Track question - SailNet Community
post #1 of 4 Old 09-17-2013 Thread Starter
Dave_E's Avatar
Track question
Hi All,
My new boat Traveler has 2 geanoa tracks per side (for lack of a better name to call them). They both have some pretty heavy duty track cars on them. One track is up close to the cabin house and the other is on the rail outboard of the stancheons. I have a 150 genoa on the furler now and it definitely uses the outside track, then up to the winch. What is the inside track for? A working or storm jib?
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 4 Old 09-17-2013
ASA and PSIA Instructor
Re: Track question
Assuming tracks of similar length, the inside track would be for jib trimming, especially closehauled where the inside location permits sailing closer to the wind.
The outside track can be used for jib trimming when reaching (use a temporary short sheet), and for spinnaker blocks.
sailingfool is online now
post #3 of 4 Old 09-17-2013
4KSB driver.
SHNOOL's Avatar
Dock
Re: Track question
Um... outside the lifelines is likely for twings or tweakers for a spin.. inside the lifelines would be for the genoa. If you were talking about tracks inside the shrouds... then we have another ball of wax.
No wait, looking at the doghouse (from a sister ship)
... your cabin comes nearly out to the lifeline...I so Suppose outside is nearly as close as inside, so you could use either. Sheeting angle on your genoa would be BETTER closer in, which would mean sailing closer to the wind... but if unfurled your genoa easily clears the lifeline using the outside one it would mean easier walking forward, in that narrow catwalk.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is online now
post #4 of 4 Old 09-17-2013
I don't discuss my member
zz4gta's Avatar
Re: Track question
Are the tracks the same length?
How do you know the 150 ONLY uses the outside track? Does the foot touch the chainplate and end of spreader at the same time?
Merit 25 # 764 "Audrey"
zz4gta is offline
gpx track davidpm General Discussion (sailing related) 2 02-24-2012 10:58 PM
The right track for sail track Skipper Joe Gear & Maintenance 4 07-26-2011 10:26 AM
Sail slug track gate question? OldBlue P30 1 07-13-2011 03:00 PM
jib track on CD 25D craigw Gear & Maintenance 0 11-15-2009 08:53 PM
Water Heater and Mast Track Question dave6330 Gear & Maintenance 3 08-06-2007 01:10 PM
