to be their "normal" amount of scope, but will go to 5:1 if expecting a blow...
I believe they have the right approach, using an oversized hook that holds well to short scope to begin with, instead of depending on additional scope alone for holding power... Like Steve Dashew, they believe a cruising boat's main anchor should be sized on the assumption that they might have to be used with 3:1 scope, and I think that recommendation is spot on. In crowded anchorages, I think more drama is due to undersized anchors to begin with, than to 'insufficient scope'...
I would agree with much of this, though you're really well outside of "anchoring 101" or even 201 here. I usually don't like to mention this kind of stuff unless a lot of qualifications and specifics are mentioned. It's too easy, in my opinion, for someone to mis-read this info and start using 3:1 with rope and a regular sized anchor, for example, which none of the experts you mentioned are recommending.
Even with a pure rope rode there is no benefit to >7:1? Do you have a link to their data? I love anchor geekery.
MedSailor
MedSailor is offline
post #32 of 34 Old 08-30-2013
MedSailor
Try this one. Highlight the variable you wish to change and click and move up or down (took me a while to figure that out)
Fun to play with, but I still like to be able to raise the wind and leave some chain on the bottom.
lowtide is offline
post #33 of 34 Old 08-31-2013
MedSailor
Rocna's 'Knowledge Base' offers a wealth of information, backed by extensive experience with anchoring in some of the most hostile conditions on the planet...
Catenary & Scope In Anchor Rode: Anchor Systems For Small Boats
JonEisberg is offline
post #34 of 34 Old 09-01-2013 Thread Starter
flandria's Avatar
Dock
I notice that a lot of the discussion has shifted to scope etc... The 2 boats "in trouble" did not drag... they were simple beating the sh@# out of each other in a squall with a nasty little chop... and not a skipper on board who knew what to do (such as, break the raft...)
flandria is offline
Perils of a Pleasure Boat Insurance. DonQuijotedelMar General Discussion (sailing related) 4 07-13-2007 12:03 AM
I THINK Rafting Up is Allowed, though if its bumpy you may not want NewsReader Mass Bay Sailors 0 08-14-2006 08:15 PM
The Particulars of Rafting Up Mark Matthews Learning to Sail Articles 0 06-09-2003 09:00 PM
The Perils of Piracy Mark Matthews Seamanship Articles 0 07-15-2001 09:00 PM
Offshore Perils John Rousmaniere Seamanship Articles 0 06-07-2001 09:00 PM
