Dinghy Towing - SailNet Community
post #1 of 20 Old 09-29-2013 Thread Starter
svQED's Avatar
Dinghy Towing
I was recently watching an episode of Distant Shores and noticed that when they towed their dinghy behind the boat, they used two lines which made the dinghy go from side to side. I had never seen this before and am wondering what the benefits of doing this are. Also, how common is it and are how exactly would you go about setting it up?
Thanks for the help.
svQED is offline
post #2 of 20 Old 09-29-2013
MarkofSeaLife's Avatar
Dock
Re: Dinghy Towing
When I tow my dink I put a bridle on the two D rings on the tubes just above the waterline. These are meant the be the attachment points for towing.
Then I put a safety heavy bit of old genoa sheet on, and finally add the painters.
Between islands here its too short a passage to put the dink on deck but the gaps between the islands can be mighty rough!
I have lots of elasticity in the bridle lines
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #3 of 20 Old 09-29-2013
overbored's Avatar
Re: Dinghy Towing
we use a bridle to the two D rings and a single painter with a safety line to the center ring which is slightly loose during towing.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 20 Old 09-29-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Re: Dinghy Towing
svQED,
When towing, we tow our dink with 2 lines. One is poly to float. the other is not and we are very careful with it. Both are taken up to a cleat on the side deck for close maneuvering and close work. The two lines do not make our dink swing from side to side. It does swing in cretin wind/wave conditions.
As to why,..... I once gave away a new dink cruising the Bahamas. It was there in the evening, at day break, it was not.... OUCH
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #5 of 20 Old 09-29-2013
Re: Dinghy Towing
Without seeing the vid, not sure what you're describing, or why anyone would actually WANT their dink to oscillate from side to side :-)
As others have described, you definitely want to use a secondary backup preventer. On a soft bottom inflatable, however, I wouldn't want to rely on on the towing rings glued to the tubes, solely. When I used to have an Avon Rover as my tender, I used to run my primary towing bridle through a loop on the bow eye, then underneath the bottom and back to a pair of padeyes bolted through the transom... It's a far more secure setup, in the event the tender might get swamped or take on a lot of water in a squall, whatever - and it also seemed to help lift the bow a bit, and help break the bottom suction that a soft-bottom inflatable can develop. Now that I have an RIB, one of the big advantages is the large towing eye bolted through the bottom... Still, some sort of bridle arrangement to the rings positioned outboard will definitely help in keeping the inflatable tracking straight...
Greg
Well, there's one pretty easy way to avoid that one, of course... :-)
JonEisberg is offline
post #6 of 20 Old 10-01-2013
Re: Dinghy Towing
Welcome to the board svQED!
FirstCandC is offline
post #7 of 20 Old 10-01-2013
Broad Reachin'
kwaltersmi's Avatar
Re: Dinghy Towing
We use a bridle attached to the d-rings on the bow of the dink. Then a poly painter (floating) run to a stern cleat. We adjust painter length so that the dink's motion over the swells/waves is in rhythm with the mothership.
We've tried two painters in the past, but didn't like way it towed, mostly because of the side-to-side motion that you noted. I suppose if you tinker enough and get the lengths just right you can eliminate the sideways motion, but a single painter has work fine for us.
Catalina 34
kwaltersmi is offline
post #8 of 20 Old 10-01-2013
Coquina's Avatar
Re: Dinghy Towing
For our RIB - an Avon 340 - one floating line to the towing eye secured through the fiberglass hull works great. For the soft bottom we used to have the only way it towed well was lifting the bow up out of the water.
I once tried to tow a canoe and it oscillated horribly. We tied a small round fender to the stern of the canoe and it made a great drogue and steadied the tow perfectly.
Joe Della Barba
Coquina
C&C 35 MK I
Coquina is offline
post #9 of 20 Old 10-01-2013
ASA and PSIA Instructor
Re: Dinghy Towing
The two bridle lines to D rings serve to minimize the yaw motion of the dingy. I advise also running a third line from the bridle junction to the inflatables's bow (an centerline eye or handle), and to adjust the length of that line so it pulls up before the other two lines.
After a lengthy trip towing a rib in rough seas using just two bridle lines, I found the wave action had almost completely slit the attachment patches holding the D ring straps, i.e the D rings were close to being ripped off.
sailingfool is offline
post #10 of 20 Old 10-01-2013
Re: Dinghy Towing
Use a 2 point bridle at the dinghy AND the boat. I also have a length of bungee between the bridle lines at the boat. As the dingy pulls back (due to waves) the bridle lines try to straighten, the bungee resists and takes some of the shock.
DonScribner is offline
Towing a dinghy Barquito Gear & Maintenance 14 04-28-2012 07:56 AM
towing a dinghy, Painter size? Cruiser2B General Discussion (sailing related) 19 09-17-2011 03:04 PM
Dinghy towing gulfcoastcruiser Cruising & Liveaboard Forum 4 08-31-2010 02:59 PM
Towing a dinghy PBzeer Seamanship & Navigation 57 02-20-2007 12:22 AM
Towing hard dinghy EClaire Gear & Maintenance 3 04-24-2003 09:47 PM
