-   -   To pull or not to pull.... (http://www.sailnet.com/forums/general-discussion-sailing-related/103457-pull-not-pull.html)
blutoyz 09-08-2013 10:29 AM
...that is the question.
My pals use a marina that has a recirculation system to keep the ice away from their docks and only charges $16/foot to store there for the winter. They haul every other year so will be there this winter and I was thinking of joining them.
Haul/powerwash, storage, launch there is $33/foot but then I have to wait for them in the spring rather than just prep my mooring and go.
I did put fresh bottom paint this year so it should be good with just a brush from the surface. a scrape on the prop will be necessary I am sure in the spring.
Opinions? Experience? ...what say you:D
Sabreman 09-08-2013 10:48 AM
We haul, the piece of mind over the winter months is worth it to us.
miatapaul 09-08-2013 11:27 AM
Re: To pull or not to pull....
For me it would really depend on if I was going to spend much time on the boat during the winter. One thing to do if you have her pulled out for the winter is try to be one of the last out, so you can be one of the first in and not have to wait too long. I think in RI I would pull it unless you were going to live on it during the winter. There are two ways of looking at it; winter can mean storms, but boats were built to be in the water not land, so often they survive the storms better in the water than in a yard. Especially if your boat or even less controllable another boat comes off it's stands. But it is good for the hull to dry out so it is kind of a toss up. If you do keep it in the water make sure you check the lines often, as chafe is a big issue so if that is not convenient then pull it.
jimgo 09-08-2013 12:54 PM
I like to pull it so I can do work on the thru-hulls and other stuff under the water line. I also find it easier to do some of the work when she's on land because if I drop a tool overboard, it lands on terra firma, rather than in the drink.
Jaramaz 09-08-2013 01:05 PM
Even if there is no ice, that doesn't mean it is not cold. If it becomes really cold then water in the through-hulls could freeze even if there is no ice in the surrounding water (as it is circulating, which the water in the through-hulls isn't). Frozen thrugh-hulls is likely to create problems.
If it isn't very cold on the palce where the boat is - sure, no problem to stay in water. Many are doing that.
The advantage with having the boat in the water is the prolonged season - nearly all year! Sailing on Christmas - an experience.
To stay in water just for saving some $ - not a good argument, I think.
/J
jimgo 09-08-2013 02:25 PM
You also get SERIOUS condensation inside the boat. Great for mold, not so great for you.
Jaramaz 09-08-2013 02:43 PM
Actually, no x2:
Condensation is not a real problem, may even be less of a problem in the water compared to on the hard; it is usually colder on the hard, humidity is about the same.
Mostly too cold for mold. In both cases (water, pulled) one has to decide which strategy to use: closed or open:
Closed means everything should be locked, no air vet at all. One has to ensure all humidity is absorbed, usually in some kind of salt.
Open means ventialtion is open, the more the merrier. Dust and dirt will enter, but humidity is ventialed away.
/J
Sabreman 09-08-2013 05:06 PM
Not statistically, according to BoatUS. They continue to recommend hauling for storm protection. Hurricane Sandy was an exception in their view - many boats floated off their stands. Since they pay the bills, I trust their judgement.
We also like to haul to let the hull dry out. I've seen instances where blisters can form in a hull left in the water continually.
To be honest, by late fall I'm usually tired of the boat and want to catch up with other interests for a few months. When the boat is in the water, I'm always thinking about it's condition. Hauling lets me shelve those thoughts for a while.
BarryL 09-08-2013 06:41 PM
Hey,
I live in NY and keep my boat in a mooring during the season. In the winter my mooring gets hauled and my boat must be moved. I used to have the boat hauled each year, but last year I left it in the water (in a slip, securely tied with dock lines).
For me, the cost difference is major: Under $500 to leave in the water, over $2000 to have hauled and stored.
Now, with good ablative paint that lasts 2 years I plan on spending two years in the water, then hauled out for the winter. With the boat on the hard I can sand and paint the bottom and polish, wax, etc. the topsides.
Since I had my boat hauled in June for some storm related repairs I had the bottom painted, so I will spend winter in the water.
Last winter I thought I would do some sailing but I only got out twice. This winter I will forget about sailing and put a cover on the boat.
I live close to the marina and would be aboard often, at least every other week. I put a small propane heater on, and would often have lunch in the cabin: some hot coffee, a little heat from the propane, and then I would just read a paper, maybe clean a little, i found it very pleasant.
Barry
geronimo69 09-08-2013 10:43 PM
Hi Barry, I'm just curious to where you are based. I'm in Bayshore.
