Survey results - SailNet Community
post #1 of 7 Old 10-01-2013 Thread Starter
Survey results
Just got my pre-purchase survey results. My biggest concern is blisters.
"There are many gel coat blisters on the hull between the bottom paint and the boot stripe for a distance of approximately 7' on the
starboard side. These are cosmetic in nature but should be repaired never the less."
I'm surprised I missed them but I guess I was overexcited.
I couldn't attend the survey and he told me they were about the diameter of a pencil eraser. This looks like an expensive repair. See picture. Thoughts?
The surveyor also said he thinks the boat overall is in nice shape for it's age. (97 Hunter)
stevestk is offline
post #2 of 7 Old 10-01-2013
Re: Survey results
I bought a boat last year with about 6 to 10 blisters probably about one inch in diameter, classic smell when the surveyor popped them. I had them ground out and repaired then had the bottom painted. I can't remember the exact cost but it was only a couple of hundred dollars. Had boat pulled in Caribbean for hurricane season after it had been in water for nine months no blisters, so your small blisters don't sound a big issue
neilsty is offline
post #3 of 7 Old 10-01-2013
Re: Survey results
Does not look like a deal breaker. A few small blisters close together is no big deal to repair. Easy DYI ( Do Yourself In ).
Sent from my rooted DROID X2
Mark
1975 Hunter30
mjf55 is offline
post #4 of 7 Old 10-01-2013 Thread Starter
Re: Survey results
Doesn't the fact that these are in an area above the bottom paint mean more expertise is needed for a smooth color matched gelcoat finish?
stevestk is offline
post #5 of 7 Old 10-01-2013
Re: Survey results
Is it a gelcoat bootstripe? or painted on after the fact? That would make a difference.
Faster is offline
post #6 of 7 Old 10-01-2013
Re: Survey results
Why would they be above the waterline
neilsty is offline
post #7 of 7 Old 10-01-2013 Thread Starter
Re: Survey results
I wondered the same thing but found a site with extensive information on blisters that indicated at or just above the water line was fairly common. I see water stains by them.
stevestk is offline
Sailing results NewsReader News Feeds 0 03-15-2012 11:00 AM
Insurance survey vs purchase survey RossC32 General Discussion (sailing related) 9 03-01-2012 05:05 PM
Sea Trial and Survey Results montenido Boat Review and Purchase Forum 9 06-05-2008 09:50 AM
Survey Results - Pursue or Run Away? Ishmael Boat Review and Purchase Forum 22 10-03-2007 03:11 PM
Bayfield 32C Survey Results :) Kacper General Discussion (sailing related) 27 04-27-2007 06:47 PM
