series drogue or para anchor? - Page 2 - SailNet Community
 16Likes
post #11 of 49 Old 09-06-2013
Re: series drogue or para anchor?
It took me a LONG time to become a believer in the JSD for that very reason (stern-to waves seems wrong). I'd read the Pardy book as well and saw the "common sense" in the bow-to approach.
However, after lots of research, and especially after reading Hal Roth's "Handling Storms at Sea", a more recent heavy weather book than the Pardy's, with its very meticulous comparison of the various tactics...I became a believer.
I also agree with Jack above on the issue of how your boat is set up to handle a boarding wave. Ours is pretty well set up to deal with such an occurrence (relatively small and shallow cockpit, top-down companionway entry - not vertical with large hatchboards, pretty good drains, etc.) - to a degree of course.
Anyway, all this is certainly hypothetical for me. And I hope it stays that way. But I definitely trust Hal Roth's take. So the JSD for me.
Let me be clear, I have the utmost respect for the Pardeys, what they've accomplished, and what they've learned and passed onto other sailors... However, I feel their recommendation regarding sea anchor tactics are very specific to the sort of full-keeler they sail, and have become outmoded when applied to the more moderate or split underbody designs most of us sail today...
If anyone has managed to get their bridle system using snatch blocks to work during a storm at sea, I'd love to hear about it... Hell, I've never managed to get their setup using a pennant riding on the anchor line with a snatch block to work at anchor, much less in large, confused seas offshore :-)
I've laid numerous times to a bridle in open roadstead anchorages, or harbors with a surge, in an effort to reduce rolling... Baracoa, Cuba, is a classic example of a place where the ocean swell wraps around into the anchorage at a deep angle to the prevailing wind, without a bridle the rolling would be very uncomfortable...
But in my experience, the only thing that works is to have the pennant FIXED to the main rode, and adjusted at your primary winches. Trying to use a snatch block as the Pardeys claim they do, it's just a matter of time before it moves up or down the rode, and I'd invite anyone who has had success using their setup in heavy weather to explain how they managed it... I suspect many who endorse this techinque have perhaps read Lin & Larry's book, or watched their video, but have never actually tried this approach in heavy weather offshore :-)
Evans Starzinger does a pretty thorough job of de-constucting the 'myth' of the viability of the use of a parachute in this fashion, although the bolded emphasis is mine :-)
9a. How about the bridled para-anchor technique?
As mentioned above, we generally think the para-anchor tactic the least useful because it prevents you from sailing away from the worst weather and is difficult to change/adapt as conditions change. The bridled para-anchor deployment approach is the most complex possible way to deploy the para-anchor, with the most points of potential failure and human error. Those are bad traits when fatigued in severe storm conditions. Virtually every crew we know who has tried the approach in real storm conditions has considered it a failure. So, we like this 'bridled' approach even less than the 'over-the bow' approach.
We believe the bridle approach violates three fundamental principles regarding breaking wave tactics.
(1) An essential guiding principle for surviving breaking waves is to keep either the bow or stern pointed into the waves. The bridle technique violates this principle by setting the boat up at about 50 degrees to the waves.
(2) An essential principle of para-anchors is that big ones are needed to keep the boat in place through big breaking waves. The bridle technique again violates this principle by (at least in the Pardey's technique) using a much smaller para-anchor. It is a simple fact of physics that a boat with its head 50 degrees off the waves hanging on a smaller para-anchor is more likely to roll than one with head directly into the waves on a bigger para-anchor - head off the waves means greater surface area exposed to the wave impact, smaller para-anchor does reduce immediate shock loads but it does so by allowing the bow to move backwards through the water increasing the likelihood of being rolled; the bridle solution spreads some of the para-anchor effort to the aft bridle leg reducing the force keeping the bow up. It can be argued that the extra risk is not a significant factor compared to the extra motion comfort and somewhat reduced shock loads, but in an absolute sense there is some amount of increased risk.
(3) An essential guiding principle of all heavy weather tactics is that they should be simple and easy to execute, difficult to mess up even when it's pitch black and raining, with waves washing over the deck and an extremely fatigued crew, and relatively easy to adapt to changing storm conditions. The bridled para-anchor approach is none of these things.
A core assumption of the 'bridled small para-achor' approach is that creating a 'slick' (e.g. turbulence in the water upwind of the boat caused by the hull and keel drifting to leeward) is a significant factor in stopping waves from breaking on the boat. We question this assumption. First it is essentially impossible to hold a vessel with exactly zero forward motion and thus actually directly behind any potential 'slick'. If the boat has even 1/2kt of forward drift, it will be moving 50'/minute. In which case the slick will angle aft and the boat will always be right at the forward edge of the slick. Thus a wave coming from directly downwind or forward of that will be able to reach the boat with minimal interference from the slick. Second, it is equally clear that the effect dissipates very quickly as it moves away from the hull. The effect is impossible to discern more than about 10' from the hull. It will certainly not have much effect on the really large breaking waves that are the true danger. John Neil, who likely has more miles and heavy weather experience on a 'modern' cruising boat (a Halberg Rassey 46) than anyone, agrees: "My experience (and it's a fair amount now) is that the entire 'slick' reducing breaking waves concept is not at all realistic".
Here is a great video of a real breaking wave (not just the more common breaking crest) that a hull slick would not have any significant effect on. In contrast we would consider most of the action in this video to be breaking crests, still dangerous to a sailboat but not the worst case breaking waves. The hull slick is just too near the boat and too narrow to affect a massive wave like that in the first video clip, which will already be breaking in a huge 30kt landslide of water by the time they hit the hull slick and often come sliding in at an angle different than the hull slick angle. Further the 'slick' will have zero affect on some of the most dangerous waves - those where two different wave trains become synchronized and form extremely steep pyramid-shaped waves and/or create 'bottomless troughs' - because these dangerous wave shapes are created by wave energy that runs deep underwater and is not affected by any surface 'slick'. These were the sort of waves identified as most dangerous in the Queen's birthday storm.
If the slick was as valuable a factor as suggested then lying a-hull, which creates an even wider slick than lying hove-to, would be an effective tactic rather than being the most dangerous possible technique. The para-anchor may potentially create turbulence at the right distance from the boat, but only with a shortish rode (e.g. 100' is about right but 300' is too far from the boat) and obviously a bigger para-anchor will create wider more effective turbulence than a smaller one. Interestingly, the slow speed steady state drift rate of the big and small para-anchor are in the same range (e.g. .5 - 1.5kts) in heavy weather. The extra drag of the bigger para-anchor comes into effect when a breaking wave actually hits, and prevents the boat from accelerating more effectively than the smaller one.
As a final practical point with the bridle approach - we have never found a chafe-free way to lead the bridle legs in over our toe rails. We also have concerns about engineering the bridle so it is strong enough for Hawk's expected loads (about 20,000lbs loading in the worst case breaking wave). The strongest available snatch block is not strong enough, so the bridle legs would have to be spliced and then tied or shackled to the end of the main rode. That would be strong enough but would make recovery even more difficult because we would have to work the splice/knot/shackle around the recovery winch.
While much controversy exists as to what actual parachute loads are in storm conditions, there is absolutely no question that worst case breaking wave loads are a high fraction of displacement. There are four ways to estimate these loads, all of which arrive at the same ballpark figure. The only reason there is any debate about how big the loads are, is that big breaking waves are, fortunately, extremely rare.
(1) The physics of a boat falling down a 45-foot near vertical breaking wave are very clear and very impressive. If you are skeptical about the existence of such waves take a look at the video footage of the 1998 Sydney to Hobart (the link is to a report on the storm; we have yet to find video footage on the web). Don Jordan’s web site is one of many that provide a good analysis of these loads and also has another great video of 60' ketch getting knocked down.
(2) Commercial vessel design and experience confirms this order of magnitude loading with big waves - in an article on new findings about big waves: "Most modern merchant vessels are designed to withstand about fifteen tons of pressure per square meter, but these unusual waves exert a pressure of about one hundred tons per square meter" and other testing has found common wave loading of about 100,000-170,000 lbs/sq meter for 7 seconds on static structures*. To return to our own practical experience. There are many many example of actual high wave loading but just to cite one - the 1,000-foot cruise ship Norwegian Dawn encountered a 70-foot wave that broke windows designed for 5 ton/sq meter loads up to the 10th floor.
(3) We have measured the steady-state loads on our smallest Galerider drogue at 3,500lbs (10% of displacement) in a static, non-breaking wave situation. Para-anchor loads will certainly be much higher and worst case breaking wave loads will additionally be much higher. Scaling this load by frontal surface area produces peak load estimates for our series drogue (150 cones) of approximately 10,700lbs and for a 12' dia. para-anchor (the bridle approach recommendation) of 41,000lbs (e.g. 100% of Hawk's actual cruising displacement). The physics are a bit more complex than a simple scaling, so this needs to be taken with a grain of salt, but these are useful ballpark estimates for sizing equipment and attachment points (remember that you need to add a 2x-3x safety factor).
(4) Looking at the wave energy in a storm serious enough to require a drogue or para-anchor is another way to estimate the likely loads. To ballpark the absolute minimum peak load on the para-anchor, in a storm bad enough to make the para-anchor needed, take your 1 degree righting moment (2700ft-lbs for Hawk) x 60 degrees (generally a boat's angle of peak righting moment) / half beam (7' for Hawk) x .5 (nylon rode shock absorbing) = 12,000lbs for Hawk (40% of displacement). This is the minimum loading that you can expect in a storm bad enough it could roll your boat. It assumes that the boat is caught perfectly beam on to the waves, that the wave delivers only just exactly enough energy to capsize the boat and no more, and that the nylon rode acts as a perfect spring and averages out the entire wave load. If the waves don't have at least this much energy then they can't capsize the boat, even if she is lying ahull, and you really don't need to set the para-anchor. In a bad storm the peak energy will be much higher. An upper limit ballpark can be calculated from the case of a vessel falling off a 60' near vertical wave with a 400' nylon rode (properly sized for 15% stretch at a working load of 15% of breaking strength). In this case the peak load will be equal to 100% of the vessel's displacement. These are both rough calculations but they do bound the likely peak para-anchor loads between 40%-100% of vessel displacement, and we use halfway between them (e.g. 70%) in our calculations/equipment sizing.
We would only consider using a para-anchor in one situation: if too close to a lee shore to use our drogue and dismasted so we couldn't forereach and with a broken engine so we couldn't use the trawler tactic of powering into the waves. In that situation we would first try our series drogue and see if the drift rate is slow enough to keep us off the shore, if not we would put out the largest possible para-anchor off the bow. This would minimize leeway and be better and easier (in our opinion) than the smaller para-anchor/bridle technique. Honestly, if you are caught way too close to a lee shore, while dismasted and engineless, you have probably lost your boat no matter what technique you use. Top of Page
*(Note: Recent scientific work on big waves is at ICMS Workshop on Rogue Waves Programme page).
Seamanship FAQ.
John Harries doesn't like parachutes, either:
Large Sea Anchors Not Recommended For Offshore Sailboats
While I do carry a Para-Anchor on my own boat, it would require a very specialized set of circumstances of the sort Evans describes, for it to be my first choice as a storm tactic... If I'm gonna put anything over the side, it will be a Series Drogue first... And, I sail a boat that's "easily pooped", compared to most :-)
And, for the OP, I'd suggest a good light-air sail inventory will be far more important, and see far more use for the trip you have in mind, than either sea anchors or drogues... :-)
smackdaddy likes this.
JonEisberg is offline
post #12 of 49 Old 09-06-2013
I was under the impression that the Pardey method places the boat into a heave to position; not straight off the bow.
benesailor is offline
post #13 of 49 Old 09-06-2013
+1 Jon.
Ralph - you ought to read through this thread:
Heavy Weather Sailing
It's one of the best I've ever seen and covers this whole debate very well I think. Oh, and this one:
Don Jordan and the Jordan Series Drogue
smackdaddy is offline
post #14 of 49 Old 09-06-2013
Master Mariner
capta's Avatar
Having used both in weather that actually requires it, over 60 knots in most cases, I would never use a sea anchor again. I was constantly worried about damaging my rudder as mentioned above.
Towing a drogue also has it's own problems. Though I have not had this happen to me, I have met people who have had their drogues end up in their rigging, which must be a real pain in the a**.
Alternately, I have had a drogue slow me to the point that I was constantly being pooped, filling the cockpit frequently. In the end, the only solution was to cut the thing free and allow the boat to sail unrestricted under bare poles. It is a tremendous amount of work to steer in those conditions, at times surfing across the face of the waves at ridiculous speeds, then pointing the bow directly down wind to allow the white water to pass underneath as it overtakes you.
But if I can keep the boat under control, I feel I am much safer than hampering her with a drogue, so I no longer keep either aboard. Should I ever (Neptune forbid) get into a situation where I feel I should drag something to slow me down, I can see no reason why one or two of my 6 anchors with 30 or so feet of chain, on a long anchor rode, would not do the trick.
facebook.com/svskippingstone
Our Videos;
capta is offline
The Following User Says Thank You to capta For This Useful Post:
smackdaddy (09-06-2013)
post #15 of 49 Old 09-06-2013
Thanks capta. I love hearing directly from those who've used these things in anger.
What kind of boat were you in with the drogue/pooping? I assume it wasn't your center-cockpit shown in your avvy?
post #16 of 49 Old 09-07-2013
Omatako's Avatar
The problem with controlling the situation you describe is that you have to be able to see what you're doing. Mostly when the weather is such that you need a drogue, it is heavily clouded too and then the inevitable happens - the sun sets and it gets real dark.
We had this and in the dead of night we saw huge areas of white water overtaking us on both sides - we were sailing downwind under bare poles and doing 7 to 9 knots. When the boat surfed for the first time in pitch black conditions down what felt like a huge wave with a 10 ft wall of white water chasing us from behind, I knew that whatever else I do in my life, I never want to do that again. When it got light the next morning it was confirmed that the waves around us were 35 to 40 feet and randomly breaking. Nobody chooses to surf that in a 40ft cruising boat - unless you're stark raving mad.
And I don't get the fear of being pooped. So a flood of white water washes over the boat. As long as the boat doesn't accelerate down the rest of the wave and your wash boards are in place and strong, I don't have a huge problem with that. Having said that, I don't really ever want those big patio doors commonly found on ocean going cats these days.
smackdaddy and Brent Swain like this.
Arthur C. Clarke
Omatako is offline
post #17 of 49 Old 09-07-2013
And another. Good lord, Oma, I love "big sailing", but that's sounds like hell.
"Those that go down to the sea..."
post #18 of 49 Old 09-07-2013
FYI, when Herreshoff (I think it was L. Francis) designed his personal short-handed around-the-world sailboat (the Marco Polo design), he included a spade rudder that could turn 360 degrees, to protect it while lying a hull or to a sea anchor.
scotthenry is offline
post #19 of 49 Old 09-07-2013
Master Mariner
capta's Avatar
smackdaddy; I've sailed several boats through some pretty extreme storms;
a 46' British built timber yawl, a 65' Wm. Hand gaff ketch (1909), both aft cockpit boats. The gaffer had a much larger stern than the British boat which had a very fine stern and bow, but neither handled well with the drogue out. After releasing the drogue both rose much more quickly to the seas and shipped less water, though the steering of both vessels was still very hard work and extremely tiring. A third boat in an Atlantic storm was a Brown, 37' Searunner tri, and on that, the drogue specifically recommended by Brown, would not allow the boat to go fast enough to safely keep her on the face of the waves when needed. That was a wild ride for 22 hours, but we had no problems after we cast off the drogue.
Omatako,
"The problem with controlling the situation you describe is that you have to be able to see what you're doing. Mostly when the weather is such that you need a drogue, it is heavily clouded too and then the inevitable happens - the sun sets and it gets real dark."
I found that even in the dark, the white water was quite visible, though, quite honestly, 90% of the steering was done by feel, after the first few hours. The stern would lift as the waves approached and I would set her to race across the face, much as a surfer would, then as the whitewater caught up with us it was necessary to put her stern directly into the approaching water (which I could certainly hear, if not see) and slow the boat and let the wave pass under us. Though the noise was terrible, I welcomed the dark, because seeing those waves was a truly terrifying site at times.
I don't know if you've ever had a huge wave mount a boat in heavy weather, but for me the boat became completely unmanageable with several (hundred?) tons of water washing over the stern and filling the cockpit. It doesn't matter how big your cockpit drains are, they are never large enough to rid the boat of the extra weight quickly enough to allow her to rise for the next wave. But if the stern did rise, with all that water rushing forward, I was sincerely worried that she would pitch pole, one experience I dread. Read "Once is Enough" by Miles Smeeton, a book that saved our lives when we were capsized three times in a hurricane (cyclone, if you insist) in the SoPac.
I guess it's different with every boat. I shudder when I see these boats with no transoms or the ones with the huge scoops and stairs on the stern, which in my estimation are an invite for the waves to mount the boat.
I hope never to go through that sort of experience again, because it was very frightening and exhausting. But at least I know that the boats I chose to sail in the past and the boat we are sailing now can take whatever Neptune chooses throw at us and we did and will survive, without asking others to risk their lives to save us. Perhaps that sounds a bit cocky, but at a certain point I have to have that confidence or I'd better stop voyaging.
smackdaddy and smurphny like this.
Our Videos;
capta is offline
post #20 of 49 Old 09-07-2013
Over Hill Sailing Club
smurphny's Avatar
The biggest issue with a sea anchor would seem to be the many variables in getting it set and working as it should. Getting it positioned in the right wave set, getting a snatch block to sit in the right place to keep the boat quartered, just getting it over the side without fouling in heavy weather would be a challenge. The deployment of a sea anchor presents many more potential problems than a drogue. Also, being that this is not a routine procedure means that you will not practice using a sea anchor to the extent whereby you really feel confident in the procedure. I have a laminated sheet of deployment procedure right in the bag with it :
Deploy Sea Anchor
Check weather, ready all below decks before storm.
Link lines, sea anchor.
Buoy on trip line.
Put snatch block on pennant line.
Chafe gear ready.
All up to cockpit.
Up on deck clipped in.
Heave-to.
Wrap pennant on winch to length, cleat.
To bow on windward side, bring :
Bitter end- cleat on 2 cleats (outside lifelines).
Tie off at approx. half the line (150')
Back to Cockpit
Ready main rig to go over.
Rode ready to uncoil freely.
Trip line/float unclipped and free to pull chute.
Launch over rail to windward. Wait for chute.
To bow with snatch block and pennant chafe gear.
Snatch block on anchor line
Set chute in 2nd wave crest.
Chafe gear on rode.
Adjust pennant, sails, and rudder to stay in slick.
Check hourly, adjust periodically to avoid chafe.
Probably the most important part of this is in doing it well before conditions get too bad.
I have also sewn up a seat belt drogue which I have yet to try.
smurphny is offline
Tags
atlantic crossing , para anchor , series drogue
Video of Jordan Series Drogue deployment... MedSailor General Discussion (sailing related) 42 04-12-2012 09:29 PM
jordan series drogue kimberlite Gear & Maintenance 33 08-04-2011 10:14 PM
Jordan Series Drogue - Quality of construction. pdqaltair Gear & Maintenance 1 06-20-2009 12:31 AM
series drogue chain plates Snboard976 Gear & Maintenance 2 11-28-2008 04:19 PM
Jordan series drogue magnusmurphy Gear & Maintenance 23 05-22-2007 04:41 PM
