Need cruising help. - SailNet Community
 10Likes
post #1 of 29 Old 09-30-2013 Thread Starter
Need cruising help.
I am going on a 6 day sail. It starts with a 20 hour crossing. What should i take for the meal on the first night? I want something simple but warm and nourishing for two.
We are going to be in a crowded mooring field. I believe there will be a shower somewhere on shore but plan on taking a solar shower. Is there a soap that is good for hair and body that I can use from the foredeck that is not bad for the ocean or offensive to the other boats nearby?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #2 of 29 Old 09-30-2013
Asleep at the wheel
jimgo's Avatar
Re: Need cruising help.
Jordan,
If you'll be able to make hot water, consider some of the instant noodle bowls that you can find in the grocery store. They are inexpensive, usually taste OK (note that I didn't say they are a gourmet meal), last a long time, and are easy to prepare.
Sorry, I can't answer the soap question.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 29 Old 09-30-2013
snake charmer, cat herder
zeehag's Avatar
i just use what i used on land.
cruising is taking your comforts of home out to play. make it comfy as poossible if you wish to continue.
i been out here now since 2011 and have yet to use any magically overpriced
junk that is put out for alleged marine use--i wont pay the inflated price for same thing i can buy elsewhere cheaper by 400 percent.
if you want a soap that works in sea water, buy castile.
joy soap or dawn also mix well with sea water.
otherwise, use what you enjoy using. i do even in sea water--i dontfollow snotty yottie rules out here--they are useless.
formosa 41, cruising tropics
zeehag is offline
post #4 of 29 Old 09-30-2013
azguy's Avatar
Depending on what you like to eat, pasta is easy to cook (and you can even bring the fresh noodles for the 1st few days) and supplies some carbs and you can mix in canned chicken and use some olive oil and garlic or some red sauce...
azguy is offline
post #5 of 29 Old 09-30-2013
The most female moderator
Donna_F's Avatar
Dock
What type of cooking equipment will be available? I often make soups or stews while at home to heat up on the boat. I have grilled beef at home so all I have to do is slice it on board for sandwiches or wraps. Sometimes I plan differently for eating while underway vs. while at anchor vs. at a marina (many marinas do not allow you to grill off the deck).
For clean up after, I found that Dawn is better than others in cold water. For personal hygiene, we use Pears soap both at home and on the boat.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #6 of 29 Old 09-30-2013
no longer reading SailNet
Alex W's Avatar
Hard to beat soup. You could even make a handmade soup beforehand at home and leave it slow cooking on the boats stove (assuming it has gimbals and a pot holder) and then arrive to warm soup and good bread. I love making lentil soup (saute onions in olive oil until they turn clear, add a mix of red and brown lentils, rice, spices, water, simmer for 2 hours) this way.
Dr Bronners does the trick for me.
alex
bljones likes this.
Alex W is offline
post #7 of 29 Old 09-30-2013
TQA
Bombay Explorer 44
TQA's Avatar
A one pot meal in a pressure cooker is the way to go for hot food. I emphasize the pressure cooker as even if it jumps off the stove the lid stays on. Stew chili curry etc served with some chunky bread.
But if it is rough and you are not regular sailors you may be feeling a little sick and without much appetite. In which case trail mix, granola bars, crackers, bananas, apples and small tins of fruit salad in a cockpit locker along with LOTS of bottled water is good.
TQA is online now
post #8 of 29 Old 09-30-2013
Skipper Jer's Avatar
Personally I stay away from those dehydrated noodle cups. The MSG sends me into overdrive. Consider homemade soups, no grease, It takes all of 15 minutes to load up the slo-cooker for an overnight cook of a soup. Pout hot soup into thermos jugs and off you go for your cruise.
boatpoker likes this.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #9 of 29 Old 09-30-2013
Unkle Toad's Avatar
I used to use Dr. Bronners when traveling or camping. One bottle, teeth body hair dishes .. it cleans anything .. although Ill use baking soda before bronners for teeth.
Unkle Toad is offline
post #10 of 29 Old 09-30-2013 Thread Starter
I used to use Bronners back in the day. I remember brushing my teeth with it. A lesson I will not repeat.
I had planned to use today to finish prepping but got called in to work and am stuck in a remote location now. It will be a busy night for me. I like the pressure cooker idea, wish I had time to prep something.
After the 20 hour sail we will be at Catalina Island for the opening of lobster season, so I plan on eating lobster for breakfast lunch and dinner the next 4 days.
jimgo likes this.
Jordan
Oceanside CA
jephotog is offline
Budget Cruising/Bluewater Cruising Cruisingdad Cruising & Liveaboard Forum 104 10-28-2014 08:35 PM
The Cruising Life, by Jim Trefethen, and Cruising Financials Jim H Cruising & Liveaboard Forum 205 10-11-2010 07:07 PM
Andrew Burton reviews the Broadblue 385 for the 2007 Cruising ... - Cruising World NewsReader News Feeds 0 01-19-2007 05:15 PM
Newbie cruising family looking to hook up with cruising families in BVI hsilvermanmdjd Cruising and Sailing with Children 8 09-04-2006 02:27 AM
