Thoughts / Titanium thru hulls and marelon valves - SailNet Community
 2Likes
  • 1 Post By Maine Sail
  • 1 Post By tommays
post #1 of 6 Old 09-11-2013 Thread Starter
Given the almost nonexistent corrosion issues with the combo of titanium and marelon valves; and, that the price is about a wash compared to a bronze combo........
Why wouldn't this be a good idea?
I could definitely see the pro's VS the cons.
People say that won't use marelon for seacocks, yet, forespar swears by them as others.
Titanium speaks for itself.
http://www.forespar.com/pdf/930136-m...comparison.pdf
benesailor is offline
post #2 of 6 Old 09-12-2013
Over Hill Sailing Club
smurphny's Avatar
Re: Thoughts / Titanium thru hulls and marelon valves
I've considered Marelon but when thinking about how long it would take to saw through a piece of plastic as opposed to a bronze fitting, it seems less than a good idea.
smurphny is offline
post #3 of 6 Old 09-12-2013
Maine Sail's Avatar
That data should be taken with a grain of salt.... That data uses DAM or dry as molded numbers not after submersion numbers.
Marelon is made of Dupont Zytel nylon 70G13L. If you look up that data, on the DuPont link below, it will give you the dry and wet numbers, DAM (dry as molded), 50% RH and 100% RH, which are considerable weaker. These changes are likely why so many have snapped handles off Marelon valves or broken thru-hull fittings. IMHO I find it a little disingenuous to use DAM numbers to meet UL or ABYC standards when you know the part will always be at 100% RH testing levels because it is designed to be submerged.. These parts will never be at DAM levels but that is the data they use. Something to ponder anyway..
The differences in data are because nylon is hydroscopic and weakens in water. Bronze and titanium will not do this so their numbers remain consistent wet or dry. There are benefits to Marelon, like no corrosion, but they are certainly not as strong...
DuPont Zytel
capta likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 6 Old 09-12-2013
tommays's Avatar
I take a Groco BV Series over plastic 100% of the time
smurphny likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 6 Old 09-12-2013
Omatako's Avatar
That's an interesting installation - tell us how it works please. To the untrained eye, it looks like a disc of nylon epoxied to the boat skin with a valve through-bolted to the nylon disc.
I'm sure there is more to it than that.
Arthur C. Clarke
Omatako is offline
post #6 of 6 Old 09-12-2013
Maine Sail's Avatar
[QUOTE=Omatako;1088008]That's an interesting installation - tell us how it works please. To the untrained eye, it looks like a disc of nylon epoxied to the boat skin with a valve through-bolted to the nylon disc.
I don't think it is nylon it looks like it is G-10
______
Basics of Seacocks, Thru-Hulls, Valves Jaywalker Gear & Maintenance 16 03-16-2016 07:24 PM
Marelon Thru Hulls/Sea Cocks Harborless General Discussion (sailing related) 15 05-24-2011 03:31 PM
can I use bronze ball valves w/plastic thru hulls? nightowle Gear & Maintenance 6 04-20-2009 02:16 PM
Newport 27 Thru-hulls and Gate Valves jimmiebuchanan Newport 8 07-26-2008 06:16 PM
