Getting standing rigging replaced in Seatte- suggestions? - SailNet Community
 1Likes
post #1 of 14 Old 08-28-2013 Thread Starter
Hi
I have decided to have all my standing rigging replaced and get a new main halyard as well as convert a gate valve thru hull to a proper seacock.
I have used Yacht Fitters before, but they are not returning my calls or emails (perhaps my litttle 24 footer is not worth their time...). Anyone have any other suggestions or experience in the Seattle area?
No trailer, want to haul out at Lake Union or Ballard.
Thanks!
matthewwhill is offline
post #2 of 14 Old 08-28-2013 Thread Starter
Re: Getting standing rigging replaced in Seatte- suggestions?
And another question:
Just got a quote from Seattle Boat Works and it will cost almost as much as I paid for the boat so.... I had the rigging inspected and was told there was nothing dangerous and nothing that looked as if it would fail. But there was "candy caning" of the metal which apparently is a sign of some fatigue.
How often does one usually have the standing rigging replaced in a boat that is used about once a week, not for cruising extended periods, and rarely in winds greater than 20 knots?
post #3 of 14 Old 08-28-2013
Sabreman's Avatar
The rule of thumb is to replace every 20 years or so if there are no visible signs of wear or strand breakage. With that said, many rigs ( including mine) are still going strong after more than 20 years.
An option is to send the old shrouds to riggingonly.com and have them make replacements. They are quite reasonable
Sabre 38 "Victoria"
Sabreman is offline
post #4 of 14 Old 08-28-2013
blt2ski's Avatar
West marine and possibly Fisheries has the ability to replace what you have. There is another rig place IIRC with in CSR on the cut, or maybe the one out at shilshoal........
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #5 of 14 Old 08-28-2013
no longer reading SailNet
Alex W's Avatar
Fisheries recently redid their rigging department and I believe you can now DIY new standing rigging with their tools. I would expect the raw materials assembled to cost somewhere in the ballpark of $500.
I had my boat hauled at CSR and had the forestay replaced as part of installing a new furler. They did the work for a pretty reasonable price, but it still involved a lot of labor and that is the expensive part. DIY should be possible on a 24' boat and would save you money. It would probably take two mechanically inclined but not expert people a day to drop the mast, replace all rigging, and put the mast back up, based on my experience with my Catalina 25.
Small boats often are often sold for a lower price than any major piece of work (or maybe two) costs on them.
Alex W is offline
post #6 of 14 Old 08-29-2013
blt2ski's Avatar
Alex,
You're right he does have a smallish boat. Two folks "SHOULD" be able to lower the mast at a slip or equal, and take it ashore and remove the current wires etc, take them to the rig shop at Fisheries or WM or Yachtmasters or Knotty on this site, or equal, then a few days later, put everything back on, and raise the mast. OR, as noted, if Fisheries will let you use there tools etc, do it there. Not positive Cliff at WM will allow that, but you can still get everything from there if need be.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #7 of 14 Old 08-29-2013
there's two places in Port Townsend... Brian Toss and Port Townsend rigging
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #8 of 14 Old 08-29-2013
Closet Powerboater
MedSailor's Avatar
I had really good luck with the CSR yard. Good people. Yard work is expensive though, and there isn't really any yard that specializes in rigging. That's not generally what they do.
That said, you're really better off pulling the mast and doing the work yourself. What I would do if I were you is befriend someone at Shilshole that has a key fob for the dry storage area. That means you can use their crane to pull your mast.
Pull the mast, take off all the wires, measure carefully, and place your order with RiggingOnly. Reverse the process and sail away with all new rigging.
So.... do you really need new rigging or have you just been spending too much time on SailNet and the fear has started to creep in? Better look at those chainplates while you're at it, they might be waiting to explode. Checked your keel bolts lately???
I guess what I'm saying is that maintenance is good, and important, but don't let yourself get so caught up in the "what if it fails" that you never go out and sail your boat. Replace what needs replacing, but don't get carried away....
MedSailor
MedSailor is offline
post #9 of 14 Old 08-29-2013
blt2ski's Avatar
Meds point about the chainplates is a good one. An SJ28 a couple of weeks ago at the Pink Boat regatta at shilshoal lost a mast, The WHOLE blinken chain plate pulled out of the deck upwards, then the rig went down. Fortunately no one was hurt. Look around for other potential issues. At the same time, for how I have seen you say you sail........
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #10 of 14 Old 08-29-2013
aeventyr60's Avatar
If you go inside the locks and get a berth at ballard mill marina you could live aboard and work on the mast next door at sea view boat yard. Bars and restaurants close by too...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
Standing rigging won't mtboat Gear & Maintenance 10 05-11-2011 07:34 AM
Standing Rigging Re-do dmkey C22 6 05-23-2010 10:20 AM
Standing Rigging Cal 33 dshearn Gear & Maintenance 2 07-18-2004 06:42 AM
Standing Rigging docsabre Gear & Maintenance 1 04-23-2002 07:09 PM
standing rigging ohio dave General Discussion (sailing related) 2 07-08-2001 07:30 PM
