Dock vs. mooring - Page 4 - SailNet Community
 22Likes
post #31 of 58 Old 08-31-2013
Re: Dock vs. mooring
We almost always anchor or use moorings when cruising, but have a slip at our marina. We prefer shore power, so we can keep our fridge stocked and batteries topped. Easy access is very helpful for provisioning and repairs. I've not heard of too many repair technicians willing to dinghy out to your mooring. When needed, they can come aboard at the slip, while I'm away. Marina keeps a key. Also much easier to keep the boat clean, top water off, use shore bathrooms, etc.
Jeanneau 54DS
Minnewaska is offline
post #32 of 58 Old 08-31-2013 Thread Starter
The bathroom use would be a problem. Anyone use solar power to keep up there batteries? That was my plain anyway. Around my house some of the farmers use solar powered electric fence's that work great. My one fear is the bilge stops working. That's why you wire is a second.
LakeMi is offline
post #33 of 58 Old 08-31-2013
Mermaid Hunter
SVAuspicious's Avatar
Not trying to sell anything I will say that part of my competitive advantage is serving boats on moorings and at anchor. Saving a transient client slip fees helps them a lot.
SVAuspicious is offline
post #34 of 58 Old 08-31-2013
Solar is the way to go to keep the batteries topped. However, you can't skimp and you'll need a place to install them.
Most marinas are no-discharge these days, so you'll have to pump out your holding tanks, if you use the heads aboard. That's not a real big deal, if you're heading in and out anyway. On that last day, where you're not leaving till the next morning, we avoid the onboard heads. If we used them, the waste would either sit there all week or we would have to go over to be pumped out again. PITA.
Jeanneau 54DS
post #35 of 58 Old 08-31-2013 Thread Starter
With the size of boats I'm looking at the holding tanks are small. So I'm thinking at most every other time to the boat ill be making a trip to get it pumped out. 15 gal sounds like a lot but it adds up fast with 5. Still better then a portipotty.
LakeMi is offline
post #36 of 58 Old 08-31-2013 Thread Starter
Well it looks like ill be getting a mooring. Then keeping the boat at a marina for winter. Total about $1000 a year give or take a few hundred. Now to find a boat. One that the wife likes.
LakeMi is offline
post #37 of 58 Old 08-31-2013
S/V Antares
rwy36's Avatar
On the subject of moorings and pump-outs: In the Old Saybrook/Old Lyme, Connecticut area, the pump-out boat will give you an orange flag to attach to your bow rail if you're in need of a pump-out but not going to be aboard (along with a container for a tip). This is ideal for folks on moorings and in slips as not too many marinas really want to deal with the pump-out directly (as there is a large State-run pump-out just north of the railroad bridge).
I agree with the earlier comment that access to water is an important consideration and I think especially so if your doing multiple overnights regularly.
Bill
rwy36 is offline
post #38 of 58 Old 08-31-2013
5 people on 15 gallons of holding is barely a day, in my experience. To keep waste hoses from smelling, you need to flush at least one gallon of clear water, after you empty the bowl of its contents. That will mean a dozen flushes max. Better not drink or eat anything.
Jeanneau 54DS
post #39 of 58 Old 08-31-2013
no longer reading SailNet
Alex W's Avatar
The amount that you need to fully pump depends on how long the lines are. On my 28' boat where there is a 3' of 1.5" line between the toilet and holding tank it doesn't take a gallon to flush, the volume of the line is just under a quart. Our 20 gallon tank is good for 6 or 7 days for the two of us.
This thread and the thread on dealing with dock lines has taught me how regionalized boat storage can be. Mooring balls aren't that common for permanent moorage around here (Seattle), I primarily see them in front of waterfront houses for smaller boats. I've never seen a dock without cleats and where you are tying off using pilings either. Obviously both of those things are much more common in other areas. Another big difference is that boats are stored in the water year round here, but are usually hauled out in the winter on the east coast, even in the Chesapeake where it rarely freezes.
Alex W is offline
post #40 of 58 Old 08-31-2013
first sailed january 2008
northoceanbeach's Avatar
There is also more privacy when you are on a mooring. But a slip is more convenient. I would side with a slip, but I would let weather be a major factor in my decision. Anywhere that didn't have perfect weather, I wouldn't even consider a ball. I hate wet dinghy rides, and then you get your boat all dirty. And it's harder to keep clean. Yeah, slip.
northoceanbeach is offline
Wooden Sailboat Breaks Off Mooring And Crashes Into Dock - Patch.com NewsReader News Feeds 0 08-28-2011 09:40 AM
Key West dock and mooring normandavison Cruising & Liveaboard Forum 6 09-22-2008 01:33 PM
Mooring/Dock on Lake George NY SWHibbins General Discussion (sailing related) 0 09-25-2002 03:58 AM
Mooring verces Dock mpin422 General Discussion (sailing related) 9 04-05-2002 01:50 PM
mooring and dock equipment nortoda Gear & Maintenance 2 06-04-2001 05:21 PM
