Raising sail on mooring. - SailNet Community
 2Likes
post #1 of 14 Old 09-06-2013 Thread Starter
Slayer's Avatar
I sail single-handed on a Cal33 regularly and it is always a challenge keeping the boat in the wind while trying to raise the main. When I race solings we always hoist both sails before dropping the mooring. Can I do that with the Cal too, assuming the boat boat is pointing into the wind on the mooring (not affected by current). If so, what are the pros and cons?
Slayer is offline
post #2 of 14 Old 09-06-2013
Re: Raising sail on mooring.
Sure you can... as long as you're sure you can fall off, gain steerage and sail off cleanly without hitting nearby moored boats downwind.
Faster is offline
post #3 of 14 Old 09-06-2013
cons on raising an overlapping jib while you're still head-to-wind are that the forward part may fill onto the "wrong" side and carry the bow where you didn't want to go (if you don't mind either tack for departure, then this doesn't matter. the Pros are that with the jib, once you're ready to bear off from the mooring and start sailing, all you have to do is back the jib by pulling whichever sheet is opposite the way you want to turn.
Keeping her into the wind with main up while moored can be tricky, she'll yaw back and forth and try to 'sail' prematurely. Sometimes keeping the mainsheet semi-taut helps, then the main acts like a steadying sail and heads you back up as soon as it starts to fill near the leech.
Some boats try to start sailing when you don't want them to, others are slow to start sailing (particularly with main alone, you may have to ease the sheet a lot) even when you want her to. I found it best to just "use the force, Luke.." and wait til she starts swinging the "right" way, then drop the mooring pennant, trim your jib first with main eased, then trim main, and off you go.
And while raising the main, same idea. don't heave while she's partially filled, wait til she swings back to head to wind, haul up quick, stop if she bears off again, wait til she rounds back up, then haul hard on the halyard whenever she cooperates and luffs the main, however briefly.
You'll get the feel of it in time. (easy for me to say, I'm at a desk which generally doesn't yaw)
blowinstink likes this.
nolatom is offline
post #4 of 14 Old 09-06-2013
Yorksailor's Avatar
I do it all the time with a 55 ft boat. Usually easier to do things just under main with the jib ready to fly.
I keep the jib reefed at 90% so as to make it manageable while maneuvering.
I preset the reef in the main so that I am raising the right amount of sail
I wait until she is just staring onto the favored tack before I release.
Only time I do it under engine is if I am likely to hit another boat because of very light or heavy winds or a current that will override my ability to sail at low speeds.
If you don't practice on the nice days how are you going to do it at night, in an emergency, with a broken engine?
Yorksailor is offline
post #5 of 14 Old 09-06-2013
Coquina's Avatar
You can push the boom forward and reverse off the mooring
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #6 of 14 Old 09-06-2013
DrB
Another 33ft Boater...Do it all the time
We do it pretty much all the time unless it is blowin' like stink. Here is our process:
  • Move port side pennant to the starboard side cleat
  • Bring p/u stick through front triangle onto other (out) side of pulpit
  • Raise main
  • Back main/boom and with wheel, turn boat in direction we want to sail off.
  • Release boom, go to bow, cast off pennants and p/u buoy away from boat
  • Return to cockpit, bring in main sheet to trim sail and start sailing.
  • Once we are clear of our mooring neighbors and into more open water, then we unfurl jib.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #7 of 14 Old 09-06-2013
ASA and PSIA Instructor
You absolutely do not want to raise a jib of this size when you still face the task for going forward to drop the pennant. Doing so runs the risk of personal injury from the flailing jib clew, or being pushed overboard when the sail backs. A good rule is to never go forward of the mast when the jib is luffing.
Drop off under main as others have described, then raise the jib.
sailingfool is offline
post #8 of 14 Old 09-06-2013
tommays's Avatar
It REALLY depends on the mooring field spacing and weather
In Northport depending on wind direction and strength I may have less than one boat length and 6 seconds between dropping the pendant AND SPRINTING back to the wheel to start sailing
On other days there is much more space and things happen real slow
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 14 Old 09-06-2013
sailpower's Avatar
I learned to sail on a Soling in Boston Harbor.
Slack the mainsheet, raise the main and let it luff. If you want to sail off on starboard tack, sit to starboard with the tiller pulled toward you. Have the jib sheeted on the starboard winch and let it backfill which drives your bow to port. (it will not be flogging because it is full). As the bow starts moving, drop the mooring and tighten the mainsheet. When close hauled, release the starboard jib sheet and haul in on the port sheet.
If you want to leave on port tack, substitute port for starboard in the above and same thing.
The tricky part is dropping the mooring if you are by yourself. You may have to tie the tiller over after the main is up, go to the mast to raise the jib while it is sheeted where you want it, step forward to drop the pennant and go back to the tiller.
It sounds more complicated than it is.
sailpower is offline
post #10 of 14 Old 09-06-2013 Thread Starter
Slayer's Avatar
Thanks all. I probably wouldn't let out the Jib on the mooring. I have no problem letting the jib out while underway as it is on a furler.
Slayer is offline
Duarte Marine Makes Mooring Easy, Debuts First Single-Handed Mooring System - PR Web NewsReader News Feeds 1 10-06-2011 01:58 PM
Raising the sail davidpm General Discussion (sailing related) 10 08-01-2008 12:43 PM
Pile Mooring - Mooring Line Stretch? lrak Gear & Maintenance 2 06-12-2008 07:59 AM
Why does boat sail on the mooring? hullcurves General Discussion (sailing related) 4 05-10-2008 03:15 AM
Raising sail alone dahoser Learning to Sail 17 08-14-2005 02:37 PM
