Truth on Teak Interior? - SailNet Community
 5Likes
post #1 of 18 Old 09-07-2013 Thread Starter
Hello All,
We went again to see the 1975 Northern 29, he had the Atomic 4 running (on the hard) and both forward and reverse gears were fine. Took out a few sails and they were in great condition. All the Teak is scuffed or just tired out! What is the truth on bringing teak back to it's beauty? Maybe scuffed is not the right wording, it's just from age. I hope to make up our minds soon and the next time we have to drive 4 hours, it will be to start cleaning and making it ours.
Anyway, as usual I appreciate all of your advice.
Thanks,
Kalina-Lona is offline
post #2 of 18 Old 09-07-2013
Re: Truth on Teak Interior?
It will come back 100%. I knew a Kalina here, in the 60s.
sony2000 is offline
post #3 of 18 Old 09-07-2013
MarioG's Avatar
Old English oil should make the teak look good again. I use it on my 79 Endeavour interior and it it looks great.
I would be worried about the impeller if he is starting it on the hard with no water running thru the raw water intake.
Endeavour E-32 "Samara"
I am the Capt of my ship but sometimes I think I had more fun just being the cabin boy.
MarioG is offline
post #4 of 18 Old 09-07-2013
Have a look at this earlier topic:
Teak Interior Help
Seaduction is offline
post #5 of 18 Old 09-07-2013
JulieMor's Avatar
If you're talking solid teak, you can bring it back to life. If you're talking teak veneered plywood, it's only as good as the thickness of the veneer, which isn't much. If it's scratched and you try to sand it smooth, you can easily sand through the veneer. If it's gouged through the veneer, you might try to patch it with a matching putty or just leave it and live with it.
JulieMor is offline
post #6 of 18 Old 09-07-2013
Over Hill Sailing Club
smurphny's Avatar
You might try Tung Oil as well. Wipe hard with a kitchen type spray cleaner to remove film and old dirt and then, after it dries, wipe on Tung Oil. I did this to my old faded teak interior and it came out like new. Try to avoid sanding through the old surface unless you're ready to completely refinish the whole thing.
smurphny is offline
post #7 of 18 Old 09-07-2013
kunkwriter's Avatar
You can sand it, or wipe it with a bit of oxalic acid. It'll come back. The acid works easily and if scrub it on, then rinse it off it will bring out the color without bleaching. Leave it on and it will bleach it a bit. I've used it a few times on my own before varnishing on the interior.
kunkwriter is offline
post #8 of 18 Old 09-07-2013
Senior Moment Member
SloopJonB's Avatar
The sole in my boat is high quality vertical grain fir. There are some black spots where the varnish was neglected and the wood got wet. PO's fault of course.
If I sand/scrape the varnish off will Oxalic remove or bleach out the black spots?
SloopJonB is online now
post #9 of 18 Old 09-07-2013
poopdeckpappy's Avatar
Yes, even TSP will help remove some mold
SloopJonB likes this.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #10 of 18 Old 09-07-2013
smurphny's Avatar
It'll make it brighter but probably won't blend it back into the old wood unless it's fairly recent. If you sand the heck out of it and remove 1/16" or so, maybe you could get it. Discoloration/mold goes pretty deeply into softwoods like fir, pine, and spruce. Try hitting just the spots with full strength wood bleach. A little matching colored pencil or wood matching liquid pencil can work wonders before varnishing. An old German carpenter I know had a saying,"A leetle pooty a leetle baint, make id look vat it ain't."
davidpm and SloopJonB like this.
smurphny is offline
Teak Interior Help Mako144 Gear & Maintenance 15 06-03-2013 08:43 AM
P30 Interior Teak doublec9 Pearson 2 08-29-2012 12:54 PM
What is the best interior Teak Oil? Petar Gear & Maintenance 14 04-29-2010 09:00 PM
Interior Teak jongoose Cabo Rico 12 06-23-2009 12:18 AM
Interior teak lindaamstutz Gear & Maintenance 8 09-02-2001 02:50 PM
