Double vang? Rigging question from a beginner - SailNet Community
post #1 of 9 Old 09-26-2013 Thread Starter
Minnesail's Avatar
I was at the docks ogling boats and I saw one that looked particularly stunning so I walked over for a closer look. It's a gorgeous boat, well cared for. I was told it's a Valiant 40 (I don't know boats well enough to identify it myself).
Anyway, it has some rigging that confuses me. It looks like twin vangs connected to the genoa car track. That's probably not it at all, but I'm hoping someone could explain the function of this rig. What the heck is this?
Minnesail is offline
post #2 of 9 Old 09-26-2013
rhr1956's Avatar
Re: Double vang? Rigging question from a beginner
I'm guessing that is a boom preventer setup. Keeps the boom from accidentally swinging across the cockpit.
rhr1956 is offline
post #3 of 9 Old 09-26-2013
no longer reading SailNet
Alex W's Avatar
Those are preventers, used to prevent an accidental jibe when going downwind or wing and wing.
It's more common to see those and a vang rigged. I guess you could use those as a vang only, but you'd have to adjust it on every tack or jibe which would be really annoying.
Another common setup is to have the vang setup with a snap shackle. Then you can unclip it from the mast and clip it to a track to act as a preventer.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
Minnesail (09-26-2013)
post #4 of 9 Old 09-26-2013
Yes vang/ preventer, they are clipped to the staysail tracks to keep the side decks clear at dock side and sailing at higher angles. They would be moved to the rail more off the wind.
ctl411 is offline
The Following User Says Thank You to ctl411 For This Useful Post:
post #5 of 9 Old 09-26-2013 Thread Starter
Minnesail's Avatar
OK, got it. The only preventers I've seen (again, beginner here) have been run forward and not used blocks.
So does this boat not have a boom vang? Or would cranking down on the preventer serve the same function?
post #6 of 9 Old 09-26-2013 Thread Starter
Minnesail's Avatar
I should hit refresh before I post... So this boat wouldn't need a traditional boom vang run to the mast, because these preventers would hold the boom down. That makes sense.
post #7 of 9 Old 09-26-2013
Kynntana (Freedom 38)
gamayun's Avatar
I hope this is not a hijack to the OP....Alex, can you explain a bit more how this set up would be rigged? Is this just a line running from the boom where the vang is? I've been looking at different preventer setups and trying to decide what's best.
gamayun is offline
post #8 of 9 Old 09-26-2013
Master Mariner
capta's Avatar
IMO these are too far inboard to be used as a preventer. As mentioned above a preventer is usually run from the boom end forward as a single line.
I have a very similar system, though with just one block and tackle which I use as a vang, but when tacking I must move the end on deck (on the genny track) to the other side.
This appears to be a vang system that can be handled from the cockpit without the jam cleat at the deck block that my system uses.
I'm not too sure that it wouldn't be a bit more versatile if the deck ends were to the genny track, rather than the staysail track (farther outboard) but it certainly wouldn't be as neat. Pretty nifty though.
facebook.com/svskippingstone
Our Videos;
capta is offline
post #9 of 9 Old 09-26-2013
overbored's Avatar
Boom preventer / vang. it has snap shackles so it can be move to the rail but would work from the jib track. on Valiant 40 the genoa/ foresail track is way aft and would not work for the preventer . it is a cutter rig so most likely no genoa
"GOLD RUSH" PRINDLE 16
overbored is offline
Rigging a boom vang Barquito Gear & Maintenance 4 08-10-2013 12:24 PM
Beginner Bilge Question synapse General Discussion (sailing related) 3 06-05-2012 05:35 PM
Rigging a preventor using the boom vang on a C22 MazeRat7 General Discussion (sailing related) 7 09-02-2009 03:50 PM
beginner question sodman12 Boat Review and Purchase Forum 7 08-21-2007 11:30 PM
Another beginner question.... BlueWaterWannaBe Living Aboard 6 02-20-2007 08:08 AM
