-   -   How do you store excess energy? (http://www.sailnet.com/forums/general-discussion-sailing-related/103982-how-do-you-store-excess-energy.html)
allio 09-22-2013 09:14 PM
So I was thinking... Do boaters who generate power from renewables like wind, towed hydro, solar etc... have systems on board to store excess generated energy?
For example.
You're in the Caribbean and a couple of hours sunlight in the morning has topped up your batteries from overnight use.
What do you do with the rest of the days energy?
Do you have a small electric water maker to use the excess solar to top off your fresh water tanks?
A small electric ice maker?
Etc...
Can these systems be designed in to automatically come on once the batteries are topped off?
Hear me ROAR
miatapaul 09-22-2013 09:19 PM
Re: How do you store excess energy?
I know some people will dump it into a hot water heater. It will take a lot of it and it is nice having hot water.
MarkofSeaLife 09-22-2013 10:24 PM
1 Attachment(s)
Hot water heaters work off the engine or shore power. Watermakers need a generator or engine.
Basically unless you have the battery bank its wasted.
I am in that problem area. (Actually I'm not unless I have my bimini back. It tends to cover a bit of the solar panels in the morning. But when I get davits the panels will go on top giving me lots more electricity!)
What I tried to do but didnt work was put 3 freezer blocks in the frige/freezer during the day so they could slowly thaw out at night. Difficulty is the frige at 40 deg F / 4 deg C will not drop down to 0F/-18C fast enough to freeze freezer blocks in the day.
The other problem is that you need a massive oversupply of solar to make any plan for excess work because we tend to use all the power we have... for example: I have 15 minutes before I have to turn off the computer becausse the battery is down to 12.45 and its only 22.23pm.
Oh woe! LOL
allio 09-22-2013 10:51 PM
I suppose that a better way of thinking would be, do people plan excess generating capacity as part of their on board systems? If i was calculating my consumption to generation ratios, i think I would install enough capacity to generate twice my consumption if my generators were running at 100%. That way I would still be comfortable if my generators only produced 50%of their max daily capacity.
I suppose the problem becomes a technical one where you have a how to use unstable voltages and average without the need for a moderator like a battery. I can't imagine that a fridge will run if it can't draw the amps it needs when it needs it......
Hear me ROAR
allio 09-22-2013 10:52 PM
Woops. Meant amperage where it says average.... D**n predictive text :)
Hear me ROAR
Bene505 09-22-2013 10:58 PM
I made a simple circuit that flips a relay on the thermostat wire whenever the voltage gets to 13.5V during the day. The freezer/fridge compressor stays on (at the higher speed) until nightfall.
It's only about 4 or 5 amps, and we have 590 watts of solar strapped to our bimini.
Next step is to put it into the hot water heater, but I want to understand more about how the hot water heater's circuit works and how many watts the element is. (We have an extra, WalMart type inverter but may wait until I gat a marine inverter.)
There was one cruiser who put the extra energy into a watermaker. He had the extra fresh water going into a bucket in the cockpit for doing laundry. (Forget who it was, but google "Bene505 watermaker bucket cockpit site:cruisersforum.com" and "Bene505 watermaker bucket cockpit site:sailnet.com" and you may find the thread.)
Regards,
Brad
allio 09-22-2013 11:06 PM
Another random idea might be grow bulbs in your onboard "sprout" mini greenhouse....
Hear me ROAR
Don0190 09-23-2013 07:22 AM
Who really needs to use excess energy? If you needed it it wouldn't be excess.
Minnewaska 09-23-2013 07:47 AM
Spectra makes 12v watermakers, which would be happy to soak extra juice.
MarkofSeaLife 09-23-2013 08:04 AM
1 Attachment(s)
Why the hell would you double the spend on solar panels? Have you priced them? Bloody expensive! And you want to double them so you have too much electricity?
And where are you going to put them? On a monohull you are starved for space. A cat has more space above the hard bimini.
If someone spends $3,000 on renewable energy you would wonder why they would spend another $3,000 for 'excess'??
I'd prefer to spend the other $3,000 on restaurants with hot chics in sleazy parts of the world. :D
Mark
