Jib sheets stiff - SailNet Community
 2Likes
  • 1 Post By Gary M
  • 1 Post By MarkofSeaLife
post #1 of 8 Old 09-17-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Jib sheets stiff
My jib sheets are getting really stiff and they occasionally kink at the fairlead block near the winch during a tack. I am always carefully coil them up and hang them at the bow after every sail. They are fairly new but I don't think they are the highest quality.
Are there any tricks out there to soften them up a bit?
kellysails is offline
post #2 of 8 Old 09-17-2013
Re: Jib sheets stiff
could be the way you coil them, inducing twists in the sheets.
How about washing the salt off of them, in fresh water?
just guessing
ParallaxView is offline
post #3 of 8 Old 09-17-2013
Gary M's Avatar
Every fall after the mast is down I put all of my sheets, halyards etc in my wife's washing machine (when she is not looking) and wash them. Add a fabric softener and you will see a big difference.
kellysails likes this.
Gary M is offline
post #4 of 8 Old 09-17-2013
I don't discuss my member
zz4gta's Avatar
They get stiff from wear and being loaded, but mostly the stiffness is due to salt and dirt in the lines. I was all my running rigging in the tub a home with fabric softener and it does help.
Doesn't hurt the line either. Some looser braids can come apart if washed in a machine. I'd stick to the tub method.
Another thing to try, is coil your lines in a figure 8 so you're not putting twist into them.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #5 of 8 Old 09-17-2013
You can try simply towing them behind the boat for a while (no prop!) to get any kinks out and let them straighten. But after that-
Front-loading washing machine, just a little soap (not detergent) or plain warm water. Put the sheets in lingerie bags (there are some stronger similar bags sold under the "Tide" brand now as well) or pillow cases. Then air-dry, laid out in long runs if you can.
Getting out the salt crystals also prolongs the life of the line, as they act like fine sand and cut it apart from the inside out.
I haven't tried fabric softener but it shouldn't hurt, it is usually some type of water-soluble wax.
hellosailor is offline
post #6 of 8 Old 09-17-2013
manatee's Avatar
" We prefer not to splice used rope - for many reasons. So if we agree to work on your used rope - we will ask you to first wash it with soap flakes. Put the coiled gasket of rope (see instructions in the Rigger's Apprentice) in the washing machine on gentle cycle. rinse well, and add fabric softener. Then undo the coil and loop it around the garage to dry in the air or take it outside and do the same. Now your rope will be soft and much nicer to handle."
From Brion Toss: Brion Toss Yacht Riggers, Sailboat Rigging
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #7 of 8 Old 09-17-2013
MarkofSeaLife's Avatar
Dock
Originally Posted by kellysails View Post
My jib sheets are getting really stiff ...
Don't excite them.
blutoyz likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #8 of 8 Old 09-17-2013
CLucas's Avatar
Send a message via AIM to CLucas
I suggest a somewhat loose daisy-chain in your sheets before washing so they don't come out in a big rat's nest. I use Dreft or Woolite on my sheets and add some Oxyclean as well. Don't put them in the dryer -- take out the daisy-chain and let them air-dry in the basement.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
Tender or Stiff ricccccc General Discussion (sailing related) 12 09-06-2012 10:09 PM
Stiff steering LuckyMon Announcements and Suggestions Box 2 05-01-2012 10:20 PM
Stiff Steering chandlerman Gear & Maintenance 11 07-16-2010 09:10 AM
stiff controls Kiltmadoc General Discussion (sailing related) 3 06-08-2010 10:12 AM
throttle stiff houserne Gear & Maintenance 0 08-23-2004 10:50 AM
