To pull or not to pull.... - Page 2 - SailNet Community
 2Likes
post #11 of 14 Old 09-09-2013 Thread Starter
blutoyz's Avatar
Re: To pull or not to pull....
Thanks for all the opinions...
I will play it by ear for now but I am leaning towards the haul. There were a couple of really strong arguments but "peace of mind" was the strongest.
blutoyz is offline
post #12 of 14 Old 09-09-2013
Unless you really want to save the money, haul it. The winds are generally much stronger over the winter months around here and you'll have to worry about a fender jumping the dock or the bilge pump not working, etc.
It would be much easier to work on at the dock over the winter, except hull work. However, it just gets too cold in my book to really work aboard for any length of time from Dec to Mar. Most of my projects are taken home during the winter.
Jeanneau 54DS
Minnewaska is offline
post #13 of 14 Old 09-09-2013
tommays's Avatar
Keep in mind all thees pictures are 2009 and later
jimgo likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 14 Old 09-09-2013
pdqaltair's Avatar
Very location dependent, obviously. My experience is central Chesapeake.
* Snow load. Generally boats bear heavy snow better in the water, unless there is a very carefully constructed cover. However, you need to be certain your cockpit drains stay clear and that no anticipated load can cause water to siphon back into the engine (the boat may be pressed down several inches. Specifically for multihulls (huge decks and no iron keel to set on) the water is far more gentle.
* Minimum temperatures. Actually, a boat in the water seldom goes far below freezing. Though it is still smart to winterize all systems, the temperatures are moderated by the water.
* Burst rudders. Can't freeze in the water.
* Damp. In my experience, with any reasonable humidity management system, this is not a problem. Early spring is worst, when the water is cold but the air warm. Boats on the hard actually see far greater temperature swings.
* Power. I can keep a boat in the water plugged in, but not on the hard.
* Sinking. About like during the summer. At least in any climate where year around sailing is possible (no thick ice) the through hulls won't freeze, and it is not difficult to winterize them anyhow.
* Wind. If a boat is secured for named storms and squalls, winter is not worse. Chafe gear, of course.
* Ice. If you are in a marina where drifting ice is possible, haul. There is no good protection.
* Equipment reliability. Boats that see some off season use have fewer problems since everything (engines, batteries, electronics, hinges, valves, pumps, fuel systems) gets exercise and lubrication. Try parking your car for 8 months.
* Projects. There are VERY few projects that are helped by being hauled. Heck, I can't climb the mast on the hard. The dock is cooler than the yard. I can actually operate all of the systems under full load. Can you run your AC on the hard? Most cannot.
* Biannual hauling. Even with the best paint you will haul ever 2 years. Most projects can be scheduled. But even for this I haul in the summer, since working with paint and adhesives in the Spring is aggravating.
I've done both (early in my boat ownership I followed the crowd) and been MUCH happier in the water. It isn't about the money, not if they would haul and store for free. I'd need paid for lost use.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
Is this mechanic trying to pull one over on me? Mariner777 Gear & Maintenance 14 06-25-2011 07:02 PM
Pull-Pull Drive Unit for PDQ 36ft. Catamaran Classic mpdoane2 Gear & Maintenance 1 06-21-2011 09:15 AM
Do I really need to pull the mast out? Lidgard29 Gear & Maintenance 13 05-20-2010 07:26 AM
My first pull out. 1stBoat Gear & Maintenance 13 10-25-2008 08:34 AM
