This curious nautical language - Page 2 - SailNet Community
 3Likes
post #11 of 25 Old 09-19-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: This curious nautical language
My references all come from H.A.Calahan's "Learning to Cruise" written in 1934. Not all that long ago and yet all but one of those terms has either disappeared or been replaced by close variation.
Halliard more commonly spelt Halyard today. I'd never seen the Halliard spelling before this.
Blackwall Hitch is still in use it seems. Handy Billy is a form of black and tackle.
Dandy and/or Jigger is a form of mizzen sail, most commonly seen on yawls.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #12 of 25 Old 09-19-2013 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Since the original term was "haul-yard" - because, on a square-rigger, it's the rope you use to actually haul the yard up, sail attached, once you've got it unfurled and sheeted to your liking - the spelling shift is an odd one indeed.
.. as is the Topsail Hitch, even though neither find much use on a modern yacht.
..and a pump if you're American. Worked by blacks perhaps, TD??
..and on a great many full-rigged ships, so that one will be around for a while yet. It does tend to dance around a bit when sailing down-wind though, and perhaps that's where the reference to certain types of people came from.
Classic30 is offline
post #13 of 25 Old 09-19-2013
Kynntana (Freedom 38)
gamayun's Avatar
Lately I've been learning how to "blow the guy."
gamayun is offline
post #14 of 25 Old 09-19-2013
tdw
tdw's Avatar
I'm not touching that with a barge pole.
― Terry Pratchett.
tdw is offline
post #15 of 25 Old 09-19-2013
I want to Google that yet not at the same time.
br3nt is offline
post #16 of 25 Old 09-19-2013
gamayun's Avatar
The guy is the line that runs to the spinnaker pole. What were ya'll thinking it was?!?
gamayun is offline
post #17 of 25 Old 09-20-2013 Thread Starter
Classic30's Avatar
Dock
Lot's of lines run to the spinnaker pole. Technically, you're thinking of the brace aren't you??
Certainly whatever it is you're meaning by "blow the guy" isn't in any old-time nautical language list I've ever seen - it doesn't even sound nautical..
post #18 of 25 Old 09-20-2013
The gammon is the the bracket that bolts or lashes the bowsprit to the stem head and prevents it from lifting (pull of fore stays) Sailors sitting in the bows may have a chat and so are having a gam. A four masted vessel has its jigger aft of the mizzen. A handy billy ,, a pair of small blocks, usually one has a hook but the other has a short line to lash to larger line or shroud with a rolling hitch. I use one to set up my lanyards and deadeyes.Swigging up is the last bit of bouse and tail (before haul yard winches) Sort of like snugging the snotter. Now if you knew what's a snotter!! Would it help to know it goes though the beehole.? Even a little nipper knows that.
Capt Len is offline
post #19 of 25 Old 09-20-2013
gamayun's Avatar
It's in Wikipedia so it must be a somewhat common nautical term, right?
"Retrieving the spinnaker is a multi-step process, and the take-down depends on wind position. First, the windward corner is detached from the spinnaker pole and the guy is released. This step is referred to as blowing the guy. This allows the spinnaker to collapse into the shadow of the mainsail, where the foot is gathered by a crew member. The halyard is then lowered..."
It was also in a 1985 article in Sailing World magazine: http://www.sailingworld.com/sites/al...-takedowns.pdf.
gamayun is offline
post #20 of 25 Old 09-20-2013 Thread Starter
Classic30's Avatar
Dock
IIRC, the word "gammon" also describes the rope lashing that keeps the topmasts in place and "gammoning" the job of actually doing it... but either way, in the bows or up the mast, in a decent swell it sounds like hard work to me!
"Snugging the snotter.." - I like that.
Repeat after me: "Serve and parcel with the lay, turn and serve the other way." A laborious and messy job unless you happen to really like the smell of Stockholm Tar.
nautical language rant jsnaulty General Discussion (sailing related) 83 08-01-2012 12:46 PM
Sailing command language DirkJ Seamanship & Navigation 31 08-28-2010 11:04 AM
Boatbuilder Language Lancer28 Sailboat Design and Construction 7 11-05-2007 04:52 PM
