What can i use to cover my stays? - SailNet Community
post #1 of 18 Old 09-13-2013 Thread Starter
Smile What can i use to cover my stays?
I have a 30ft Grampian, I would like to cover my stays with some sort of pvc or plastic cover/insulation to prevent my genoa from tearing on them when tacking. What do you use? What will work? any info would help....
Also looking for someone experienced in sailing the Hudson river to take a trip to NYC on my boat October 11-15....
Grampian1989 is offline
post #2 of 18 Old 09-13-2013
old guy :)
rikhall's Avatar
Re: What can i use to cover my stays?
Why is your sail tearing? Are your stays frayed?
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #3 of 18 Old 09-13-2013 Thread Starter
Rik
The Stays are in great condition, No fraying on any of them. I can see the bottom of my genoa starting to fray (needs to be sewed). I am assuming this is from rubbing on my stays.
post #4 of 18 Old 09-13-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
they have covers you can buy. Or you can cut down some PVC pipe from one of the big box stores and slip them over the turnbuckles.
They also have spreader covers to keep your sails from catching and tearing up high
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 18 Old 09-14-2013
Master Mariner
capta's Avatar
Shrouds?
facebook.com/svskippingstone
Our Videos;
capta is offline
post #6 of 18 Old 09-14-2013
Learning a bit every day
FinallySailing's Avatar
Hi, I use a length of white waste pipe on my side stays/shrouds to protect the genoa. Bought them at a diy store for 2 for a 2 meter length. The manufacturers imprint wiped off with acetone. You have to be able to take the stay down to slip them over the wire. There are also pipe covers available here to clip around central heating pipes (they have a seam all the way along) if you don't want to take the stay off.
Yet my heart hammers now, yearning anew
wanting the steep salt-water road
longing with lust to roam rough seas, alone
to seek out some far foreign shore
From "The Seafarer", an Anglo-Saxon 10th century manuscript.
FinallySailing is offline
The Following User Says Thank You to FinallySailing For This Useful Post:
kegggggggg (09-14-2013)
post #7 of 18 Old 09-14-2013
4KSB driver.
SHNOOL's Avatar
Had a bunch of 1" PVC kicking around the house... cut to 3 feet... done.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #8 of 18 Old 09-14-2013
If the bottom of your genoa is showing wear it could be catching or rubbing on the cotter pins at the turn buckles. Make sure they are recessed into the turn buckles and then cover with rigging tape. However you will want to leave them open at the top and bottom so that water can pass threw. I have always been told that those stanchion covers trap moisture and will shorten the life of your standing rigging. Sort of makes sense, they will allow moisture to get trapped on the cables.
Just my .02
Peter
justified is offline
post #9 of 18 Old 09-14-2013
Mechsmith
WM has both the shroud covers and rollers that work well together.
Seafarer 29 KCB
Mechsmith is offline
post #10 of 18 Old 09-14-2013
That's another reason why I am using cheap white plumbing pipe. Its open top and bottom and can freely spin around the rigging wire.
Dodger windows - cover or not cover? Gene T Gear & Maintenance 17 10-12-2010 03:50 PM
LN Stays'l Marcvet General Discussion (sailing related) 2 11-15-2009 04:30 PM
removing stays shipley Gear & Maintenance 2 10-01-2004 11:57 AM
what stays, what goes? tybeefolk General Discussion (sailing related) 6 01-10-2004 03:34 PM
