When Lightning Strikes - SailNet Community
 9Likes
post #1 of 41 Old 09-05-2013 Thread Starter
Ok, another Green-horn question... I have been surfing the web trying to find info on what happens when the boat you are gets struck by lightning. There is a ton of stuff about what can happen to the boat but nothing on what happens to the boat's occupants.
Anyone have the joy of this experience who can shair without a senace?
wannabsailor is offline
post #2 of 41 Old 09-05-2013
MarkofSeaLife's Avatar
Dock
Re: When Lightning Strikes
Everyone dies.
Dead.
Fried.
Kaput.
The reality is that you can't change the effect of lightning strike on a boat with any sort of lightning arrestor(etc), nor can you change it on land. So you have the same chance of being hit on a boat as on land.
The good news is is very rarely happens.
I have been on the pick in some areas where the lightening just doesnt stop: Colon in Panama was one storm for 3 days... damn stuff hitting the water, trees and buildings everywhere except not a boat!
The very few people who have been hit have their electronics fired. So disconnect what you can. I turn off my electricity and disconnect my handhelds and laptops.
Apart from that, no one has been killed or injured on a boat that I know of.
So just dont worry about it. Similar to all the threads about hitting containers at sea. Some things only happen once in 10 million... but you may win the lottery as well!
Mark
tomandchris likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #3 of 41 Old 09-05-2013
snake charmer, cat herder
zeehag's Avatar
anything and everything can happen..friends of mine were in cartagena and were struck by lightning -- trimaran--their carbon fiber mast on their return to zihuatenejo then ultimately sd via mazatlan, shattered when they were off nicaraugua--
some other friends sustained a hit while in la cruz de huanacaxtle, and their wifi antenna was what was hit, and the conduction caused a burn in their electrical panel and some fail in their electrical system...
i know a boat in louisiana that was hit twice-- was in same place both times--at the dock behind the house they owned--- first time the boat took about a year to repair---dont know the damages--second time it was a write off---sunk at dock, and the electrical cord was burned half way to his house...oops......
anything is possible.
another friend was hit and sustaned minimal damages-- electronix were damaged..... different boats different damage and different bolts each hit different...cannot be predicted.
the storms can be predicted, the lightning hits cannot. and yes it does hit same place twice.
formosa 41, cruising tropics
zeehag is offline
post #4 of 41 Old 09-05-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
A Hunter..mebbe a 34 footer was hauled out at our marina a few weeks ago. Apparently struck while out on the Bay summeres.
Had a nifty bend in the mast; purportedly by having the heat near melt it whie going down, mebbe a 6 or 8" bow in the middle...from tension on the guys, I suppose. Also had two blown out and charred spots on the hull at the fwd waterline at the exit points. Onr, no bigger than 2.5 " and the other could be covered by a dollar bill.
Not too much ta fix those ( IF they were the only hull damage!) but the mast was toast, as was the rigging, prolly.
Sad; but it happens.
scgator2001 likes this.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #5 of 41 Old 09-05-2013
I've been lucky enough to have the closest lightning bolt hit the water about 100 feet away from me, a long time ago.
But lots of lightning in the steamy Gulf south, so I tell my sailing students (usually in daysailing-type sport boats) that I'll put as many of them inside the very small cuddy cabin as possible, and the rest of us on deck will get sails down early and try to avoid touching anything metal, such as stays or mast/boom, or even lifelines. The point is to not be a ground conductor, meaning don't form a pathway for a charge to pass through you. Let the rigging and the wet decks dissipate any charge.
I hope I never have to find out if this is the right advice. Better to get in before the squall, but not always possible.
jimkyle99 likes this.
nolatom is offline
post #6 of 41 Old 09-05-2013
Warm Weather Sailor
Vasco's Avatar
Do a search. I posted here a while ago about being hit by lightning while sailing. I'm still alive. What usually happens is you change your underwear.
arf145, tomandchris and jimgo like this.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #7 of 41 Old 09-05-2013
Sadly I can't directly answer your question, but I'm pretty sure "dead" isn't the answer. I've not heard of a fatality on a sailboat that was struck. There was a sailboat struck at my marina a year or two ago; it and a few of its neighbors lost all electronics but I believe there was no other damage. I assume at least one of those boats was occupied at the time (many liveaboards here), but I don't know for sure.
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #8 of 41 Old 09-05-2013
Bristol 45.5 - AiniA
We were hit going to Bermuda in the early 80s. The remarkable thing was how long it took to be hit with strikes all around us for 20 minutes of more before. Burnt out all the nav lights and the engine's voltage regulator. The person who was holding the wheel did not feel anything. The effects seem remarkably capricious.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
The Following User Says Thank You to killarney_sailor For This Useful Post:
scgator2001 (09-10-2013)
post #9 of 41 Old 09-05-2013
Minnesail's Avatar
It seems staying on the boat is safer than getting out. There was a tragedy last fall on Lake Superior in which a 9-year-old boy died from a lightning strike.
They were in a swing-keel boat, so they headed for shore and beached it. They got off and were wading in when it happened. Very sad.
Iron River boy dies after lightning strikes family seeking shelter with sailboat | Duluth News Tribune | Duluth, Minnesota
Minnesail is offline
post #10 of 41 Old 09-05-2013
scratchee's Avatar
Originally Posted by Vasco View Post
...I'm still alive. What usually happens is you change your underwear.
I assume your underwear had burn marks?
scratchee is offline
Lightning strikes once. richard_reinhart Gear & Maintenance 18 07-24-2009 02:24 PM
Storm Registers More Than 100 Lightning Strikes - Ruralnorthwest.com NewsReader News Feeds 0 06-06-2007 08:15 PM
