How Do I Replace a Cntinuous Furling Line?? - SailNet Community
post #1 of 13 Old 09-17-2013 Thread Starter
jim7289's Avatar
My friend has a '91 Catalina 30footer. It has a jib furler that has a continuous loop furling line. It is a great system since it prevents the furling line from over riding and jamming the furler. Any suggestions on how to replace this line.
He said the furler is marked 'North Sail".
jim7289 is offline
post #2 of 13 Old 09-17-2013
TTC
Re: How Do I Replace a Cntinuous Furling Line??
Easy: Find a rigger or someone who can splice lines. They can replace it for a modest fee.
Harder: Learn to splice lines yourself.
TTC is offline
post #3 of 13 Old 09-17-2013
bruceyp's Avatar
Or you can do it your self.
http://www.samsonrope.com/Documents/...UG2012_WEB.pdf
I did a practice or two with smaller line then did the real thing. It wasn't perfect but it worked and lasted 2 seasons before Sandy did the furler in.
Bp
bruceyp is offline
post #4 of 13 Old 09-17-2013 Thread Starter
jim7289's Avatar
Thanks, I'll pass the info to the owner.
jim7289 is offline
post #5 of 13 Old 09-18-2013
Bp
The splice in this doc wont work on all furlers since it increases the diameter in the splice.
This one is better.
knuterikt is offline
post #6 of 13 Old 09-18-2013
chucklesR's Avatar
I have a Hood continuous line furler, really folks - this is it? I have to have a rigger come to my boat and make the splice in place?
chucklesR is offline
post #7 of 13 Old 09-18-2013
But if not...
Just faced this as I had to replace the furling line winch. I decided it was a skill I should know for when there is no rigger close by. I tried to hire a rigger for an hour to come to the boat and teach me, but the schedules never worked out. So off to youtube and some studying. After a couple practice runs on old line, I felt confident enough to give it a shot. The result probably isn't as perfect as an experienced rigger, but it's done, it works and I know I can do it again.
One lesson learned if you decide to try it yourself. Spend extra time on figuring out the length calculations - where do you mark what parts of the splice to end up with what length line. I now have an extra piece of line aboard that's just a little too short to use as a furling line - about 2 fid lengths too short, in fact...
paperbird is offline
post #8 of 13 Old 09-18-2013
You have three options
  1. Bring the furler to the rigger
  2. Bring the rigger to the furler
  3. Find a friend you can bring
  4. Learn to do the splice
  5. ?
This is an easy splice to do -one of the easiest double braid splices.
Basically it's all about removing the core in the splice section and cross the cover into it self and get a tight fit where the core/cover ends meet inside the rope. Secure by cross stitching.
post #9 of 13 Old 09-18-2013
Owned by Velcro
Ferretchaser's Avatar
If you are close to the Bohemia river I'll splice it for you
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #10 of 13 Old 09-18-2013
tommays's Avatar
It depends on the double braid brand ,for example on sta-set the outer core is on the small side and I had to do it with my wire loops as the fids are to large
Most of the time you also need to build it to a fairly exact length and I suggest practice as just snagging a tiny bit of jacket or core fugs it up
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Replace Diesel Fuel Line Bake81 Diesel 3 03-08-2013 07:32 AM
Scotty, (Replace Old DC Breaker Panel) When Will I Have My Warp Power On Line ? HighFly_27 Electrical Systems 4 11-09-2012 07:37 PM
How hard/$$$ to replace furling main with a proper battened one? EarthBM General Discussion (sailing related) 8 10-15-2010 07:58 PM
Unbreakable Furling Line... MedSailor Gear & Maintenance 17 05-22-2008 06:18 PM
How to make a furling line? MelSnyder Gear & Maintenance 5 06-22-2007 08:13 AM
