Nav light question - SailNet Community
 5Likes
post #1 of 14 Old 09-25-2013 Thread Starter
rbyham's Avatar
Nav light question
Been getting into night sailing lately. My light set up is navigation lights on one panel switch that turns on lower red/green plus stern white PLUS white light half way up mast pointing forward. This white light hits my jib and makes me very visible but some have told me that should only be used when under power. In order to do that I would need to add a switch. Also I have red/green/white masthead light on a second switch. I turn them all on at night. Guys tell me I look like a Christmas tree. But in a busy commercial harbor like Charleston that sounds like a good thing. :-) so what lights do you think I should be running under sail keeping in mind those massive container, navy, and CT vessels that like to move around at night? And how about that white one half way up mast? Am I ok to run it under sail? Thanks.
rbyham is offline
post #2 of 14 Old 09-25-2013
chucklesR's Avatar
Re: Nav light question
When sailing just use the tricolor at the masthead.
When motoring using the steaming light pointing forward.
Don't mix it up - misrepresenting what you are and what you are doing makes a collision your fault.
Faster, vega1860 and smurphny like this.
chucklesR is offline
post #3 of 14 Old 09-25-2013
Yes.. since they're wired separately, in your case the lower set under power (with forward white 'steaming light'), the masthead tricolour under sail...
It's pretty much up to you to avoid the shipping... how much you're lit up won't make a difference there.
Faster is online now
post #4 of 14 Old 09-25-2013
I agree with Faster and Chuckles that currently your options are limited to sailing with the tri-color and then turning that off and using the deck/light, steaming light combo when under power. You can't use both.
But I would eventually try to put the steaming light on a seperate switch. That's my set-up.
I think the tri-color is good to have at sea and probably with the large shipping you contend with, but smaller recreational power boats might be less inclined to look 50 feet in the air to see your nav lights. Just a thought.
tempest is online now
post #5 of 14 Old 09-25-2013 Thread Starter
rbyham's Avatar
Thanks folks... Sounds like consensus. I will operate masthead when sailing and lowers under power. But ultimately I think the full answer is steaming light on separate switch...
rbyham is offline
post #6 of 14 Old 09-25-2013
davidpm's Avatar
One advantage to the masthead tri-color is that when sailing the deck level lights can cause enough glare to be distracting and and damage your night vision.
davidpm is offline
post #7 of 14 Old 09-25-2013
My steaming light is out of commission, is it appropriate to substitute the anchor light along with the running lights.
Mark1948 is offline
post #8 of 14 Old 09-25-2013
steaming lights only light the front while anchor lights are all around
fred1diver is offline
post #9 of 14 Old 09-25-2013
paulk's Avatar
Like Chuckles says, lighting the wrong lights misrepresents what you are doing. Using the anchor light MEANS that you are anchored. Using the steaming light MEANS that you are under power. Maneuvering at night is dangerous enough without essentially lying to others around you that have to act according to the lights that you are showing. Your improper lights may cause them to steer the wrong way and result in a nasty accident. Fix your circuits or stay home after sundown.
paulk is online now
post #10 of 14 Old 09-25-2013
jackdale's Avatar
No.
From the stern someone would see two white lights. That could be mistaken for a 50 m vessel with the sidelights below the horizon.
jackdale is offline
Charging Light Question manhattan08 Gear & Maintenance 8 07-12-2010 01:28 PM
Question About the Light Lists KindOfBlue General Discussion (sailing related) 2 07-01-2010 11:25 AM
Catalina 22 mast light disconnect question andyjen Gear & Maintenance 12 03-04-2009 09:11 PM
nav light question badsanta Gear & Maintenance 9 07-15-2008 05:38 PM
Anchor Light - Newbie Question Fasteddy General Discussion (sailing related) 1 05-20-2002 10:50 AM
