Sail twist - SailNet Community
 5Likes
post #1 of 18 Old 08-29-2013 Thread Starter
Gregrosine's Avatar
Sail twist
Ow do you trim sails to get twist?
Gregrosine is offline
post #2 of 18 Old 08-29-2013
Remember you're a womble
PaulinVictoria's Avatar
Re: Sail twist
Adjust the various bits of string tied to them
For the main, a combination of mainsheet and traveller, for the jib/genoa, move the car (or the block if on the toerail).
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #3 of 18 Old 08-29-2013
Re: Sail twist
Gross oversimplification:
Close-hauled, with slack vang, less mainsheet tension gives more twist, and vice-versa.
nolatom is offline
post #4 of 18 Old 08-29-2013
bblument's Avatar
Re: Sail twist
I'm not being a wise-guy... being a newbie to sailing, I don't understand how you can be close hauled with less mainsheet tension. Can you elaborate?
Thanks..
Barry
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza." - Dave Barry
bblument is offline
post #5 of 18 Old 08-29-2013
Re: Sail twist
Still simplified....
It comes from a combination of traveller setting and mainsheet tension. In light air many boats respond well to a traveller position to windward, reduced sheet tension, but the boom still near the centerline.. the reduced tension (with vang relaxed as nola qualified) allows more twist in the sail because luff tension is reduced. Excessive sheet tension in this condition would put the boom to windward of the centerline and likely stall and/or cause excess heeling.
Similarly in heavier air the traveller is set lower on the boat, reducing angle of attack.. the mainsheet tension can be played to the desired twist, but will require more tension to keep the boom near center (until the breeze builds enough to drop the traveller and let the boom fall away...) With a good traveler setup you can 'play the puffs' to control heel with the traveller alone.. much quicker/easier than dumping/hauling several yards of multipart mainsheet.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
bblument (08-30-2013)
post #6 of 18 Old 08-30-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Sail twist
Great explanation of traveler usage, faster...thx....
but....
Is "twist" soley used to de-power; or is there some other reason. I can get a fair shape using end-boom sheet, vang and cunninham. I see some natural twist when I have enuff breeze. Last Monday's sail was a bit brisk by early afternoon. I ended up approaching the fairway at 5 +/- knots with the boom near out alla the way and the little 85% jib let out right far. Would slacking up on the vang have calmed her down a bit w/o relying on the main being near luffing?? Felt like the wind was running near ta 15 and gusting a bit to 20....mebbe more, I dunno. Got a bit hairy for this sedate-to-date sailor!
I (also) wonder if actually remembering to put the (short) battens will upset my old sails? What effect do battens have when "twisted"? Help or hinder?
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #7 of 18 Old 08-30-2013
Re: Sail twist
Twist gives you different shape at the bottom of the sail to the top of the sail. It can be used to depower or power up a sail depending on how you use it.
Orange Crush
1974 C&C27 MkII
post #8 of 18 Old 08-30-2013
SchockT's Avatar
Re: Sail twist
It comes from a combination of traveller setting and mainsheet tension. In light air many boats respond well to a traveller position to windward, reduced sheet tension, but the boom still near the centerline.. the reduced tension (with vang relaxed as nola qualified) allows more twist in the sail because LEECH tension is reduced. Excessive sheet tension in this condition would put the boom to windward of the centerline and likely stall and/or cause excess heeling.
Good explanation, just one minor correction!
North Sails has some good animations in their tuning article: Here
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #9 of 18 Old 08-30-2013
Re: Sail twist
Right you are, of course...leech, not luff....
Thanks, Schock..
Faster is offline
post #10 of 18 Old 08-30-2013 Thread Starter
Gregrosine's Avatar
Re: Sail twist
Is that what all those ropes are for that are lying around everywhere? Who knew.
Twist ctlow Racing 24 08-12-2013 10:19 AM
Twist in the forestay... sailhog Gear & Maintenance 17 05-20-2009 10:19 AM
what''s up with sail twist? hrae Learning to Sail 15 09-08-2004 04:00 PM
partnership with a twist nhblwfnm Boat Review and Purchase Forum 0 03-03-2002 11:54 AM
Mainsail Twist for Waves Dobbs Davis Racing Articles 0 03-23-2001 08:00 PM
