Replacement Cable for ICOM HM127B - SailNet Community
post #1 of 3 Old 09-10-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
I have an ICOM HM127B Command Mic on which the handset still looks good, but the cable is showing signs of deterioration. It also kept losing the signal when plugged in, and it seemed as though the problem was likely to be a bad solder joint in the cable. I'd like to replace the cable and see if that solves the problem. Does anyone know where I can find a replacement cable?
I did buy a separate mic off of eBay, but I'd still like to replace the cable for back-up purposes. ICom quoted me $45 to diagnose the problem, plus whatever the repair costs are. At that rate, it was easier to buy a replacement, but I like the idea of having a second working mic just in case.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #2 of 3 Old 09-10-2013
Large Member
Re: Replacement Cable for ICOM HM127B
There was an issue on some of the Icom cables. I believe they are replacing them for free. It may depend on the model. Might want to check with Icom.
mdbee is offline
post #3 of 3 Old 09-10-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Thanks! I did contact them, and they said nothing about it. I'll call them tomorrow.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
Need to extend Icom M802 power cable. Need advice britsailor007 Electronics 9 06-06-2010 04:21 PM
Splice an Icom mic cable? JeffBurright Electronics 1 08-31-2009 05:59 PM
Control cable replacement j34035 Gear & Maintenance 2 08-10-2009 01:20 PM
Steering Cable Replacement zoom555 Gear & Maintenance 26 06-03-2008 05:20 PM
Trailer winch cable replacement Classic30 Gear & Maintenance 18 09-23-2007 09:04 PM
