Wacky Wind - SailNet Community
 1Likes
post #1 of 13 Old 09-22-2013 Thread Starter
Wacky Wind
Sailing in Casco Bay, Maine yesterday was a bit challenging. Going off the mooring, we saw the wind was at 17 kts, so decided to reef and put out only the staysail as the wind was supposed to kick up. After going 2 kts in an 8 kt wind we put up all the sails.
The wind varied in direction by about 15 degrees, which made beating difficult, and the speed varied from 8 or 9 kts with gusts to 20, which nearly buried the rail and caused loss of control until we dumped the main and the jib (maybe we should have pulled in the jib and just gone with the stay?). Between this and the fog we called it a day and went back in.
Suppose we weren't daysailing and had to continue? What are your tactics for dealing with very gusty wind. Do you under canvas to prepare for the worst or set sails for the predominant speed and adjust for the gusts? I can see merits in both.
Thanks.
doug1957 is offline
post #2 of 13 Old 09-22-2013
grumpy old man
Re: Wacky Wind
Doug:
I think it would depend on the amount of effort you wanted to put into sailing the boat and how long you anticipated the conditions lasting. More a matter of personal sailing style rather than doing "what is right".
killarney_sailor likes this.
Bob's Blog ....
bobperry is offline
post #3 of 13 Old 09-22-2013
Re: Wacky Wind
as the golf slogan goes... "Grip it and Rip it!"
I prepare for the lightest condition and dump the main when it gets too "hot".. but I'm on meds for it, now!!
Johnnycatt is offline
post #4 of 13 Old 09-22-2013
Re: Wacky Wind
Also depends on your comfort level... If you find it difficult to manage the puffs, you may be better off under-canvassed and "suffer" through the lulls... As your confidence grows you can lean towards the opposite.
Faster is offline
post #5 of 13 Old 09-22-2013
Tartan 27' owner
CalebD's Avatar
Re: Wacky Wind
A question of philosophy.
Everybody has one:
CalebD is offline
post #6 of 13 Old 09-22-2013
Re: Wacky Wind
The OP describes what we consider nice sailing conditions on north Texas lakes :-)
I didn't catch the size of his boat. Our Bene31 is not hard to control under those conditions, but it behaves much as you describe under full sail when when the winds get maybe 5 kts higher.
A lot of this depends on your boat, and sail conditions. I have two strategies for these conditions. If I'm trying to sail fast, we just try to read the wind for the gusts, and drop the traveler when they happen to try to avoid rounding up. I may go ahead and flatten the main as much as I can, and move the jib fairleads back. Maybe add some twist to the main. Crew on the windward rail helps a lot more than I thought it would in a boat this size. I don't have an adjustable back stay; if you do you might see if putting on some backstay helps.
OTOH, if I'm just cruising around and don't want to make my main trimmer work so hard, I will may go ahead and reef at least the main. It will be slower in the lulls, but more controllable in the gusts.
s/v Dancing Days
Beneteau 31
Lewisville Lake, TX
bacampbe is offline
post #7 of 13 Old 09-22-2013 Thread Starter
Re: Wacky Wind
Thanks all for your ideas. We've been in 25 kts steady and had a blast, but this was a different beast entirely. You've definitely given me some ideas to try the next time. It seems it comes down to how hard do you want to work and how long is it going to be like that? the boat can definitely take it - it's really hard to bury the rail, so I don't worry about going over too far. For me, it was the complete loss of control (rounding up) until we dumped the main and (emphasis) jib. That was a new learning experience. I haven't reefed the jib as we usually just go with the staysail in high winds, but in this kind of situation, it may be worth a try.
doug1957 is offline
post #8 of 13 Old 09-22-2013
Re: Wacky Wind
What boat are you sailing?
Faster is offline
post #9 of 13 Old 09-22-2013 Thread Starter
Re: Wacky Wind
Shannon 28 cutter. I don't think the boat's the problem.
doug1957 is offline
post #10 of 13 Old 09-22-2013
Re: Wacky Wind
I wasn't suggesting that... it's just helpful to know what type/size of boat is under discussion - it can make a difference to techniques and options.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
doug1957 (09-22-2013)
Wacky hypothetical question - jury rigged pedal power mattt General Discussion (sailing related) 18 09-15-2013 01:06 PM
Wind powered vehicle speeds much faster than wind; downwind! Dirtboy General Discussion (sailing related) 41 07-19-2011 09:53 PM
Wacky winds blow over regatta (Long Beach Press-Telegram) NewsReader News Feeds 0 02-19-2007 04:17 AM
wind point / wind speed bkw Learning to Sail 4 09-11-2006 03:01 PM
